stock shift knob question
Old Feb 17, 2008 | 11:02 PM
JGR4444's Avatar
GR
stock shift **** question
i searched the site for about an hour and i couldnt find a thread on this probably because its dumb and nobody cared to start one... i have been trying for about two days to screw my shift **** back on so its straight and i cant get it lined up.... i know it sounds dumb but is there a trick to screwing the **** back on so that its pointing the way it should be? I always get it to be 90 degrees to the right of where it should be... dont make fun haha
Old Feb 18, 2008 | 03:40 PM
JRichter's Avatar
Void Where Prohibited
I haven't removed mine or anything but the hand grip stays somewhat loose to where I can rotate it perpendicular to the center console while still tight enough to were it won't rotate freely. If this is what you mean...
Old Feb 18, 2008 | 03:52 PM
mikesol's Avatar
gas kilometerage
Is it really hard to turn it a bit further? And still really loose when you turn it the other way to line up?
If so, you may want to do something like drop some sort of adhesive into the shift **** (turn it upside down, natch) so that it won't screw on quite as far. May take some turning to get right. Choose a good glue that becomes fairly solid when it dries and one that can stand a lot of heat cycling without becoming adhesive again.
Old Feb 18, 2008 | 03:57 PM
EdwardsB's Avatar
Registered RX-8 User
not sure if its possible, but did you cross thread it when put it back on?
Old Feb 18, 2008 | 04:17 PM
boffam's Avatar
Rotating eccentrically
Only 270 more degrees to go... I'd clamp it with visegrips and a rag and keep turning. If all else fails, get a Voodoo **** like mine...it's spherical.
Old Feb 18, 2008 | 04:26 PM
Jasonawojo's Avatar
I thought that, or something is stripped. I've noticed that mine remains somewhat loose in the fully tightened, straightforward position.
Old Feb 18, 2008 | 06:36 PM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
Im thinking stripped too the threading could have been diff you really have to check that with the *****
california style
Apr 29, 2020 12:30 PM
Billy Marcial
Mar 1, 2018 06:50 AM
yapakanichi
Aug 17, 2015 09:47 AM
akagc
Aug 11, 2015 07:07 PM
skydemon
Jul 23, 2015 01:51 PM
