What is that ticking noise???
Old May 19, 2008 | 08:08 PM
Queen of Mean's Avatar
The Queen
I just noticed 2 days ago that when I start my car it has some kinda ticking noise coming from the motor or somewhere up there? I have no idea what the hell it is and since I'm a girl I NEED assistance!! I have 42,000 miles, up to date with maint., and I can't tell a diff. in the way it drives or anything else.
Old May 19, 2008 | 08:14 PM
DarkBrew's Avatar
Extraordinary Engineering
http://www.youtube.com/watch?v=Tx1XIm6q4r4
Post a video or recording.
BTW, don't pull the "I'm a girl' thing; Just ask for help!
Old May 19, 2008 | 08:28 PM
Jon316G's Avatar
Grasshopper
Could be several solenoids and valves that perform a self-test when the ignition is first turned on.
Also, check the spark plug wires, at the plugs and at the coils. Could be a spark jumping the gaps.
Old May 19, 2008 | 08:39 PM
The Queen
The ticking stays on after the car is running and sounds like a lifter noise on a regular engine. Could bad gas make this happen.
Old May 19, 2008 | 08:53 PM
xsnipersgox's Avatar
One Shot One Kill
http://www.youtube.com/watch?v=wiI7-iXQj48
tat is wat a bad connection at the spark plug sounds like.
Old May 19, 2008 | 09:00 PM
The Queen
So if the spark plug wire is loose it'll make that noise??
Old May 19, 2008 | 09:04 PM
One Shot One Kill
if anything from the wire to the sparkplug to the spark plug not properly tighten/loose, you will hear arcing sound.
Old May 19, 2008 | 09:09 PM
Jon316G's Avatar
Grasshopper
Correct.
Just grab the spark plug wire boots and give it a twist while pushing in and see if you still hear that sound afterwards.
Old May 19, 2008 | 09:11 PM
The Queen
Fixed It!!!
I found the problem!!! It was the plug wire, it was almost off. I also want to know is it common for them to get that loose? This "dumb" girl fixed something!!
Jon316G's Avatar
Grasshopper
Good job!
Yeah... they have been known to come loose.
Old May 20, 2008 | 07:26 AM
Go48's Avatar
If the wires are properly snapped onto the plugs (you can feel it snap), they should not come off--ever. Well, almost never.
Old May 20, 2008 | 07:53 AM
Jon316G's Avatar
Grasshopper
From what I've read here, the lower front plug wire is known to come off.
Old May 20, 2008 | 10:44 AM
The Queen
well, that's the one that was almost off... gotta change em out anyway so maybe that'll be the end of all this???
Old May 20, 2008 | 01:01 PM
VampireSix's Avatar
Well I'm glad someone posted this thread, because I've had this issue since I bought the car a year ago (48k at purchase, 67k now)!
What do I need to do to check my plugs? Does this require taking off the front driver side wheel, or can I check it from the hood?
Old May 20, 2008 | 07:40 PM
Jon316G's Avatar
Grasshopper
The plug wires can be checked through the hood if you have long skinny arms.
I just lay on the ground and reach up from underneath.
To check/remove the spark plugs themselves, refer to this DIY:
https://www.rx8club.com/showthread.p...ighlight=spark
Old Mar 17, 2009 | 11:00 PM
kellyrx8's Avatar
thats exactly what mine sounds like...
I took mine to Firestone where my old roommate works, threw it on the lift and checked the wires...everything was snug...
you mentioned in your video that the plug wasnt torqued down enough...did re-torquing it fix the problem?
Old Mar 18, 2009 | 10:51 AM
Yee Haw! Queen of Mean can be my mechanic any day!
Old Mar 18, 2009 | 10:54 AM
dozer's Avatar
on his 3rd rx8
NICE JOB!, now go and link this to every "ticking noise" thread out there...this is EXACTLY what i tell people and they dont wanna believe me
Old Mar 22, 2009 | 06:14 AM
DOMINION's Avatar
I don't buy Kool-Aid
That might be due to the fact that I changed my coils spark plugs and spark plug wires and I got, never had, this "ticking noise". I also just went down to my car, removed all the spark plug wires and reinstalled them. Start the car up and its still ticking like timex lol
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
