K&N Drop-in. 1 MPG?
Old Apr 21, 2008 | 04:12 PM
Docj78's Avatar
K&N Drop-in. 1 MPG?
Not expecting any power improvements, but is the K&N drop in actually at all worthwhile potentially for maybe a MPG gain and/or throttle response??
I've read a handful of threads here, but wanted to ask about just the drop in for now, and it's worth--or lack of.
Also, what are some aftermarket alternatives to the K&N? I'd rather run a "dry" filter vs. dealing with the cleaning and re-oiling of the K&N. Yup, that's lazy, I know.
Old Apr 21, 2008 | 04:15 PM
expo1's Avatar
He's as bad as Can
And how can you scientifically prove a 1 MPG gain?? A couple days of a tail wind can get you that.
Gish's Avatar
1 MPG is way, way too subjective. Changing your driving style by just a little bit can give bigger differences than that...
Old Apr 21, 2008 | 04:20 PM
Docj78's Avatar
I got the 1 mpg "idea" from some of the other posts here. I agree that 1 mpg is all but impossible to accurately and consistently measure. So I guess the question should simply ask whether the Drop-in alone is worth $50.
I had all the bolt ons on my truck, and did not feel much if any gains.
Old Apr 21, 2008 | 04:28 PM
expo1's Avatar
He's as bad as Can
I have one I only used at the track (HPDE), Maybe has 5,000 miles on it. You can have it for $30.00 shipped.
Old Apr 21, 2008 | 04:31 PM
Docj78's Avatar
What are you running now? Back with oem? What about the ever subjective "throttle response"? I'm leaning towards not wasting my money..
Old Apr 21, 2008 | 04:36 PM
expo1's Avatar
He's as bad as Can
I picked up a used Racing Beat intake, it uses a custom K&N filter. Since at the track I'm over 7,000 RPM all the time I wanted the " better " flowing K&N, at least in theory. I would put in the K&N a day or two before the track weekend, take it out when I came back. MPG was never a goal. PM if you want mine, I send you a paypal address.
Old Apr 21, 2008 | 05:00 PM
yea, 1mpg will be impossible to prove. Slightest change in driving can cause a greater fluctuation then that.
Old Apr 21, 2008 | 05:58 PM
05rx8mazda's Avatar
B.I.G
dont use those k&N filter sure they give you more air flow but they have also been proven to allow more dirt into your engine.. be advised!
read up on it if you dont believe me
Old Apr 21, 2008 | 06:38 PM
imput1234's Avatar
I ♥ Drifting!!!
I think you need to read up.
Old Apr 21, 2008 | 06:52 PM
hakuna matata!
i got a 40 mile difference between the tank before and after i installed my filter.. random but true.
Old Apr 21, 2008 | 08:06 PM
savedsol's Avatar
Carbonormous
I have one in my 8 and one in my MPV. My MPV mileage tanked after installation. Bought a can of MAF cleaner and sprayed the snot out of it. NEVER had better mileage. Didn't notice much difference in the 8 except that on startup it seems to "breathe" in easier. If you want a low maintenance dry filter stay stock.
The fact that you're starting a thread instead of continuing to post in ones you've already found needs to be called out.
Old Apr 21, 2008 | 08:14 PM
StealthTL's Avatar
K&Ns get better at filtering as they age/get dirty.
When fresh new and oily they filter less dirt out than a typical paper filter.
....I prefer to let a filter do the filtering, rather than the "layer of dirt".
AND they will put a film of oil on your MAF sensor, so lose/lose.
S
Old Apr 21, 2008 | 09:18 PM
Docj78's Avatar
Actually, as I stated in the first post, I have read some other info here on this subject and was only looking for a few specific answers regarding just using the drop in filter.
It's VERY time consuming reading all the way through several threads only to finish with a remaining question. Now I will admit that I've been a bit of a post ***** today and lately. I suspect that most people here are/were when they just joined and/or just got an 8.
Can I be called back in now??
Old Apr 22, 2008 | 07:18 AM
savedsol's Avatar
Carbonormous
Posts don't conclude. I was simply stating that you should have tagged these questions at the end of an existing K&N thread. You would have everyone already subscribed to that thread get an email regarding the update.
Old Apr 22, 2008 | 06:09 PM
hakuna matata!
i gained 1 mpg by getting rid of my spare tire!!
Old Apr 22, 2008 | 08:22 PM
DavidR's Avatar
WranglerFan
Aug 21, 2022 01:29 PM
yapakanichi
11
Sep 23, 2015 02:14 PM
CMRine04
Jul 29, 2015 02:07 PM
MarkW
Europe Forum
95
Apr 6, 2004 04:48 PM
pcorsaro
Aug 27, 2003 09:33 AM
