Question about trunk opener..
Old Nov 13, 2003 | 10:14 PM
nt5k's Avatar
When you hit the remote button on the trunk release how high up does/should the trunk open?
Mine just pops up an inch. In other cars I've had the trunk would open all the way..
Anyone else?
Old Nov 13, 2003 | 10:17 PM
RX-GR8's Avatar
mine pops up an inch also.
Old Nov 13, 2003 | 10:36 PM
Genom's Avatar
Not so Super right now
It's only a release so yeah, it's just gonna pop open an inch. It's not motorized to open all the way or close by itself.
So, normal.
Old Nov 14, 2003 | 09:00 AM
eccles's Avatar
Prodigal Wankler
Originally posted by Qhris
My trunk opens only an inch or so as well. I prefer it this way - should it be raining (I live in Portland, OR) I don't get a trunk full of rain or bird crap if it's sunny.
The down side is that if you pop it unintentionally, you have no visual reminder to close it again. There is no "trunk open" light on the dash - I drove around for a day and a half with mine ajar once. The only indication that it's not closed is that the lights will not flash when you lock the car, which I thought was an alarm problem until I eventually discovered the trunk open.
Old Nov 14, 2003 | 09:24 AM
MyRxBad's Avatar
Fb's rock!
...and if it's pop's open accidentally (if it were to open all the way) no one walking nearby has a free look at the contents of your trunk and steal stuff.
Old Nov 14, 2003 | 09:32 AM
Chuck Clifford's Avatar
My problem with the trunk release, is the button is really hard to locate while sitting in the car. A little more visibility would have been nice.
Old Nov 14, 2003 | 10:05 AM
eccles's Avatar
Prodigal Wankler
There is a series of small braille-like bumps moulded into the button - I just feel for those.
Old Nov 14, 2003 | 10:11 AM
LesPaul's Avatar
When my CEL came on, I stopped, popped the hood and trunk and checked my oil (with the intention of getting a quart out of the trunk). My oil level was fine, so off I went. I then discoverd that when I pressed my fob the yellow lights did not flash to indicate the alarm was armed (although when I pressed a second time, the horn did sound). Anyway I thought the alarm was part of my CEL problem. It was not. Since I forgot to securely close the trunk, the alarm was indicating that the perimeter was not secure. Closed the trunk and the lights then worked as they should. My dumb.
The CEL turned out to be a thermostate problem.
Old Nov 14, 2003 | 10:27 AM
eccles's Avatar
Prodigal Wankler
My experience precisely, 'cept I didn't have a CEL.
Old Apr 28, 2004 | 05:34 PM
loco4rx8's Avatar
BSG 75
I know this is an ancient thread, but I wanted to thank you guys anyway.
I just used my trunk release button in the car and the one on the key fob last night, and they both worked. Then, today neither one would. I was stumped.
So, I came on this board, did a quick search, and boom - there's the answer. Check the disabler in the glove compartment, moron! Sure enough, somehow the trunk release had been turned off. How this happened, I have no idea. I didn't open the glove compartment from last night to this morning. Maybe I went over a big bump as I drove in to work this morning ... or something.
Anyway, thanks for the help - you guys are the experts and a very helpful bunch!
Old Apr 28, 2004 | 05:55 PM
Spin9k's Avatar
Momentum Keeps Me Going
Here's another variation - not a good one either. Pop and forget or pop unintentionally... and leave the trunk open that little bit - - then leave the car a day or so - no battery twice so far!
I just put compact booster cables in the back with the air pump.
Old Apr 28, 2004 | 06:35 PM
ptiemann's Avatar
maybe you didn't use the trunk opener since you had the airbag recall done?
My opener was disabled after the airbag recall (they work on the glove box there) and it took me a week to notice it.
