Sparks and coils which goes first
Old Nov 15, 2007 | 03:20 AM
dasoviet's Avatar
So I am so confused with this ignition system.
I would like to know which dies first
THE COILS OR THE SPARKS?
Certainly the performance of both depends on the other.
The reason I am asking this is that because i went for a new set of coils and sparks 15kkm before and i now i am experiencing some misfires and hard morning starts. So I thought that if i change only coils i will have my sparks last longer and vice versa.
Thanks for your input
Old Nov 15, 2007 | 04:56 AM
Flashwing's Avatar
3-wheeler
Just throwing this out there but if you were having any issues prior to the coil or spark replacements you might try an E-shaft reset.
I had a failed trailing coilpack and upon replacement I was misfiring all over the place. Resetting the e-shaft position sensor took care of that.
Old Nov 17, 2007 | 05:13 PM
j9fd3s's Avatar
if the coil fails, the misfiring probably damages/fouls the spark plug.
so if you replace coils, you should do plugs too.
Old Nov 17, 2007 | 11:53 PM
shaunv74's Avatar
Power!!
Um. Check your spark plugs to see how they look first. 15K is short for either.
Old Nov 18, 2007 | 12:10 PM
j9fd3s's Avatar
if you can SEE its bad, they have been bad for a long time.
the plugs we changed in the recalls usually look they went under with the titanic or in jim bobs tractor since 1962.
they live a hard life if you dont beat the snot out of the car
RevMeHarder
Jun 1, 2026 02:30 PM
TeslaMSI
Dec 10, 2015 01:10 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
