Will 19" HP Racing HPR5 fit my rx8??
Old May 11, 2008 | 07:14 PM
Tharp691's Avatar
Hello, i just joined rx8 club and am very pleased with it. and just last week i got my rx8!
I absolutely love it but am looking for some new wheels. i saw a custom rx8 with these wheels on it but when i went to order them, it said these wheels would not fit!
do any of you know if these wheels would fit? and would the 19" wheelse fit under the fender correctly? and if so can i get lowering springs to go along with the wheels?
Thanks alot! --- Tyler
Old May 11, 2008 | 07:18 PM
lurch519's Avatar
www.evoperform.com
need a little more info
19X ?
offset?
what size tire are you trying to put on?
how low do you want to lower it?
Old May 11, 2008 | 07:21 PM
Tharp691's Avatar
im just looking to lower it enough so it doesnt look awkward.. so maybe 1 inch?
and the wheel width is 9.5 inch...
and for tires i want very low profile... any suggestions?
Old May 11, 2008 | 07:24 PM
lurch519's Avatar
www.evoperform.com
what offset are the wheels?
im dropped on the eibach springs with 19x9.5 and 255/35 19 rubber, but the offset is 40 which is a bit agressive so the rears are cambered a bit more than they should be accelerating tire wear.
Old May 11, 2008 | 07:28 PM
Tharp691's Avatar
its a 38 offset... but what size wheels do you suggest?? im looking for very low profile
Old May 11, 2008 | 07:30 PM
lurch519's Avatar
www.evoperform.com
19 x 9.5 will fit, even with the 38 offset, but when you lower it you will either need to roll t he fenders, or deal with very agressive camber in the rear
Old May 11, 2008 | 07:34 PM
Tharp691's Avatar
ohhh ok.. ic.. if i dont drop it do you think it would look too high?
lurch519's Avatar
www.evoperform.com
probably
Old May 11, 2008 | 07:40 PM
Tharp691's Avatar
okkk... thanks for the help.. and did you have to do anything to the fenders when you put on your 19's with the drop?
Old May 11, 2008 | 07:50 PM
lurch519's Avatar
www.evoperform.com
Originally Posted by lurch519
.................................................. .......so the rears are cambered a bit more than they should be accelerating tire wear.
hope that answeres your question
Old May 11, 2008 | 07:52 PM
Tharp691's Avatar
yea i get that.. but you didnt have to mess with your fender right?
Old May 11, 2008 | 07:53 PM
chrism's Avatar
Misfit Moderator TnC
in other words yes
Old May 11, 2008 | 07:54 PM
lurch519's Avatar
www.evoperform.com
no, thats why i said you would have to either roll the fenders or deal with agressive camber
Old May 11, 2008 | 07:57 PM
Tharp691's Avatar
ok.. icc.. not to be an annoyance but what does rolling the fender mean?
Old May 11, 2008 | 08:00 PM
lurch519's Avatar
www.evoperform.com
roll the inner lip in for clearance
Tharp691's Avatar
ohhh okk.. thanks alot!
F51
Aug 2, 2021 04:07 AM
Modified Dave
Sep 19, 2015 08:58 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
mazdamanda
Aug 17, 2015 11:44 AM
AussieGray
Jul 16, 2015 03:58 AM
