What to check, before warranty is over?
Old Jan 7, 2008 | 11:18 AM
reddevilwarrior's Avatar
Before Warrranty is over, what Should I check in my car for?
I checked speakers, and tail lights.
What else "to do" list to check
So I dont regret after my warranty is over.
Thanks.
Old Jan 7, 2008 | 11:22 AM
chetrickerman's Avatar
check every nook and cranny of your engine, transmission, differential, driveshaft, axles, suspension, all of that. you want to be very very thorough. you should spend at least a whole day doing it
Old Jan 7, 2008 | 11:24 AM
compression check
Old Jan 7, 2008 | 11:52 AM
and... problem is how to... check those things listed...
Old Jan 7, 2008 | 12:02 PM
Raptor75's Avatar
Originally Posted by Jedi54
compression check
I second this one, might cost you a hundred bucks but it is well worth the piece of mind.
Old Jan 7, 2008 | 12:30 PM
where do you live?
Old Jan 7, 2008 | 01:17 PM
dmorales's Avatar
Spin Triangles! Spin!
motor mounts
________
Web shows
Old Jan 7, 2008 | 01:40 PM
where do you live?
Live in Pennsylvania...
My friend has mazdaspeed protege he has a tool that can compression check.
But He doesn't have experience with rotary.
1. He doesnt know where its at on rx8
2. what are the number supposed to be?
Thanks jedi54
Another one, I have a little over 15k miles on the car.
Driver side seat has little bit of wear/tear, Is this something I can ask under warranty? since its only 15k miles on the car?
Old Jan 7, 2008 | 02:13 PM
dmc27's Avatar
doin' the bull dance
hmm . . . not sure if the compression numbers are listed on the recall letter, but it's worth a check on rosenthal's site - TSBs. (compression test = vacuum test) I think the numbers were discussed for a while in the "engine replacement poll" thread - here (tho it may be a ton of reading to find @300+ posts)
Doing it yourself would be nice for comparison, but it's worth doing at the dealer either way. Then there's no question about differences between machines - or any other craptastic nonsense the dealer may try to claim makes your readings invalid.
Old Jan 7, 2008 | 02:15 PM
dmc27's Avatar
Can't hurt to ask about the seat, but my gut instinct was to rofl. Maybe if you actually use the dealer service dept, but if not they'll probably tell you you fart too much!
Old Jan 7, 2008 | 03:03 PM
Raptor75's Avatar
The engine recall would not list the compression ratio, it tested vacuum not compression.
As for testing it your self, you will need a special gauge designed to test compression on a rotary. A regular compression gauge will not work.
Old Jan 7, 2008 | 03:10 PM
dmc27's Avatar
ugh. just when I thought I had a grasp of it . . .
I thought the vacuum test was to check compression. meh.
Old Jan 7, 2008 | 03:40 PM
Duke15's Avatar
2006 Velocity Red Mica
One more little thing - check to see if either of your visors are cracked at all yet. It would be annoying to replace them this summer.
Old Jan 7, 2008 | 03:56 PM
RojoOcho's Avatar
Greensboro's Finest
Just to clarify it's 4yr and 50,000 miles right?
Old Jan 7, 2008 | 03:57 PM
enforcer's Avatar
dmc27 you're avatar scares me...!
Old Jan 7, 2008 | 03:58 PM
dmc27's Avatar
4yr / 48
powertrain extended to 5yr / 60
Old Jan 7, 2008 | 04:02 PM
dmc27's Avatar
haha. Having some fun with the ladies' avatar uprising.
wait, that doesn't sound quite right . . .
Old Jan 7, 2008 | 04:23 PM
enforcer's Avatar
I saw their 'uprising'....well done...
Old Jan 7, 2008 | 04:24 PM
Ah-ha, Thanks Raptor75
Old Jan 7, 2008 | 04:27 PM
Raptor75's Avatar
Nope from what I understand it measured the volume or pressure of the air being sucked into the engine. I don't know why they did this test instead of a compression test. Being cynical I assumed more cars would have failed the compression test and it would have cost Mazda more to fix.
Old Jan 7, 2008 | 05:32 PM
valpac's Avatar
Ahead of its time
48 months or 50,000 miles, which ever comes first.
Old Jan 7, 2008 | 05:44 PM
48 months? that's 2 year
My car is 04, still under warranty now, only has 15k miles.
Def, more than 48months,
I believe its 4 year.
Old Jan 7, 2008 | 05:46 PM
48 months is 4 years
Old Jan 7, 2008 | 06:20 PM
Dang what is wrong with me today...
I apologize...
Back to the topic!
Old Jan 7, 2008 | 06:25 PM
haha, its ok. its a monday
