How much labor for GReddy turbo fix #2?
Old Dec 18, 2007 | 07:41 PM
turborx8's Avatar
Boost 4 Life
I explained the GReddy turbo "fix #2" to my local tuning shop today.
He had a look and told me it would require having to take apart 1/2 the car to get out the turbo outlet pipe.
Is there any quicker way to accomplish this?
Old Dec 18, 2007 | 07:46 PM
mysql101's Avatar
hmmm, to put a nipple on the pipe? If you remove the passenger side wheel, you can directly access that pipe. If you wanted to pull it out, you'd have to remove the front bumper, remove the ffront passenger wheel, remove a few bolts, and untighten the couplers, then pull it out.
So... should be able to do it and put it back together in 1-2 hours if you had to take it all apart. If you can do it with it on the car, 20 mins.
Old Dec 19, 2007 | 12:42 AM
turborx8's Avatar
Boost 4 Life
Is that even possible?
Cause all the metal shavings would need to be removed after he drills the hole.
Old Dec 19, 2007 | 12:51 AM
turborx8's Avatar
Boost 4 Life
Another thing he was saying is that the wastegage signal does not need to be installed on the turbo outlet pipe. He wanted to grab the signal from the charge pipe.
Old Dec 19, 2007 | 01:21 PM
turborx8's Avatar
Boost 4 Life
Bueller?....... Bueller?
Old Dec 19, 2007 | 09:26 PM
chickenwafer's Avatar
Nope
It's really easy to do yourself. Half the car does not have to come apart.
Jack up the front end, pull the passenger wheel, pull the bumper, undo the couplers and unbolt the pipe. Shouldn't take more than 2 hours to get the first compression pipe off the turbo outlet, then 5 minuets to drill and tap the pipe and thread in the nipple. Bolt the compression pipe back on and then run the silicone hose for the w/g line.
Hunterkelley24
Jun 14, 2022 08:32 AM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
drlubell
Sep 26, 2015 11:58 PM
