DSC OFF blinking after....
Old Jan 23, 2008 | 06:38 AM
andreasy's Avatar
This is what I did:
I removed the negative battery pole, disassembled console components, ashtray, etc, in order to reach the faulty cd changer in order to replace it with a new mp3. I haven't managed to go any further so I put everything back, connected the negative pole but when I tried to start the engine, the DSC OFF lights is constantly blinking.
I did a quick search and found that this happens if you press the button for more than 2 seconds.
What does this mean now?
Old Jan 23, 2008 | 06:42 AM
DarkBrew's Avatar
Extraordinary Engineering
You have to reset. The manual explains it
Turn full left then full right.
It happens when ever you disconnect power.
Old Jan 23, 2008 | 06:47 AM
andreasy's Avatar
Furthermore, I found this:
Turn the car OFF, move the key to the "ON" position, turn the wheel clockwise fully, and then counter-clockwise fully, start the car.
I followed this procedure once and the light went off but another yellow light went on (don't know the English name) and couldn't turn on or off the dsc. I repeated the procedure another time and then it was fixed.
Is this normal? and why does this happen, maybe due to battery removal ?
Old Jan 23, 2008 | 10:16 AM
Juice's Avatar
I made some poos
Yes, due to the disconnecting of the battery, the systems need to be calibrated again. just turn the steering wheel full left then right. The lights should go off. There should be 2 lights, one is DSC OFF, and the other is the traction control light (car with curved lines behind it). Do the left/right procedure and you will be fine.
Old Jan 23, 2008 | 01:09 PM
FTFM PLEASE !
I MEAN PLEASE ! I BEG YOU !
OfficerFarva
Dec 5, 2015 10:53 AM
D13
Oct 1, 2015 07:55 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
