Wiring info request
Old Nov 10, 2003 | 07:25 PM
DisneyDestroyer's Avatar
Careful, I bite!
Wiring info request
Hi, I'm getting an alarm put in the vehicle, and they need to grab info from the tachometer wire - but they can't find it. Also, they tried talking to the local Mazda dealership, but they also didn't have the info.
Does anybody have any schematic info they can post / scan / e-mail that would help?
Thanks.
-Nick
Old Nov 12, 2003 | 04:59 AM
canzoomer's Avatar
Forum Vendor
There IS no "tachometer wire"
You can derive it from one of the plug coilpack trigger wires, and multiply by two.
There are 4 plugs. 2 per rotor. One leading and one trailing.
On the ECU connectors pugs, on the 28 pin plug, the lower left connection, with the white wire is the front rotor, trailing coil trigger. The blue with orange wire above that is the rear rotor, trailing coil trigger.
next to these ( inboard one wire), are the leaading coil triggers. yellow/green and green wires.
Old Nov 12, 2003 | 12:44 PM
Careful, I bite!
Cool, thanks for the info.
Old Nov 12, 2003 | 07:24 PM
oosik's Avatar
I'm a n00b....what does tach have to do with the alarm?
thx
Old Apr 14, 2004 | 08:55 PM
Kevo's Avatar
3.2 Liter Inline Sex
canzoomer - i guess i don't quite understand exactly what the remote start is supposed to detect through this single "tach" wire that is hooked to the trigger(s). if i knew that i could prolly work through it myself and not have to be a pest. essentially, i was just going to hook it up to one of the trigger wires and see what happened.
i don't necessarily need the answer, but can you maybe give me a clue as to what exactly you meant by "derive it and multiply by two."?
Old Apr 14, 2004 | 09:30 PM
RX-8 friend's Avatar
The coil trigger wires come from the PCM. It puts out a +3V 5 mS pulse. To get true RPM you need to multiply by two, or add the pulse from both rotors (leading or trailing). If you are just detecting "engine run" (I suspect that is what that wire is for), you don't need to worry about that, just use one trigger wire. Put a diode in series and a resistor. Try 10K to start. If it doesn't trigger the unit you are installing, try dropping the resistance value by half. I wouldn't go any lower than that. We use 1N4148 diodes.
Old Apr 15, 2004 | 09:36 AM
Kevo's Avatar
rx-8 friend is a friend indeed! thanks for your assistance. i will give it a shot and report the results. kevo
Old Apr 15, 2004 | 12:37 PM
Careful, I bite!
I now understand that the CZ unit will be coming specifically with a tach output (according to a post from Canzoomer). Any info on the format for this interface, so my alarm installation guys can start working on it?
Old Apr 15, 2004 | 07:25 PM
The tach output is a pin which has, coincidentally, a diode and resistor from each rotor leading ignition output, tied to the pin. It is a true tach output (RPM=true RPM). With a high impedance input to whatever you connect to it, you should see about +2.1 V 5 mS pulses. It uses 10K ohm resistors. The rotary gives you a pulse rate just like a 4 cylinder engine, so you get two pulses per rotation.
Old Apr 15, 2004 | 11:42 PM
Kevo's Avatar
sweet success! tach was detected with a IN4148 diode and 10k resistor in series hooked to a single coil trigger. the transponder bypass installed without a hitch and remote start is up and running. now i just have to find the factory arm/disarm wires that don't also fire the door locks and i am in business.
thanks again rx8-friend and canzoomer...i couldn't have done without you guys! kevo
Old Apr 18, 2004 | 05:09 PM
Kevo's Avatar
see the following thread...
https://www.rx8club.com/showthread.p...threadid=25928
RXFEVER
Aug 29, 2018 10:14 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
