throw out bearing and engin replacement test
Old Oct 24, 2007 | 07:08 AM
ineffable13's Avatar
PWNZ0R
Question throw out bearing and engin replacement test
ok i know i need a new throw out bearing... i have a appointment at the dealership for them to replace it...
1) will it be covered by warranty?
(there are no mods to my car that should effect it)
2) i am due for an oil change should i do it b4 going to dealership?(im not sure if they will need to drain my oil to replace the throw out bearring)
3)im going to also have them test my car to see if i can get a new motor...should i put my stock airbox back in b4 taking it in? (i have the simota intake)
thanx in advance
Old Oct 24, 2007 | 09:04 AM
1. If you are still under warranty, yes, it should be covered.
2. No need, if its under warranty, they will cover it.
3. They cant void your engine warranty Cuz of the intake unless they can prove that the intake is the cause of failure, which is impossible. but if you dont want to argue anything. change it back.
vapor2
Nov 3, 2020 03:38 PM
BigMikeATL
May 26, 2016 12:31 AM
Rx808BI
Aug 9, 2015 10:06 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
