Need New Engine
Old Jan 8, 2008 | 10:10 PM
MRPN's Avatar
Need New Engine
mazda says i need a engine i lost comp. on one rotor i have a 04 rx8 the car was running fine till i stopped and got 6.8 gals gas and i made it 1.5 miles from store. i pumped the tank and got the water out but it would not run right so i took it to mazda dealer they said it needs a short block,intake,o2sensors,wire set, engine harness ( which the cat got cherry red and melted the wires on trans.) coils they want 11,775 to do this should i get in touch with mazda or find a second opinon. DOES ANY ONE KNOW WHERE I MIGHT GO TO FIND A NEW OR REBUILT ENGINE OR FIND A REBUILD KIT.
Old Jan 8, 2008 | 11:27 PM
First, Are you out of warranty ?
Have you ever did the recall ?
Short Block means the engine itself, nothing else attach to it.
Intake, O2sensors, wire set? what wire set ?
Engine harness ? why ? Cuz the Cat melted it ? Are they even suppose to be that way ?
Cuz to me, it sound like you had a clogged cat, result in *burning hot* cat. then it starts melting other stuff.
if thats the case, you should be covered 100%, cuz Emission equipment are warranted for 80K miles I think. and anything failed because of it should be covered as well.
We need more info. and please next time try to use some ',' (commas) and '.' periods.
Oh and, talk to Mazda. Not the dealership, Call Mazda directly and tell them you believe the emission equipment failed and cause other stuff to failed. Also, no offense here but, Find an adult to call, cuz you sound like you're not old enough to do this alone.
Old Jan 9, 2008 | 12:04 AM
shaunv74's Avatar
Power!!
There is a recall for this exact issue.
Check here for details:
http://www.finishlineperformance.com/rx8/bulletins.html
Like NYGPS said it sounds like your cat melted and caused your engine to fail. Should be covered under warranty. your Powertrain warranty is 6yrs 60K miles (assuming you're in the US). It's also listed on the link I posted.
If for some reason you end up stuck paying for your engine rebuild (which you should not) you can buy one from Mazmart for ~2K. They are a vendor on the forum.
Post up your location so we know where you are from.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Aug 31, 2015 11:51 AM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
