Need Major Help!!!
Old Jan 20, 2008 | 01:06 PM
SRrx-8JC's Avatar
Felix "The Man" Wankel
Unhappy Need Major Help!!!
Problem: I was driving on the highway last night, I was going about 75 mph and then I went to downshift into 5th gear because I was getting off an exit. As soon as I downshifted I had loss of power and a deeeep sputtering sound the car would jus barly move if I gave it gas then if I let off it would stall. I also had a Flashing CEL light which I know means misfire. I then Tried to start the car again and it turns over and sounds like it almost catches and starts but then just dies.
Weather Conditions: It was 7:02 in the eveing and it was 19 degrees out side, and clear.
Recent Upkeeping: Last weekend I topped off the oil, Checked the coolant levels, replaced four ignition coils, and put on the Racing Beat ignition wires on, cleaned the RB Revi intake, and put in a new battery, also full tank of Shell V-Power gas.
I take very good care of this car, I have many things done to it and done correctly. My car is an 04 MT with 58,984 miles on it. i bought the car new. I have the warrenty on the car but since I have all those things on there they will most likly void my warrenty. So I am asking so some general input for the time being, I am also pulling the codes within the next 3 hours so I will have specifically what is wrong with it and then get advice for that.
Bottomline: Need help, Hate the dealership = ********!
Thanks a ton guys...
Old Jan 20, 2008 | 01:11 PM
chancejat's Avatar
Drive it like u stole it!
put the stock parts back on and take it to mazda.....maybe one or your wires fell off or something like that....
Old Jan 20, 2008 | 01:13 PM
DarkBrew's Avatar
Extraordinary Engineering
Random questions
Did you over-rev on the down shift?
Have you checked that the RB wires are properly snapped in place?
Also you should check the connectors on the coils
You didn't mention plugs...?
Did you at least get to the dealer for the recall flash update?
Old Jan 20, 2008 | 01:23 PM
SRrx-8JC's Avatar
I did not over rev on the downshift, I have checked the wires like thre and four times...lol, I just put them on like two days ago, I will check the connectors on the coils, and no I didnt put new plugs in yet I have them I just couldnt get them loose or to even move so I was going to take it to midas to a buddy of mine that works there to do it for free. ....I have know idea where to even check for a recall flash, but i keep every service record for my car so is it on that paper work....?
Old Jan 20, 2008 | 01:29 PM
DarkBrew's Avatar
If your dealer updated the flash revision in you car then it should be listed.
Check your paperwork from the engine check recall.
Old Jan 20, 2008 | 02:05 PM
SRrx-8JC's Avatar
ok...I will do that and I will get back to you guys when I get the code....I am doing that in about 30 mins....
Old Jan 20, 2008 | 02:10 PM
check to make sure plugs are tight to motor..
wires to coils and plugs are tight..
also it might be fuel pump time.. i just went through this...
Old Jan 20, 2008 | 02:14 PM
chrism's Avatar
Misfit Moderator TnC
if your location is clifton, nj why not just take it to wayne...they are pretty good and should be able to fix it....
Old Jan 20, 2008 | 04:53 PM
SRrx-8JC's Avatar
OK Guys here are the codes....
- p0171- System too Lean
(Bank 1)
-p0302- Cylinder 2 Misfire Detected
(pending)
I got another p0171- System too Lean
(Bank 1, Pending)
Any insight would be great, and I live in Clifton, Ohio ...lol...not NJ.
Old Jan 20, 2008 | 04:56 PM
chrism's Avatar
plug wires and revi should not void your warantee....this is something in my opinion should be fixed by the dealer....and if they said your mods voided the warantee then the burden of proof falls on them and not you on the how part......
Old Jan 20, 2008 | 05:19 PM
SRrx-8JC's Avatar
Does anyone know specifically what those codes could mean.....i.e- spark plugs, fuel pump, fuel injectors....