-Peter
Old Apr 28, 2004 | 07:04 PM
moRotorMotor's Avatar
Rotary eXperimental-8
The only downside I see with the trunk not opening up all the way when you press on the key fob is if you were walking out of the store with your hands full. It's a little hard to open the lid without putting down the groceries or heavy object. Although I have read somewhere about the struts are suppose to be replaced for those with a spoiler installed. The new, more powerful struts are to compensate for the heavier lid and (correct me if I'm wrong) open it all the way. Mine only opens 1 inch and so I was wondering if anyone now still have this little problem?
Old Apr 28, 2004 | 07:06 PM
StealthTL's Avatar
Cool Trunk sucks...
Check out my 'trunk opener relocate thread'......
Factory trunk button relocate.
Bought a factory button from Canzoomer, moved it up where it belongs.
S
Old Apr 28, 2004 | 07:26 PM
livitup's Avatar
Twisties for 1000, Alex
I've got the factory spoiler (not the huge wing) and when I pop mine I only get a tiny bit of lift, not even an inch.
Mind you, it's not enough to re-close itself, but the lid rests on the latch after a pop. If they do come out with stronger struts it would be nice if they retro-fit us...
---A
Old May 19, 2004 | 09:04 AM
TreknMazda's Avatar
Love it! Keepin' it!
Has anyone noticed the trunk opening without pushing any buttons
At least three times in the last week, I have arrived at work and find the trunk is open.
When I unlock the car with the key fob in the morning, the only sound I hear is the door unlocking and the trunk does not. I don't hit any buttons while driving, and yet when I arrive at work the trunk is open. I have not noticed the same thing happening on the return trip, yet.
Old May 19, 2004 | 09:42 AM
Razpewton's Avatar
FREE ADVICE!
MY trunk opens up 1¼" neener neener :D
Old Nov 10, 2004 | 10:14 AM
ASO's Avatar
ASO
trunk Opens bvy itself
I'am experiencing the same behavior... I thought I was accidentaly rubbing the button next the the hood opener but it's not the case. I am puzzled.
Any news on your side for this ?
ASO
Black RX-8 GT
Old Nov 10, 2004 | 11:04 AM
TreknMazda's Avatar
ASO,
I realized that everytime the trunk was inexplicably open the LoJack Early Warning had been triggered. This ended up being due to a weak battery in the LoJack device on my keyring. For those not familiar with it, Early Warning is a direct notification to you that your car may have been moved without your permission/knowledge. (In other words, it does not recieve the LoJack signal from your keyring when the car starts moving.) This is separate from the standard LoJack signal that is triggered for police tracking after you report the theft.
It appears that when LoJack sends out the Early Warning signal, it also triggers the trunk. Replaced the battery and have had no reoccurance. So do you also have LoJack Early Warning?
Old Nov 10, 2004 | 11:16 AM
ASO's Avatar
ASO
I'have just installed a similar device on my car last week (in Canada, it's called Boomerang. Just got bought by Lojack). But I don't have the key chain device model and therefore I don't have and early warning signal switch. I suspect there is still a corelation with this.
I will check with my Boomerang installator for this.
Thanks again for your lead
ASO
Old Nov 10, 2004 | 12:01 PM
w0rm's Avatar
PUSHER ROBOT
I have been having the same problem with my 05. Trunk appears to be randomly opening- at first I thought I was accidentally hitting the release on the FOB but now I'm not so sure.
Old Nov 10, 2004 | 12:34 PM
ASO's Avatar
ASO
W0rm do you have a Lojack device ?
Old Nov 10, 2004 | 01:13 PM
ASO's Avatar
ASO
Had my Boomerang/Lojack instalator verify it's knowledge base (and call Lojack).
They found the problem. When they installed the module, they hooked up to the Trunk release cable for it's power feed. When Boomerang/Lojack does a remote random system verification, it triggers the trunk opener.
Having it fixed tomorrow.
Mystery solved.
ASO
WranglerFan
Aug 21, 2022 01:29 PM
nowakm99
Oct 9, 2015 07:10 AM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
yankeepicker
Sep 11, 2015 05:42 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
