How to shift faster and easier ?
Old May 17, 2008 | 12:10 AM
PRX8's Avatar
When street racing and drifting, downshifting I miss gears, sometimes don't shift properly, and feels stiff.
I've changed the clutch to Act HD and Act HD pressure plate, ACT prolite flywheel, and feel power but not easy to shift.
What can I do or replace to feel the shift a lot soft and faster.
I've heard about the short shift , but what does this actually do? Will I be able to shift faster and easier than stock for drifting purposes.
Old May 17, 2008 | 12:37 AM
flip's Avatar
LOVE / HATE Relationship
street racing...
Old May 17, 2008 | 12:51 AM
AJ's Shinka's Avatar
Enthusiast
He's from Puerto Rico street racing is legal there, but not in here. Yes, to the short shifter get the AFE it's very precise.
Old May 17, 2008 | 01:01 AM
hakuna matata!
oh snap
Old May 17, 2008 | 05:24 AM
neXib's Avatar
Change tranny oil? And get the short shifter if you like shorter and tighter gearing like most people, it's probably better for you.
Old May 17, 2008 | 05:43 AM
DarkBrew's Avatar
Extraordinary Engineering
The AFE short shift kit reduces the throw and improves the feel of the shifter.
Add the Voodoo **** and the throw is very quick and precise.
Old May 17, 2008 | 07:00 AM
wcs's Avatar
wcs
no agenda
Takes some driving lessons.
Learning to shift correctly is pretty hard to teach via a forum post I would think.
I know I need some, and as a matter of fact I'm trying to schedule some for this summer.
Basically you are like the rest of us that haven't had race experience.... you suck.
I suck
That's just the way the universe wants it until you get skool'd dude
Old May 17, 2008 | 07:10 AM
mysql's Avatar
Doppelgänger
The AFE will help you if you're shifting well already and want reduced throws between gears so you can shift faster.
HOWEVER, if you have problems with the stock setup, going to the AFE will make it worse since the throws are shorter, requiring more effort going into gears. Bad combo to have problems going into gear then adding more effort to do it.
Old May 17, 2008 | 07:18 AM
Benjamz's Avatar
Tony says, RX8s are GREAT
Join SCCA
Old May 17, 2008 | 08:00 AM
Search
Old May 17, 2008 | 11:26 AM
PRX8's Avatar
Thanks neXib, next week I will defenitely drain the tranny oil, and put in Royal Purple, also short shifter is on it's way by this friday, hope to get it by thursday so I'll make it to the Speed Show on Saturday at the beach. Will let you know how this went.
Old May 17, 2008 | 11:30 AM
PRX8's Avatar
Wow, didn't realize that the voodoo **** will help on the shifting issues. Thanks for the info. Let'see if I'm not too late to order it along with the short shifter for next weekend.
Old May 17, 2008 | 11:34 AM
PRX8's Avatar
I suck
Jejeje... You can be right nobody is a perfect street racer, at some times we all suck and make mistakes lol...good sence of humor...
Old May 17, 2008 | 11:48 AM
mysql's Avatar
Doppelgänger
it won't.
Old May 17, 2008 | 12:19 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Originally Posted by mysql
it won't.
Old May 17, 2008 | 12:27 PM
neXib's Avatar
I don't know what the voodoo **** is, but I noticed on my previous car when I changed the gearknob to something lighter it was actually a lot easier to shift fast, as long as you knew where you were going it went smoother into gear
Old May 17, 2008 | 01:57 PM
kersh4w's Avatar
Hit & Run Magnet
no.
a heavier shift **** will help you shift, because its weight will help the shifter fall into gear easier.sh ifting is all about leverage. if you attach a weight to the end of a 10 foot pole, its harder to keep it straight than if the weight were right next to you. same idea here, attach a heavier weight to the end of shift **** and it will want to fall down into gear quicker.
whatever. i have the mazdaspeed shift **** and im very happy with it. of course, its also a very heavy ****, so is the oe shifter. compare the weight of our OE **** to a bmw shift ****. our's is at least 5x heavier.
prx8, drive slowly up each gears RPM range. noting where X Gear is at XX MPH. things happen too quickly when racing to check your speed, but this is to give you a feeling. for instance, you are cruising in 6th at 75mph and want some power. you would put the shifter into neutral and quickly rev match to ~8000 rpm and then stick it in 3rd.
once you have a feeling for what speed relates to what gear to what rpm you'll have an easier time down shifting. always rev match when downshifting.
Old May 19, 2008 | 03:57 PM
Charles R. Hill's Avatar
Owner of BHR
How come none of you idiots have told our friend here to...........
CHECK YOUR CLUTCH PEDAL ASSEMBLY!!
Search the issue and you'll find all you need to take the first step toward fixing it.
Old May 20, 2008 | 12:08 AM
mdw1000's Avatar
I'll snap his neck.
Get an AT.
Sorry, couldn't resist
Old May 20, 2008 | 03:14 AM
neXib's Avatar
Or a new mechanic
Old May 20, 2008 | 03:28 PM
staticlag's Avatar
The Professor
Drive in traffic. Find the busiest street you can and drive it every chance you get.
If pedal finesse is your problem you can try running or lifting weights. Making your legs stronger will help with controling the car.
Old May 22, 2008 | 12:58 AM
kersh4w's Avatar
Hit & Run Magnet
Originally Posted by mdw1000
Get an AT.
you mean get a sequential manual.
Old May 22, 2008 | 01:08 AM
imput1234's Avatar
I ♥ Drifting!!!
When street racing and drifting, downshifting I miss gears, sometimes don't shift properly, and feels stiff...
You could learn to drive.
Old May 22, 2008 | 06:40 AM
yushinrt's Avatar
what short shifter will do is make your shift shorter. it good to get, but i think practicing will be cheaper option
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
Frosty8
Sep 11, 2015 10:27 PM
