pics of my spark plugs, what does it mean?
Old Jan 29, 2008 | 02:30 PM
Jeromie's Avatar
what exactly does this mean? i know that the plugs can tell u a lil about how ur engine is running. i forgot what means what tho...
these plugs should only have about 15000 miles on them since i got the recall done.
i redline the car regularly, any ideas?
Old Jan 29, 2008 | 02:42 PM
Bit of crap...but they aren't fouled or anything....I'd just put in a new set and don't worry about them.
I would suspect that you do a lot of city type driving????
Old Jan 29, 2008 | 02:45 PM
Jeromie's Avatar
eh.. i do some city driving... and yea i got new spark plugs, coils, and racing beat wires....
Old Jan 29, 2008 | 03:00 PM
Juice's Avatar
I made some poos
Typically white plugs usually mean you are running too lean. Black means too rich. A brown/tan color is what you want. Yours look about right for the mileage.
Old Jan 29, 2008 | 03:06 PM
Should be good to go...just be careful when installing the wires.......
either do them one at a time ( difficult to figure out which wire to use)
or label them..compare lengths...and install from the coil position....
FL FT RL RT from front to back
The rotor housings are marked by the plugs
Cheers
Old Jan 29, 2008 | 03:16 PM
you think yours look bad? Try to look at mine ! just posted yesterday.
Old Jan 29, 2008 | 04:43 PM
diabolical1's Avatar
i'm the undead
they're not THAT bad. that's what mine looked like when i changed them a couple weeks ago. i do mostly highway driving and i don't redline my engine every chance i get simply because i'm out of pocket right now. i premix and do regular maintenance and my car runs fine - good power, decent mileage.
Old Jan 29, 2008 | 05:08 PM
DarkBrew's Avatar
Extraordinary Engineering
Your plugs look good. (for a rotary)
Link to my plug thread
Old Jan 29, 2008 | 05:17 PM
Nubo's Avatar
Lubricious
They look ok from what I can see. The most important thing is the color of the center insulator. Can't see it in all the plugs due to shadow, but the ones I can see are "tan" color, which is good. A little pinkish, which could be MTBE (gasoline additive) or maybe just the camera. The crusty stuff on the ends is mostly because our engines consume oil. Plugs pulled from a rotary will usually look gnarlier than from an equally healthy piston engine, due to those deposits. They don't hurt anything. Again, it's the center insulator that is the key. It's what keeps the spark jumping across the gap instead of back down inside the plug.
Old Feb 8, 2008 | 04:03 PM
wwwnika's Avatar
8<RX>8
smell any gasoline?
Old Feb 8, 2008 | 04:28 PM
ZoomZoomH's Avatar
Mulligan User
all these spark plug pic threads somehow reminds me of fortunetellers reading tea leaves, lol
Old Feb 8, 2008 | 04:39 PM
brown is okay, black is bad. My leading plugs looked worse then 5,000 months after the recall work.
RevMeHarder
Jun 1, 2026 02:30 PM
TeslaMSI
Dec 10, 2015 01:10 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
DVerdeyen
Sep 13, 2015 11:19 AM
