Aftermarket headers + stock exhausts
Old Oct 28, 2003 | 01:42 AM
alex's Avatar
SIGSEGV
Mod Edit: This is a 10 year thread bump
I was thinking of upgrading the headers of the RX8 but keep the stock exhaust. The only reason I would do that is because I've read sites (Racing Beat) say that the Mazda didn't leave much room for improviement on the cat-back. So, just figured this combination would yield some good results on the HP/torque side while keeping most of the OEM parts.
Any ideas of this is wise?
--alex
ps: are the tubular headers for the RX8 being sold?
Old Oct 28, 2003 | 01:46 PM
wakeech's Avatar
mostly harmless
Re: Aftermarket headers + stock exhausts
--alex
yeah, there are equal length headers being made for the RX-8... i think Amemiya-san might have his on for sale, but rotarygod has veeerrrry interesting thoughts about what'll actually work on this engine ('cause the intermediate port is siamesed).
anyways, Racing Beat, and other tuner companies say that kind of thing to cover their ***, and talk up the product. don't think that you can't make more power out of the back end, 'cause there're always factory comprimises which can be swayed one way or the other to gain more performance.
the biggest problem with just replacing the header is fitment: you'd have to find a direct replacement header, and given the design of the current log (which is really REALLY just a log with almost no runner length) it'd be hard to squeeze all the tubing necessary and have the collector in the stock mounting location.
anyhoo, could you?? sure, if the part exists.
BY THE WAY
be a convert of the "Torque Numbers are Marketing BS" crowd, and realise that they're useful only for creating a suggestion of the torque curve of the engine, but given that they really only give you a reading at one speed of the engine are completely useless.
when most people say the word "torque", they're talking abotu "off the line power", which is exactly that: low rpm power.
'cause Americans have always made everythign big (especially their engines), low rpm power is something they're accustomed to in abundance, but for some weird reason keep calling it torque. it isn't, it's still HP, just in the lower specturm of RPM.
Old Oct 29, 2003 | 01:08 AM
alex's Avatar
SIGSEGV
Thanks for the information, I am usually not too worried about the HP/Torque, its just people in the forum has been bringing up, indirectly, the desire to "boost" the performance. Seemed like lots of credible "post-ers" were making this topic something that was feasible to do and from this, placedin my head the thought of a header upgrade for more "go".
Seeing that you're on of the most knowledgable person on the FD's, I will just leave the of the RX8 performance be (for now .. hehe); I mean, I feel the RX8 is pretty darn fast, even w/ my 19" wheel upgrade.
So what is rotorygod's viewpoint on the Renesis performance potential?
--alex
Old Oct 29, 2003 | 01:20 PM
wakeech's Avatar
mostly harmless
--alex
oh, i wasn't talking abotu the potential: this is one helluva strong motor.
the issue i was talking about was designing the resonance of the header to optimise breathing out of all three ports: an equal length approach apparently isn't the best way to do it, because the intermediate port (middle one) is siamesed between the two rotors. this could be fixed by making the one port into two, then having a 4-to-1 header, or by designing a header with a resonance appropriate to the siamesing.
Old Oct 29, 2003 | 02:49 PM
SA22C's Avatar
Oversteer = Bliss
Yeah, I was looking at the exhaust ports from the pictures on Yaw's website, they're very interesting. It certainly looks like a fair amount of testing/tuning will have to be done before a header will be produced that offers significant power gains. Another poster on this board mentioned that the header out right now doesn't offer any power gains!
Old Oct 29, 2003 | 03:12 PM
rotarygod's Avatar
wakeech I posted an error in the distance ratio.
Here's how the headers I want to build are designed. I looked at the mid 20th century 4 cylinder engines and saw that many had the 2 middle cylinder exhausts siamesed. This baffles me and obviously we have evolved away from this. On race cars however they found a way to make it work almost as good as a true seperate system. There are 2 ways to do it both similar. One way involves figuring out the perfect header primary pipe length and then making the 2 outer pipes collect at this distance. The center pipe does not collect here. Take the length of the primary runners and multiply it by 3. This is how far down after the first collector that the 3rd runner will collect at. That is option one. Option 2 is very similar. The 2 outer runners collect at a certain distance while the 3rd collects farther down. The difference is that the 3rd pipe collects at a ratio of 3/4. Take the first runners lengths divide by 3. This number gives you the distance from collector number 1 to where the 3rd runner collects. This isn't the end though. We want the middle runner to think that it is being tuned the same as the outers. 3 equal length runners won't necessarily do this due to the very different pressures inside the siamesed port. take the original outside runner lengths and make a dead end pipe. Join it into the center runner right outside the engine and make it extend the same length as the outer pipes then just cap the end off. This gives the center port an acoustical resonance at the same spot as the outer ports even though there is twice as many exhaust pulses in that pipe. Acoustics play a huge role in tuning. It isn't only a gas pressure thing, it is also an acoustic pressure thing as well. Unforunately I don't know the lengths that the pipes should be since I don't know the port timing. I could probably guess fairly close although maybe I just think that and it will be way off. The key would be to make the best guess, dyno it, and see where the peak is. If there is a peak I'll know the idea is sound. All that would need to be done then is to work on adjusting the length and then finally proper collector sizes. If I had an RX-8 I'd already be working on it.
