wheels squeaking?
Old Feb 7, 2008 | 02:20 PM
philsbluerx8's Avatar
wheels squeaking?
i searched but no results about wheels squeaking
yesterday i put my new rims and tires on and they 18x8.5 +38 with 245/40 R18 all around. After i went out from the shop, the front wheels sounded like squeaking. i dont think it was about the breaks cuz i just replaced my hawk ceramic break pads about 4k kms before. then what should it be? anyone could give me some ideas?
Old Feb 7, 2008 | 02:42 PM
c41250n's Avatar
did it squeak only when you're on your brakes?
or does it squeak when you're going slow?
Old Feb 7, 2008 | 06:20 PM
TopGear8's Avatar
mkuhnracing.com
Take the wheels off, then put them back on. Might work..
Old Feb 7, 2008 | 09:50 PM
Check the tires. You may be rubbing on the outside or The inside may be scraping the SC.
Old Feb 7, 2008 | 11:15 PM
make sure the lug nuts are properly tightened
Old Feb 8, 2008 | 11:44 AM
i used stock ones but they said its a little bit too tight, but it fit very well;
its squeaking when low speed.
and they found out that my left tie rod is loosened. but i dont know what exactly it means but i will let the dealer check it out.....
i will also try remove and put them back.
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
