Trunk Space for 15's
Old Mar 15, 2008 | 01:14 PM
NavyJoe's Avatar
Trunk Space for 15's (UDATED w/ 12's)
I'm looking to install my Kicker 15" Solobarics next weekend, problem is, the box I had them in is way too big for the trunk. I have like 2 ideas, but i constantly hear people's comments on the different ideas and I can't decide. Let me run them by you guys and tell me what you think.
2 SUBS, 1 BOX
One of the ideas is to make a perfect fit box to cover the entire trunk and place the subs facing up. Problems: The box would be hard to build/install due to lack of space in trunk opening. The bass would bounce right off the trunk lid and possible back to the sub. The box would have to be tall to cover the magnet depth.
3 BOXES, SUBS FACING INWARD.
This is the one I like the most. Build a 3 piece box. The boxes would then be connected together inside the trunk. The subs would face inward (magnet on the outside). The center box would be hallowed out with the amp inside with neons. The box would have a plexiglass window on it. Problems: The boxes for the subs would be huge for airspace allowance unless I made it ported.
I like option two. If I take my time in preparing the box, and come up with a nice idea first. I think it would look nice. Here's the ideas:
Sub Box (2)
Red Carpet
Subs facing inward
Amp Display Box
Black Carpet
Red Neons (w/ Pulsate box)
Display opening shape of Rotary
Few questions:
1. How do subs sound when reversed?
2. Do reversed subs sound ok w/ ported box?
3. Is this feasible?
4. Do you think it will look good if done right?
EDIT: SEE NEW POSTS
Old Mar 15, 2008 | 01:31 PM
RWagz's Avatar
Piston-free 07.11.2007
I have like an idea that this is not a great idea in a light sportscar. Let's run with it anway...
2 SUBS, 1 BOX
Yes, the limited space above the subs will decrease output. Also your trunk lid will rattle like crazy, may even flex.
Ported boxes are bigger, not smaller. This design idea is great for that bling bling look, which is obviously what you're going for. Not sure if you have enough space for inverted subs though.
Sub Box (2)
Red Carpet
Subs facing inward
Amp Display Box
Black Carpet
Few questions:
Allowing for proper enclosure size and all the other things you want to locate in the trunk, it's going to end up looking overfull, stuffed in. Never mind the effect adding 4-500 lbs of equipment to your trunk is going to have on your handling.
Idea #1 is closer to "possible" than #2.
Old Mar 15, 2008 | 02:07 PM
NavyJoe's Avatar
I know fiberglass can be used to make speaker boxes, is there any advantages/disadvantages to using Fiberglass? I know it's way lighter, but will it last the beating that two solobarics will bring? I loved my Solobarics in my Cav and want it in my 8. How much bigger does the box have to be for inverted subs, or is it the same?
Old Mar 15, 2008 | 02:09 PM
WikkedOne's Avatar
Deals on wheels
Let my start by saying that putting 15"s in the 8 is ridiculous. Due to the size of the car and the trunk you're going to get much better performance from one 12 or 2 10"s - or maybe 2 12"s if you do it right.
I think i've seen a 1 or maybe 2 different 15" setups, they've both been single setups and they filled the entire trunk with the sub facing upwards.. at comp I think they only got about 125 DB - there just isn't enough airspace.
whatever you do, remember that the opening of the trunk is only 13" - so unless you want to built it inside your trunk it can't be any thicker than 13"
Old Mar 15, 2008 | 02:12 PM
NavyJoe's Avatar
The thing about solobarics are that they don't need much airspace. The setup you've seen, did they use Solobarics or a different brand?
EDIT: The 15 needs a minimum of 1.5 CU FT. I would up it alittle just to make room for the power of my amp. So the box would only need to be 1.5 x 1.5 x 1 (3 CU FT).
Old Mar 15, 2008 | 02:14 PM
WikkedOne's Avatar
Deals on wheels
https://www.rx8club.com/series-i-interior-audio-electronics-24/calling-all-soundstreamers-104483/
Old Mar 15, 2008 | 02:37 PM
DeViLbOi's Avatar
The devil made me do it
So what year Civic did you own before you picked up an RX8?
I mean seriously...this is just a stupid idea. Forget about the whole ungodly loud unbearable sound that will be in your car, and all the weight you will have in the back end, why would you want your car to rattle that bad? You do realize that your audio setup is going to weigh almost twice as much as your engine right?