I ran the idea by Paul Yaw and he said that he has always wanted to try the dead leg on a rotary but never has. He is more inclined to try it on a bridgeport or peripheral port engine but he'd love to know as well how it works on the Renesis. If Paul is at least curious then it must have some merit. I wish I could build it.
Old Oct 29, 2003 | 04:12 PM
wakeech's Avatar
mostly harmless
and there you have it alex.
Old Oct 29, 2003 | 11:37 PM
alex's Avatar
SIGSEGV
Wow, I feel extremely humbled ..
[Peter Griffin - The Family Guy]: Wow, I think I learned something there ..
So, I guess I will save $$$ and NOT buy this enhancement yet.
Thanks guys [Wakeech, rotarygod,SA22C]!
--alex
Old Oct 30, 2003 | 11:50 AM
rotarygod's Avatar
Paul Yaw had said that the Renesis has proven to be unresponsive to headers so far. If the middle port needs a different length to work right then it will mess up the tuning no matter how long the headers are. Therefore it shouldn't really matter if you have long headers, short headers, or the stock manifold. That middle port is always going to cancel out any benefit as long as it is the same length. This is why I feel that the center port needs all the attention. We can figure out how the outer ports want to breathe. The key is fooling the middle port into thinking that it works the same way. Someone is going to stumble on this and make it happen. When it does, remember where you heard it first!
Old Aug 18, 2013 | 03:57 PM
BlueRick's Avatar
I'm in the process of modding my 2004 RX8. I've done the rear exhaust and the short throw forced air induction and I'm signed up to do Racing Beat exhaust headers. Will it do any good?
Old Aug 18, 2013 | 04:17 PM
RIWWP's Avatar
Blue, you may want to read the newbie's guide to modding rather than bumping 9-10 year old threads that were made while people were taking their first baby steps in modding this car. What they knew in 2003-2004 was quite difference from what we know today.
Also, you can only use "exhaust header" if you use supercharging for forced inductions, since one of the key components of a turbo install would replace that "exhaust header"
Old Aug 19, 2013 | 09:18 PM
HOLY BATMAN ! WOW !
but may I ask, what the heck is "short throw forced air induction" ???
Old Aug 19, 2013 | 11:29 PM
I'd be more concerned with understanding "zero overlap", very few people do ...
Old Aug 20, 2013 | 07:21 AM
BlueRick's Avatar
Originally Posted by nycgps
HOLY BATMAN ! WOW !
I'm not technically knowledgeable enough to tell you exactly what 'short throw forced air induction' is. I can tell you that it looks like a short piece of tubing that replaced the previous piece that channeled engine exhaust back towards the rear exhaust system...which I also replaced. It's all part and parcel of the exhaust system mod. I'm still trying to figure out what cold air inducton is as compared to my short throw forced air induction. I suppose it channels air in from outside the engine.
Next up are the Racing beat headers.
And for what? Better sound and maybe 15-20 extra horsepower....maybe...
Let me be more specific...and more exact....
My mods so far include: SP Elite Exhaust Muffler System, Injen 03-09 Rotor Polished Short Ram Intake, and I ordered Racing Beat Exhaust Headers which I'm waiting to arrive and install. Any thoughts?
Old Aug 20, 2013 | 08:12 AM
RIWWP's Avatar
Blue,
You should start with my newbie's guide to modding. It sounds like you are getting all your information from scammers trying to make money on your lack of knowledge.
