Cold Air Intake For The 8...
Old Nov 6, 2003 | 03:19 AM
im pretty sure others have seen this pic before but i thought i'd share it anyway...
Old Nov 6, 2003 | 11:06 AM
Tamas's Avatar
Registered Lunatic
That's cool but the fact that you have to remove your entire front bumper in order to clean the K&N filter doesn't appeal to me.
Now I know some people will say that it's a piece of cake to remove the bumper, takes five minutes, blabla... but this still bothers me. Removing a bumper is usually NOT that easy... I did it on other cars and it was never fun.
Old Nov 6, 2003 | 12:06 PM
edzrx8's Avatar
Re: Cold Air Intake For The 8...
WHO MAKES IT/Price?/HP Gains
Old Nov 6, 2003 | 12:38 PM
said7's Avatar
Id imagine you can take the filter off without removing bumper. Just reach up in the grill.
Old Nov 6, 2003 | 12:44 PM
rabinabo's Avatar
They said that they've changed the design of that intake. This one is a prototype.
Old Nov 6, 2003 | 12:51 PM
rabinabo's Avatar
Check out their website. They've added some new mazdaspeed look-alike parts, like th e front and the adj wing, as well as a cf hood.
Old Nov 6, 2003 | 07:14 PM
mikeb's Avatar
100% Italian
nice pic
they are coming out with tons of stuff
the short arm intake is 260 with hp gains of 6
Old Nov 6, 2003 | 09:09 PM
Originally posted by mikeb
nice pic
sweet thanks mike...umm do you know if the cold air (longer tube) makes more power??
Old Nov 6, 2003 | 11:00 PM
mikeb's Avatar
100% Italian
no Im not sure
Old Nov 6, 2003 | 11:25 PM
Nemesis's Avatar
Cool
Go to rotaryextreme.com to get pic's and info.....
Old Nov 8, 2003 | 12:29 AM
shadowcougar's Avatar
A longer tube doesn't give you hp.
A cold air intake increases hp by lowering the air temperature that flows into the engine. Lower temps = more power as a rule of thumb.
However, design on the intake is important, as you want to optimize flow, so a design with fewer or smooth turns is usually better.
Hope this helps.
Gus.
Old Nov 8, 2003 | 12:32 AM
FYI same concept of flow is the usual rule of thumb for exhaust. The fewer, or the less extreme, turns are in the exhaust pipe, the better the performance. Thats why mendrel bent pipes are the best option...
edit: depending on engine design, true duals are optimal.
Old Nov 8, 2003 | 12:04 PM
Shocka's Avatar
WHAT.... YEAH... OK!
i think i might go for the short arm, but i wanna wait for others to come out and some reviews as well.. plan is to buy parts during the winter when i dont go out much and put it in the car during the spring.. so i wont have time to go out instead ill play with the car :-)
Old Nov 8, 2003 | 02:31 PM
Hope this helps.
Gus.
not intirely true...the whole purpose of the cold air intake (longer tube) is to grab colder air from a different place other than the hotter air the engine produces..."dyno proven (well not on the 8 yet") a longer tube does grab more colder air opposed to the short ram where it grabs hotter air from the engine bay..but if the tube is not designed correctly,like you said..the longer tube is useless...
Old Nov 8, 2003 | 06:39 PM
Maybe you misunderstood me... The length of the tube itself is not the reason for the hp increase, but the colder air is. All I was saying is that the CAI works by getting air at a lower temp...
I basically said what you said in a different way.
It just seemed that people had the misconception that the length itself was the major factor...
Having a choice between CAI and short ram, I would lean torwards a CAI. However at this time I would wait and to see all the different designs that will pop up for the 8 before I got anything...
just my .02 cents.
Gus.
WranglerFan
Aug 21, 2022 01:29 PM
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
