Need Help Installing Pulley Kit
Old May 11, 2008 | 05:42 PM
rxracer208's Avatar
I just bought a pulley kit at a car show this weekend and need some tips on how to install them can someone help me out thanks
Old May 11, 2008 | 06:20 PM
8 Maniac's Avatar
what pulley is it? how many are there? If you have brand name or pics that probably helps most.
not to thread jack (even though I am kind of, though might help OP too) Aftermarket pulleys should fit the stock belts, correct? I believe one of my belts is squeaking and might need replacing.
Old May 11, 2008 | 06:49 PM
SebtownRx8's Avatar
75shot55fueljets=GOBABYGO
You will need to buy new belts. I've got unorthodox pulley set took like 1 hour to install.
Pulleys are pretty straight forward to install, Loosen to Two Bolts located on the alternator, take off the main belt. loosen the AC Belt by loosening the bolt by the AC. And you'll need probably need air tools, the Alternator bolt is a real bitch to get off. the crank pully is easy and so is water pump. as for belt size i'd have to know what pulley set you got.
Attached Thumbnails Need Help Installing Pulley Kit-134_2125.jpg   Need Help Installing Pulley Kit-134_2126.jpg
Old May 11, 2008 | 08:21 PM
8 Maniac's Avatar
I just have the agency power pulley
Old May 11, 2008 | 09:31 PM
Jon316G's Avatar
Grasshopper
No... you should have received a belt with your AP pulley.... I did.
Old May 12, 2008 | 04:17 PM
rxracer208's Avatar
It is a Ralco RZ pulley kit and is the alternator and water pump pulleys
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
