Wanted: DIY for Brake Rotors & Pads
Old Apr 25, 2008 | 01:57 PM
Daemos's Avatar
I'm going to be doing Rotors and Pads tomorrow, I have the basic concept as I've done it on other cars, just want to see if anyone has a DIY to make it easier to follow.
I tried checking this link http://www.hi-impact.org/ryang/modify/modify.html but it doesn't work for me
Old Jul 15, 2008 | 05:39 AM
klittl06's Avatar
Anyone know of a working link?
Old Jul 15, 2008 | 06:00 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
I see you may have done search in the DIY section itself? Robin Yangs stuff got moved onto a different server. It is now at http://69.108.208.137/ryang/modify/modify.html It's actually a little weak, so since I'm stuck at home today, I'll see if I can find a better one.
Other than that I did find more in the DIY section.............although I did go look at the actual threads.
This link is to the DIY section and you can look alphabetically under brakes in the 2nd post, where I see at least two of them.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-section-category-alphabetically-101998/
Old Apr 25, 2009 | 01:08 AM
ZumnRx8's Avatar
RX8 & RX7 owner
i know this is an old thread but if anyone finds it, heres an awesome one
https://www.rx8club.com/showthread.p...=1#post2987754
Old Apr 25, 2009 | 01:11 AM
yep,
that covers it well.
Old Apr 30, 2009 | 11:56 PM
Doesn't work for me.
Old May 1, 2009 | 12:19 AM
wow,
that is to bad it was done well. and then it got crapped.
Old May 1, 2009 | 05:33 PM
Zepo.'s Avatar
Redlined Rotary = Sex
For the pads it's really simple, take the wheel off(duh), take the bottom bolt off the calipers and flip it up pull pads out and put new ones in. Not sure about rotors.
Old May 1, 2009 | 05:37 PM
Spinning Sushi's Avatar
I <3 Sushi
It's a good idea to resurface the rotor when installing new pads. There are two bolts (I believe they're both either 16mm or 14mm) on the back. Remove both of them and the whole brake caliper will come off, remove the alignment screws on the rotor itself (you don't need to put the screws back, they're there for manufacturing purposes) and then pull off the rotor. It's going to be hard to pull off the rotor because of heat and rust so get a rag and hammer the top of the rotor and it'll come right off.
Old May 1, 2009 | 06:37 PM
You don't need to pull them off. Just sand them a little bit on both sides then bed them in.
You can't turn rotors on the RX8. They are too thin from the factory.
Besides Renesis SE3p owns a Camary, so what does he know.
Old May 5, 2009 | 03:34 PM
JOLIET WANKEL's Avatar
Xboxgametag:Chafed Banana
Why can't I compress the rear brake pistons? The new pads for the rear are so thick that I can't put it back on. The front brake piston was a cinch. Channel locks squeezed it. But the rears won't budge. I've tried turning them too both clockwise and counterclockwise AND loosening the bleeder valve while turning it both ways and tried compressing it with channel locks some more. I'm working on the driver's rear right now btw. Somebody please help.
Old May 5, 2009 | 10:16 PM
raleighRX8's Avatar
hello, is this thing on?
They need to be turned clockwise in. It takes many turns to get them all of the way in. It doesn't seem like they
are going in because it is so slow, but be patient, you will see them going in slowly!
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-how-change-your-rear-brake-pads-172382/
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Road Cone
Nov 6, 2015 01:52 PM
yankeepicker
Sep 11, 2015 05:42 PM
