A look quick look at the ECU where it seats
Old Oct 26, 2003 | 11:15 AM
seikx8's Avatar
Is this title ok?
In the wake of trying to figuring out the wiring of the ECU, I found the RX8 ECU have quite a lot of wires!!! And to top it all, freshair cooler box is wraped around the ECU to disipate heat from itself and the botton unit (the traction control unit I believe). Very well made and integrated.
I need to get myself the electrical shop manual! :p Btw, does anyone know which pins is for the RPM and TPS signal?
Old Feb 14, 2005 | 04:05 PM
Frank Patrick's Avatar
we all would like to know pin for tps
To shut it off!!
Old Feb 14, 2005 | 11:37 PM
robertdot's Avatar
Originally Posted by Frank Patrick
To shut it off!!
Check DIY. I think MazdaManiac had a fix, and it seemed like someone else did, as well.
https://www.rx8club.com/showthread.p...t=disable+tpms
Old Feb 15, 2005 | 05:54 AM
rx8cited's Avatar
And if you check out that thread, you'll see that several people who have tried it say it does not work.
RX-8 Racing
20
May 14, 2016 06:25 PM
alming1132
Sep 30, 2015 11:30 AM
DeltaJ802
Sep 29, 2015 01:20 PM
