After Eibach Lowering.... Is it Low enough?
Old Jan 13, 2008 | 11:19 AM
WoHorsy's Avatar
I didnt know exactly what was suppose to be loosened through the tech guides i found. I do not believe the car is low enough in the front.
Old Jan 13, 2008 | 11:22 AM
WoHorsy's Avatar
o ya here is a pic of the front...
Attached Thumbnails After Eibach Lowering.... Is it Low enough?-dscf0710.jpg
Old Jan 13, 2008 | 11:28 AM
HCTR154's Avatar
Go to the search function and type in " preloading". That should explain it for you. Very simple procedure that takes only a few minutes and should drop your front down.
Old Jan 13, 2008 | 11:32 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Jack it up, loosen the A-arms, lower the car(for loading..........that's for TEAMRX8), maybe push up and down on the front end a little, then climb under there and tighten A-arms to spec.
Old Jan 13, 2008 | 12:40 PM
altiain's Avatar
Sparky!
Also don't forget that with new springs the suspension will settle after the first hundred miles or so.
In addition, keep in mind that not every RX-8 leaves the factory with the exact same ride height. There are tolerances built into the suspension, and yours may not end up at *exactly* the same height as another identically equipped car.
Old Jan 13, 2008 | 07:37 PM
WoHorsy's Avatar
cool thanks for the good information. Will loosening these up change my alignment? I got the car lowered about a month ago and have since already had it aligned. Although if it does i will get it aligned again.
Old Jan 13, 2008 | 07:43 PM
Mazurfer's Avatar
Probably not 100% needed, but I think I would go ahead and do it.
I would recommend a search in the DIY section about springs and or shocks if unsure about thow to do this whole loading thing, but I pretty much expalined it above, just make sure you use jack stands and be careful.
Old Jan 14, 2008 | 07:52 AM
WoHorsy's Avatar
I will definately be careful. Thanks for the good information and all the help. I actually have a friend with a shop with a few lifts in it. He will let me use one of them on the weekend i am sure so this should be a quick process.
Old Jan 15, 2008 | 12:58 PM
WoHorsy's Avatar
Well i got it done last night and i am pretty sure it dropped about 3/4 in. I will post pics when i get on my mac and can retrieve it. Initially i was disappointed when i first got springs on but after last night it was all worth it, the car looks much better.
cliffkemp
Dec 24, 2024 10:48 AM
Michael Bryant
Oct 12, 2015 03:07 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
xAgyex
Sep 28, 2015 08:54 AM