Old Jan 20, 2008 | 05:23 PM
SRrx-8JC's Avatar
I have done to my car
-Revi ram air intake
-RB plug wires
-four new coils
-catless midpipe
-greddy sp2 exhaust
-AP underdrive pulley
Old Jan 20, 2008 | 05:43 PM
06carbon8's Avatar
its strange how similar our issues are. i had almost the exact same thing happen to me, last night. except i didnt downshift. during highway speed (80 or so) motor just bogged down, shut off, and wont restart. i just got back from changing the plugs, still wont start. i have spark and fuel. so i'm assuming the motor is dead at 29xxx miles. good luck with yours, i'm getting mine towed in the morning. i have an intake, full exhaust, and thats it. i believe theyll try to void my warranty as well.
Old Jan 20, 2008 | 05:53 PM
SRrx-8JC's Avatar
Well 06carbon8 let me know how things go, did you pull any of the same codes as I did? Because the misfire codes sound like a spark plugs, fuel pump, or fuel injectors....so I am curious to see what they say....let me know man.
Old Jan 20, 2008 | 05:55 PM
06carbon8's Avatar
alright, ill keep you updated. i doubt ill even have a car after tonight, its sitting on the side of the interstate so itll probably either get plowed by a truck or stripped. we'll see in the morning.
Old Jan 20, 2008 | 06:03 PM
Speedrx8er's Avatar
(Bank 1)
(pending)
(Bank 1, Pending)
that suck.. You may have lost a seal. Get a compression test done.
Old Jan 20, 2008 | 06:18 PM
SRrx-8JC's Avatar
Do I have to go to the dealership for the compression test? I am trying to avoid the dealership if at all possible. And are you talking about an apex seal, and if that is the case is the engine done?
Old Jan 20, 2008 | 06:21 PM
Speedrx8er's Avatar
you can get a compression tester from the auto store and remove the check valve. your compression should be 80+ .
Yes the apex seal..
If it is your seal then yes the dealer will replace your engine(put it all back to stock).
Old Jan 20, 2008 | 07:13 PM
SRrx-8JC's Avatar
Sry for all my questions, but where is the check valve? and how do I go about doing this. I am eager to learn how to do this stuff, and I want to save money also I did a search for a DIY and I couldn't find anything....
Old Jan 20, 2008 | 07:31 PM
Speedrx8er's Avatar
most compression tester will have a check valve install. but our engine in a sense have three chamber(3 seal) . by removing the check valve will allow you get the reading.
Google it.. Use the spark plug hole <-- should get you started.
before you do all that. As someone has mention earlier. Check your coils and make sure you have it wired correctly.
Check to make sure the spark plug wires is going to the correct coil.
Make sure the plug wires are not touching.
Old Jan 20, 2008 | 07:34 PM
Go back and try to re-start it.
Don't let the state tow it.
Maybe you went into limp mode.
a completely dead battery will kill the car like you described it, but I highly doubt that is it.
Re-check your installation.
Old Jan 20, 2008 | 07:44 PM
just went through the same thing.. same code.. car would just shut off after about 95 miles. let it sit for 5 min. ran fine..
i replaced the fuel pump and coils..
runs like new..
if i were you. do the coils first.. then the pump..
(Bank 1)
(pending)
(Bank 1, Pending)
Old Jan 20, 2008 | 07:50 PM
SRrx-8JC's Avatar
ok guys thx...I just checked my funding and to see what kind of money i will have in the next three months and things look good, so if the engine is bad it may sit for a bit and then can you say cough cough 20b cough......lol..thx for all the replies.
Old Jan 20, 2008 | 07:51 PM
olddragger's Avatar
I hope that is what it is.
If you want --do an audible test on the rotors,,just removed the fuel pump relay, and the eccentric shaft plug. then remove one trailing plug at the time and crank it. Should hear each rotor face's compression as the engine turns. Listen for any difference. Do both rotors that way.if you hear a difference then ask for a compression test. Its a rough result test--but it can give you some idea.
oldscdragger
Old Jan 20, 2008 | 08:27 PM
Is your vac plug still on the intake...it can make the lean code come up.
That won't be your major problem....I would check the coil/plug wires and plugs as already mentioned..... Sure you didn't mix them up?
