neutral safety switch
Old Nov 8, 2007 | 08:35 PM
blowinup's Avatar
Well it seems I went out of my service contract an or course now my neutral safety switch is faulty. Is this something I can do myself I have an *** load of tools but do I need to reset my computer? Also where is the switch located?
Old Nov 17, 2007 | 08:11 PM
D_8's Avatar
D_8
Hey man im a new member also and i know how it sucks when you dont know what to do and no one helps...to the point now... I dont know where it is located but even if your service is out...i would check to see if that might of been a recall on your car...ive read a few site where it stated that many 8z have had a recall and that the neutral switch was one of the possible parts to go bad..ill try to find them site again and let you know...good luck
Old Nov 17, 2007 | 10:39 PM
they have been failing... mine is done.. you have to modify a socket or have the right sized crows foot to remove it... think it is on the drivers side of the tranny...
not easy to get to..
Old Nov 27, 2008 | 09:21 AM
RX8-Frontier's Avatar
To drag up an old thread...
I'm changing mine out today.
It's on the driver's side of the transmission.
To expand on what swoope said, to modify a socket to work, you'll need a 1-1/16" deep wall socket (either a 26mm or 27mm should fit as well, but the 1-1/6" is just perfect for the replacement one I have; check yours to be sure, 'cause there ought to be a metric size that's technically the "right" one. Cut out the side of it similiar to an injection socket so that the wire harness & connectors can come out the side. There's not a whole lot of space in there, so a wrench isn't gonna' cut it, most likely.
Make your socket look like this:
Old Nov 27, 2008 | 10:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah don't use one of your expensive good sockets if you have good one if ur gonna' cut a socket apart buy a cheap *** one from walmart or something don't use a snap-on or something....or a crowsfoot....
Old Mar 15, 2009 | 01:32 PM
PRX8's Avatar
Anyone got pictures of the location of this neutral switch....?
Old Mar 17, 2009 | 03:39 PM
upper rear driver side of the trans just forward of the powerframe mounting point (pic by Swoope)
Old Mar 17, 2009 | 07:23 PM
I wonder if you can buy a socket like this?
Old Mar 17, 2009 | 07:25 PM
shazy's Avatar
Can you edit the picture and circle it?
Old Dec 27, 2012 | 06:29 PM
Silverhorn's Avatar
Do you guys have the code # for this alarm?
Old Mar 3, 2013 | 11:06 AM
ace10134's Avatar
Originally Posted by silverhorn
do you guys have the code # for this alarm?
p0850
cliffkemp
Dec 24, 2024 10:48 AM
Jst4fun
Mar 5, 2021 07:16 PM
Digitz0070
Oct 7, 2015 12:43 PM