WikkedOne's Avatar
Deals on wheels
first of - that box you just mentioned is only 2.5 Cu/Ft
second - try to picture those dimsions in your head, where would you put 2 15" subs? one on the front and one on top? basically 2 15's take up a MINIMUM of 34" if they are side by side (with the mounting ring and everything takin into account)
This should help you a little with your design - I drew the back of the trunk (the part just behind the rear seats) and stopped before the trunk well.. but you can get an idea of what you're working with
https://www.rx8club.com/series-i-interior-audio-electronics-24/here-trunk-dimensions-subwoofer-design-89366/
Old Mar 15, 2008 | 02:40 PM
DeViLbOi's Avatar
Isn't that 2.25 Cu/Ft?
Old Mar 15, 2008 | 02:49 PM
WikkedOne's Avatar
Deals on wheels
18 X 18 X 12 = 3888
3888 / 1728 = 2.25
I stand corrected.
Old Mar 15, 2008 | 02:50 PM
NavyJoe's Avatar
Yeah, sorry it's early here. Anyway, Wikkid One put it in perspective with the trunk dimensions. I guess I'll have to sell off my 15" and get what? Do you guys recommend 10" or 12"? I want Solobaric. So what do you think?
Old Mar 15, 2008 | 02:54 PM
DeViLbOi's Avatar
Depends on what you are listening to really. If you are listening to rap music the 12's are better...if it is rock I have always felt that 10's were better.
Old Mar 15, 2008 | 03:08 PM
WikkedOne's Avatar
Deals on wheels
I win! Yay!!!
if you want easy and good options there are 2 main ones -
I have 2 10"s personally... and still have enough trunk left for all of my groceries..
they are faster, and better for thumps in music, like a bass drum
12's are better for rumble.. mainly for rap music..
spend some time searching around here you will find alot of different setups and some really cool stuff!
here is mine for starters
https://www.rx8club.com/series-i-interior-audio-electronics-24/corksport-avic-z2-experience-review-rest-my-alpine-system-121032/
This is the easy and cheap solution for most people on this forum
http://cgi.ebay.com/Mazda-RX8-RX-8-S...QQcmdZViewItem
Old Mar 15, 2008 | 03:20 PM
NavyJoe's Avatar
I listen to both rap and rock, but mainly rap/r&b. So I want hit. I remember when the install on my Cavalier (not Civic...lol) was done and the guy drove it around, it was setting car alarms off across the street. Got alittle chub from that...lol.
Old Mar 15, 2008 | 04:09 PM
DeViLbOi's Avatar
The smaller the cone...the better response you will have...so the cleaner "hit" you will have. The larger the cone...the better the frequency response you will have...so you get a deeper tone. If you want something to rattle your bones you need a 15"...if you want to hear it more than feel it you need a 10".
Old Mar 16, 2008 | 11:33 PM
NavyJoe's Avatar
Alright!!!! Went to the store where I bought everything and the guy took my 15 L7's and gave me 12 L7's and a LOC. So I have 2 Kicker Solobaric 12" L7s. Anyone want to help me with the install ideas?
Old Mar 17, 2008 | 12:20 AM
staticlag's Avatar
The Professor
Its probably easiest to build the box to fit then install it through the rear seats.
If you wanted to sacrafice your trunk you could just put foil on the entire thing and lay fiberglass over it, reinforce one area, level it and cut out a hole for the sub.
Old Mar 17, 2008 | 12:51 AM
RWagz's Avatar
When making fiberglass enclosures you don't glass a seamless sealed box then cut holes for the speaker. On load bearing dimensions you need to brace (use scrap MDF) and it's common to pre-cut baffle rings for the speaker and form them into the box as you're glassing. Make sure the speaker will clear the hole before it's mounted in fiberglass. I also like to make a speaker depth guide from a few scraps in the shape of a 'T' - this way you can position the baffle and test to see if the speaker will have enough depth by placing your guide flat on the outside of the hole. If your speaker is vented at the rear add extra clearance.
For nice curves use wire (unraveled wire coat hangers, etc) and a light, stretchy material (old white t-shirts, grill cloth). Build up basic shape wire-frame style and stretch cloth over it. Apply fiberglass and enjoy.
Lastly, expect to spend a lot on a custom fiberglass enclosure. If it's your first time using fiberglass, a subwoofer enclosure is not a good first project.
Old Mar 17, 2008 | 02:34 AM
NavyJoe's Avatar
How many layers of fiberglass would I need? My idea is to use the box I had my 15's in for "spare wood" and build a frame with it. Use the t-shirt method (i've heard that before) to build the design and then lay fiberglass. So how many layers/thickness should i make the box? Do you need my amp specs to give me a good answer?
cliffkemp
Dec 24, 2024 10:48 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
GK1707
Sep 27, 2015 07:33 PM
Rote8
Sep 22, 2015 03:43 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
