agency power pulleys
Old May 16, 2008 | 11:30 PM
VS8's Avatar
VS8
4 Cylinder Rotary
about how much would it cost to get these installed
Old May 17, 2008 | 04:07 AM
Jon316G's Avatar
Grasshopper
Simple to install yourself... don't waste your money paying someone else to install.
Just loosen tension from the drive belt (you'll see that adjusting the alternator's position is what applies/releases tension to the belt). Then remove the four bolts on the crack pulley and be careful not to damage/warp the eccentric shaft positioning plate that is behind it (a plate with "teeth" all around).
The AP pulley comes with a new belt, so just install everything in reverse order.
Old May 17, 2008 | 04:15 AM
Jon316G's Avatar
Grasshopper
This should help explain how to apply/release tension to the drive belt:
Old May 17, 2008 | 12:47 PM
VS8's Avatar
VS8
4 Cylinder Rotary
is there anything else i need to do
Old May 17, 2008 | 12:57 PM
Jon316G's Avatar
Grasshopper
enough said!
Just once its installed, start the car and watch the belt and pulley... make sure its not squeaking and the pulley is properly balanced (not wobbly). Do not apply too much tension, but you also don't want it too loose.
Old May 17, 2008 | 12:58 PM
You will likely have a difficult time getting the alternator pulley nut off...unless you have an impact gun....other than that it is straight forward
Old May 17, 2008 | 01:01 PM
mysql's Avatar
Doppelgänger
walmart sells a cheap impact gun for around $25. Worked fine for me.
Old May 17, 2008 | 07:59 PM
VS8's Avatar
VS8
4 Cylinder Rotary
but say i am not able to do this about how much would it cost me
Old May 17, 2008 | 08:31 PM
Probably get away with 1-1.5 hrs...so $100-120
Old May 17, 2008 | 09:48 PM
VS8's Avatar
VS8
4 Cylinder Rotary
do you have any more pics i can use to install the pulleys
Old May 18, 2008 | 09:05 AM
Jon316G's Avatar
Grasshopper
staticlag wrote-up a DIY that should be easy for you to follow:
https://www.rx8club.com/showpost.php...9&postcount=34
Old May 19, 2008 | 09:56 PM
LiL BenNy's Avatar
Bubblicious? DEF.
easy, trust me i even did my own...as for the impact wrench its not needed u just need a long breaker bar or something togive u leverage... hell i didnt wnana pay the 30 bucks for one and just used one of my old alluminum hockey shafts... worked like a charm!
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RXFEVER
Sep 11, 2016 02:51 PM
Trekk
12
Sep 25, 2015 03:08 PM
