Body kit materials
Old Dec 21, 2007 | 11:19 AM
zorro3201's Avatar
Body kit materials
What are body lots made of other than fiberglass? I dont want a fiberglass kit as they will be too brittle.
The accolade kit is like a black rubber composite? Fexible?
Is carbon fiber stiff or flexible?
Old Dec 21, 2007 | 11:23 AM
chrism's Avatar
Misfit Moderator TnC
what makes you think fg is brittle?
Old Dec 21, 2007 | 11:24 AM
romycha1's Avatar
If you get a good quality kit, the fiberglass will not be brittle..
But there is poly-urethane, FRP, and ABS plastic... there may be more, but that is what I can think of off the top of my head.
Carbon Fiber is stiff... and expensive... It may have some flex in it, but to my knowledge.. very very very little.
Old Dec 21, 2007 | 11:27 AM
zorro3201's Avatar
I did body work MANY years ago and worked on vettes. The fiberglass was brittle stiff and a simple bump from another car would crack it.
Old Dec 21, 2007 | 11:28 AM
zorro3201's Avatar
Ah ok. Good info. Thanx...
Old Dec 21, 2007 | 11:50 AM
chrism's Avatar
you were apparently working with cheap fiberglass then....i have been bumped, bottomed and nothing has happened to my kit
Old Dec 21, 2007 | 11:57 AM
zorro3201's Avatar
Ah ok.. Where did you get your kit?
Old Dec 21, 2007 | 02:00 PM
chrism's Avatar
Veilside.....mine is the real deal (no replica) and so far its great...japanese fiberglass is different from the made in the usa knock off crap
Old Dec 22, 2007 | 10:34 PM
INSPIRE's Avatar
No Tune, No Life
It all depends on the manufacturer. Fitment is also an issue you have to take notice. you can have polyurethane and ABS and still dont fit properly.
Old Dec 23, 2007 | 01:26 AM
paulmasoner's Avatar
Asshole for hire
there is also Metton. afaik Mazdaspeed is the only thing that uses this material unfortunately. It is fairly light, extremely durable/flexible and apparently whe its molded properly doesnt warp so fitment is spot on
Old Dec 23, 2007 | 06:48 AM
sportrider24's Avatar
OP - Fiberglass is also what most boats are made out of. It is very durable.
Old Dec 23, 2007 | 07:30 AM
Kris's Avatar
you will be surprised that ALOT of the higher end JDM kits are FRP, i have only seen a few that are Urethane.
I have FRP kit and i do not have any negative to say (knock on wood)
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
paporx8
Nov 5, 2015 07:20 PM
Tsurugi
Oct 4, 2015 02:33 PM
wayloco
Sep 1, 2015 09:03 PM