"Forced induction" means turbocharging or supercharging, both of which are $10,000+ for our car. They may be just messing up "short ram air intake", however you should know that those DO NOT WORK on our car (and also have nothing to do with the exhaust system). They will seriously make you lose power. Every single last one of them. The only intakes that are superior to the stock intake are Racing Beat, AEM, and Mazdaspeed. Everything is either complete junk that will cause you problems, power loss, and CELs, or at BEST is on par with the stock intake. Our stock intake is REALLY very good.
Headers also need an entire exhaust upgrade, including midpipe and catback to really have any benefit.
Total gain from using the absolute best consumer intake and exhaust out there? Maybe 10-15hp, TOTAL. And it will cost you somewhere between $2,000-$3,000
Please read through my newbie's guide to modding: https://www.rx8club.com/rx-8-discuss...rx-8-a-233937/
Old Aug 20, 2013 | 08:14 AM
paimon.soror's Avatar
Lol ive enjoyed seeing you try to hammer this point across since probably day 1 that I have owned my 8 (2010) ..... they will eventually listen to you Team ...... right?
Old Aug 20, 2013 | 08:16 AM
RIWWP's Avatar
I don't think this guy is ready to even look at that concept, since his intake pushes exhaust toward the back of the engine...
Old Aug 21, 2013 | 07:55 AM
BlueRick's Avatar
Originally Posted by RIWWP
Blue,
To the best of my knowledge mid pipes are illegal. My mods so far include: SP Elite Exhaust Muffler System, Injen 03-09 Rotor Polished Short Ram Intake, and I ordered Racing Beat Exhaust Headers which I'm waiting to arrive and install. Any thoughts?
Old Aug 21, 2013 | 07:58 AM
BlueRick's Avatar
To be more exact, my mods so far include: SP Elite Exhaust Muffler System, Injen 03-09 Rotor Polished Short Ram Intake, and I ordered Racing Beat Exhaust Headers which I'm waiting to arrive and install. Any thoughts?
Old Aug 21, 2013 | 09:25 AM
RIWWP's Avatar
Correct, midpipes are not emissions compliant according to federal regulations. You would have to look up the emissions regulations for your state to see if you could pass emissions without a cat or not. Even so, there are plenty of tracked 8s, which can legally run without emissions compliance as they are "off road". That header you got isn't emissions compliant either though, as it will require an air-pump delete (which is part of the emissions equipment, and you will get a CEL for not having it).
My comment was simply that your exhaust system modifications will only make a difference if they are improving flow at the point of greatest restriction. A header will not do jacks**t for more power unless you solve the other OEM constriction points. The OEM header flows well enough that it will only become the point of greatest restriction IF you go catless and get a freer flowing muffler. You have gotten a better muffler ("catback" as it's referred to around here), but with your cat in place, the cat it is STILL the point of greatest restriction. You won't see any gains from that header until you go catless.
And at some further point, you will have to start thinking about TeamRX8's comment, and how that header is still not really worth the money yet.
My thoughts on your other mods are:
Go back to a stock intake.
If you ditch the cat in favor of a quality midpipe, you may see a total gain from the exhaust system of around 10-12whp. Maybe. You are losing 15whp or more from that intake. Why spend money trying to get power from the exhaust when you can get more power back from ditching the crappy short ram intake? All it's doing is providing unstable air flow across the MAF, and all the air it's breathing is hot engine bay air.
Old Aug 22, 2013 | 04:22 AM
BlueRick's Avatar
Wasted effort...
So I wasted my money?
Old Aug 22, 2013 | 04:56 AM
rofl Team ...
well, u didn't wasted ur money, if u gonna get all the said piece EVENTUALLY that is. u just got it earlier than u should, no biggie.
hell, I'm gonna get headers myself soon as well, of course I'm gonna get the rest of the stuff at the same time.
Old Aug 22, 2013 | 05:45 AM
bse50's Avatar
#50
Basically, yes.
Find a stock\original\Mazda intake and throw the injen one you have in the dust bin. The exhaust manifold will maybe help you with 1\2hp... not 15-20.
Old Aug 23, 2013 | 05:39 AM
BlueRick's Avatar
Originally Posted by bse50
Basically, yes.
oh well...too late for that...
Old Aug 23, 2013 | 05:41 AM
BlueRick's Avatar
rofl Team ...
The headers come from Japan so I'm told and there's a wait for delivery...so I wait a couple of weeks...and then...who knows?
jorx7
Sep 29, 2015 04:54 AM
Kahl
Aug 20, 2015 11:49 PM
TheWhiteAce
Aug 6, 2015 02:26 PM
RX7.9
Jul 20, 2015 12:01 PM
