Check e light midpipe?
Old Feb 12, 2008 | 10:42 PM
wassup_nuthin's Avatar
Ok so i have my midpipe in today and the check e light came on. now i know it will come on, but when i go wot the engine light blinks, is that normal?? the car runs fine but the engine light will blink when i accelerate hard w/ it.
Old Feb 12, 2008 | 10:43 PM
chickenwafer's Avatar
Nope
No, blinking indicates a problem. Pull the code, you probably have a misfire.
Old Feb 12, 2008 | 10:45 PM
hmmm.. ok well what do i do w/ a missfire??? how to fix?
Old Feb 12, 2008 | 10:47 PM
Nope
Possibly your ingition coils are on the way out. Search for "misfire", it will come up with a bunch of results
Old Feb 12, 2008 | 10:48 PM
ok well ill pull the code tom. but the car runs very well no idle prob. and accelerates really good. but like i say it blinks when i get on it... is missfire bad w/ the 8?? not to sound newbi but im not for sure what you mean like a spark plug is bad or what
Old Feb 12, 2008 | 10:49 PM
oh ok well in that case , i orderd mazsport ignition about a week and a half ago so im good. but would my midpipe cause it to missfire b/c it didnt befor i put it on. just right after it was installed it started to blink
do i need to be worried about dirving it. *hurting the motor*
Old Feb 12, 2008 | 10:59 PM
I know my car's condition, it happened to me. No concern.
For you, I dont know, dunno ur car's condition.
Old Feb 12, 2008 | 11:01 PM
Nope
Just saw your other thread and noticed you installed a new crank pulley. That is more than likely the culprit here.
Did you reset your eccentric shaft profile?
Old Feb 12, 2008 | 11:20 PM
^ yep what chicken said.
Old Feb 12, 2008 | 11:27 PM
ok i dont know if your messing w/ me w/ the hole profile w/e. what is it how do you do it?? lol
Old Feb 12, 2008 | 11:49 PM
Nope
Tap the brake pedal 21 times as fast as you can and punch a midget in the face. The oil pressure gauge will sweep and that will reset your e-shaft profile sensor.
Old Feb 13, 2008 | 12:26 AM
ok i got you never heard it called that but its more like 8 times w/ in a few seconds but ok thanks. imma do that and unplug the bat for awhile
Old Feb 13, 2008 | 12:32 AM
DOMINION's Avatar
I don't buy Kool-Aid
Wink
What Chickenwafer ment to say was turn your key to the on position then hold the trip reset button and pump the brake pedle as fast as you can till the oil pressure gauge sweeps to the middle. Then your good
Old Feb 13, 2008 | 11:29 AM
mmats69's Avatar
93.5 octane
https://www.rx8club.com/series-i-tech-garage-22/ecu-clear-reset-27548/
Read post #3
Old Feb 13, 2008 | 01:08 PM
hey guys just an update reset the ecu and did the brake tap. and everything works great no check engine no blinking. thanks guys!!
Old Feb 13, 2008 | 04:31 PM
mmats69's Avatar
93.5 octane
good deal. keep an eye on it just in case
xAgyex
Jun 3, 2026 03:47 PM
yapakanichi
Aug 25, 2015 01:24 PM
Olib1988
Aug 20, 2015 10:34 AM
akagc
Aug 11, 2015 07:07 PM
marc2820
Jul 26, 2015 10:47 PM
