yellow/brownish sticky formation during oil check
Old Jan 28, 2008 | 08:23 PM
ashwins's Avatar
I pulled out the dipstick to check the oil level in the car and noticed yellowish/brownish formation on the dipstick. The car was sitting for about an hr at around 40 F temperature ? I was suspecting that it was oil kind of freezing? Not sure
Old Jan 28, 2008 | 08:25 PM
TopGear8's Avatar
mkuhnracing.com
Just search around and you will find that everybody has experienced this. It's just a condensation build up. It is not a problem. Just happens when it gets cold. Just clean it off, stick it back in, and it should be fine. Nothing to worry about.
search oil and foam. see what you get.
Old Jan 28, 2008 | 08:29 PM
TopGear8's Avatar
mkuhnracing.com
I'll make it easier for him...
https://www.rx8club.com/search.php?searchid=3301321
Old Jan 28, 2008 | 08:35 PM
Originally Posted by topgear8
they dont learn that way...
but sense you are doing it i will add this one that will cover most of the rest of the ?s coming...
https://www.rx8club.com/showpost.php...25&postcount=4
DarkBrew's Avatar
Extraordinary Engineering
Paging Mazurfer
Old Jan 28, 2008 | 08:37 PM
IcarusX8's Avatar
i've lost my mind
i love it when i see that on my stick! it always puts a smile on my face! and by 'smile' i mean frown...hate the cold
Old Jan 28, 2008 | 08:39 PM
Originally Posted by DarkBrew
Paging Mazurfer
yea,
i was thinking that.. it would be 7 i think. not sure about the month thing.
Old Jan 28, 2008 | 09:22 PM
DarkBrew's Avatar
Originally Posted by swoope
yea,
There was already a 7. This is at least 8
Old Jan 28, 2008 | 09:45 PM
RX26b's Avatar
It is not a problem. Just clean it off, stick it back in, and it should be fine.
That's what she said, when I, uh, popped out of her back door.
Old Jan 29, 2008 | 01:08 AM
DOMINION's Avatar
I don't buy Kool-Aid
Thumbs up
Ahh you beat me to it
Old Jan 29, 2008 | 07:15 AM
CTrx8's Avatar
space for rent
^ nice sig pic.
and i'm not too worried about thread jacking since this thread should never have happened.
Old Jan 29, 2008 | 10:54 AM
or read my winter thread. link in the sig below
Old Jan 29, 2008 | 10:59 AM
VolcomStoneX's Avatar
Hi, Let's Make Out
this is covered under warranty, its condensation, just moisture happened shortly after i got my 8,
Old Jan 29, 2008 | 12:53 PM
Search ! Search ! Search !!!!!!!!
Old Jan 29, 2008 | 01:31 PM
bose's Avatar
Reginald P. Billingsly
I know Mazda says it's not a problem and most of you have no problems, but I believe it is a problem, I have bad compression on my engine and no one knows the cause IMO it's cause of this emulsified oil, this stuff is corrosive. how can it be properly lubing the seals if it's in all the oil, some don't get it anywhere but the dipstick but if it's in the pan there is where the problem lies, then it gets fed to the seals and eats them up.
Old Jan 29, 2008 | 02:27 PM
Socr8tes's Avatar
I don't even know where to begin...
Old Jan 29, 2008 | 02:30 PM
Warm up the car for a longer period of time. Problem solved.
Old Jan 29, 2008 | 03:18 PM
Juice's Avatar
I made some poos
I'll play along.
1. First off, its just condensation. Condensation means WATER. Corrosive by definition is having the power to corrode. Corrode by definition is to wear away gradually usually by chemical reation. So I must ask, how can water (with the neutral pH of 7) be corrosive?
2. Most people have this problem only on the dipstick tube. I am willing to bet you only have it on your dipstick as well. Did you check your oil pan for this? Or are you just assuming it is there because its on the dipstick?
Old Jan 29, 2008 | 03:26 PM
If you have an 04...early 05...get the new upper intake manifold/breather fix from the dealer...it will stop the condensation problem totally
There is a TSB for this around...search
Old Jan 29, 2008 | 03:41 PM
RojoOcho's Avatar
Greensboro's Finest
Ok. We got it. He knows to search now... close thread.
Old Jan 29, 2008 | 03:43 PM
dmc27's Avatar
doin' the bull dance
^ who the f8ck are you to decide when threads close!!!!?????????
Old Jan 29, 2008 | 08:04 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Damn it man.....I take a day off and look what happens!
Thanks for the heads up!
Old Jan 29, 2008 | 08:08 PM
DarkBrew's Avatar
No more days off for you
Old Jan 30, 2008 | 12:38 AM
slacker.
