Rx8 catalitic removal
Old Jan 11, 2008 | 02:59 PM
AndyRx8's's Avatar
Andy's 8888's
In South Africa we dont have to have catalitic converters so i want to remove mine but there is a sensor ( O2 or knock) in it. Can someone tell me if I can remove the sensor without causing any problems?
Old Jan 11, 2008 | 03:01 PM
staticlag's Avatar
The Professor
Yeah, should be fine.
You should install a pipe that leads the exhuast gasses away though, the heat and smoke will ruin the underside of your car if you just remove the pipe.
Old Jan 11, 2008 | 04:11 PM
alnielsen's Avatar
Just be aware that you will probably get a CEL when you remove the cat.
Old Jan 11, 2008 | 04:26 PM
mysql101's Avatar
most catless midpipes come with a bung that lets you reattach the sensor.
Old Jan 11, 2008 | 06:13 PM
mmats69's Avatar
93.5 octane
Get one of those. You will get a CEL but it will not affect the performance of the car.
Old Jan 11, 2008 | 06:55 PM
yup, these guys are tellin' the truth!
Are you going to run a midpipe or a high flow cat?
Old Jan 13, 2008 | 03:08 AM
AndyRx8's's Avatar
Andy's 8888's
Thanks to everyone for the info. In South Africa there are no after market parts available for the Rx8 so we have to either import or fabricate ourselves which is what I am going to do. My idea is to remove the CAT and to replace it with a staight through pipe with a fitting for the sensor. I have fabricated all my own exhaust systems for my Rx7's and they turned out quit well. But those models are nots as advanced as the Rx8. By the way what is a CEL?
Old Jan 13, 2008 | 03:14 AM
check engine light..
here is a helpful chart of sorts...
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Old Jan 14, 2008 | 12:34 AM
Stephen_in_Seoul's Avatar
If you remove the cat then you will get a CEL immediatly. However you have a good solution to avoid the CEL in SA. UNichip is very poplular piggyback in SA and there is a headquater of Unichip in Pretoria, also over a hundred dealerships are in SA. I live in S.Korea and got a unichip Q in my RX-8. I've managed the CEL with Unichip. It works perfectly but you need a good tuner to find the right value of o2 signal. After done you ECU will be happy with it.
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
rotorocks
47
May 11, 2016 03:23 PM
Junirol
Sep 22, 2015 06:02 AM
Bamaham
Jul 23, 2015 08:08 AM
ironj221
Jul 16, 2015 10:16 PM
