can you turn off check engine light by unplugging the battery for an hour?
Old Apr 9, 2008 | 02:38 PM
rx8m04's Avatar
does anyone know if you can turn off the check engine light by unplugging the battery for an hour? i had a spark plug issue ......so i changed those but now i just want to get that enginge light off.
Old Apr 9, 2008 | 02:39 PM
shaunv74's Avatar
Power!!
Are you sure that solved the problem? I would go to an autozone and pull the code to find out what the problem is. When you fix a problem the CEL should go away.
Old Apr 9, 2008 | 03:07 PM
rx8m04's Avatar
actuall i had it at a dealer and they said i needed new plugs but then they wanted to charge me 300$ to do it so i just got out of there and ordered them myself and put them in. everything is good to go now just that light is on. i went to advanceauto today and they didnt have a CAN scanner only OBDII. so no help there but one of my freinds said to just unplug it for an hour and then it should go away.
Old Apr 9, 2008 | 03:10 PM
staticlag's Avatar
The Professor
unplugging it does make it go away.
Old Apr 9, 2008 | 03:12 PM
Butch Brown's Avatar
disconnect both + _ cables from battery then touch them to each other then reconnect to battery. After you start your car you will need to turn steering fully left then fully right, turn off ignition and restart, that will clear the TCS light.
Old Apr 9, 2008 | 03:29 PM
rx8m04's Avatar
i will try just unpluggin it and then if that doesnt work i will try what you said.....what does turning left and right do and why would i have to touch the +- together. im not doubting im just interseted. im sure there are different ways to do this.
Old Apr 13, 2008 | 05:18 AM
BoosTED's Avatar
Turning the wheel full lock left and then right recalibrates the dynamic stability control.
Old Apr 13, 2008 | 08:29 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
ANYTIME you unplug the battery you will have to do this reset or you will get the DCS/TCS lights. Turn car to on(not start), turn wheel all the way to right, then all the way to left, then key off, then you can start as normal.
Old Apr 13, 2008 | 09:33 AM
this op failed.
Old Apr 13, 2008 | 12:02 PM
Go48's Avatar
Rx-8 Owners Manual:
"NOTE:
If the battery is disconnected, the DSC
will be inoperable. In this case, the DSC
OFF indicator light flashes and the
TCS/DSC indicator light illuminates.
To make the DSC operable, do the
following procedure.
1. Turn the ignition switch to the ON
position.
2. Turn the steering clockwise fully,
then turn it counterclockwise fully.
3. Make sure the DSC OFF indicator
goes off.
4. Turn the ignition switch to the OFF
position, then turn it to the ON
position again.
5. Make sure the TCS/DSC indicator
light goes off.
If the TCS/DSC indicator light and the
DSC OFF indicator light remain
illuminated even after turning the
ignition switch to the ON position,
consult an Authorized Mazda Dealer."
Old Apr 13, 2008 | 06:51 PM
BoosTED's Avatar
It works either way.
Old Apr 14, 2008 | 07:30 AM
rx8m04's Avatar
Thanks everyone!
Old Apr 14, 2008 | 10:01 AM
Spinning Sushi's Avatar
I <3 Sushi
You made two threads with the same title and asked the exact same question...
https://www.rx8club.com/series-i-tech-garage-22/can-you-turn-off-check-engine-light-unplugging-battery-hour-142876/
Old Apr 14, 2008 | 10:02 AM
I <3 Sushi
Oh, I forgot to mention that you also posted in the wrong section of the forum....
Old Nov 21, 2009 | 07:36 PM
RX8 Newby's Avatar
You guys are great. I have been trying to figure out how to get those two lights off!
vapor2
Nov 3, 2020 03:38 PM
akagc
Aug 11, 2015 07:07 PM
Ajmurphy85
Jul 30, 2015 07:51 AM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
