How to install rear splash guards...
Old Oct 17, 2003 | 05:44 PM
spdspappy's Avatar
I just got the delivery from Trussville. The instructions from Mazda state: "Cut off the two indicated parts on Shield Splash with nipper. (See picture 2)". However, it doesn't show exactly what it supposed to be cut. Has anyone else installed these that can give me some pointers/pictures?
FYI: Get your touch-up paint from them while you can. Mazda is out for at least a month...
Old Oct 17, 2003 | 06:03 PM
mikeb's Avatar
100% Italian
wheres pic 2
Old Oct 17, 2003 | 06:25 PM
1fine8's Avatar
I think I only had to pull apart the small preferated tabs on the plastic inner fender liner where the screws mount up the fasteners you use to install the guards.
There is no major cutting like it is for the front guards.
Old Oct 17, 2003 | 08:14 PM
mikeb's Avatar
100% Italian
the front guards require cutting?
Old Oct 17, 2003 | 08:50 PM
1fine8's Avatar
On the front installation you have to cut a 2 inch piece off the rubber moulding on the bottom of the car under the front fender so the mud guard will fit flush. This molding runs from the front to the back wheel.
Old Oct 18, 2003 | 07:44 AM
spdspappy's Avatar
Here's the pic
Old Oct 18, 2003 | 09:43 AM
spdspappy's Avatar
I figured it out...
In this pic, you'll see an opening that looks like a horseshoe...
Old Oct 18, 2003 | 09:45 AM
spdspappy's Avatar
After you cut it out, it looks like...
Old Oct 18, 2003 | 09:48 AM
spdspappy's Avatar
And you end up with...
Attached Thumbnails How to install rear splash guards...-after-install-rear-splas.jpg
Old Oct 18, 2003 | 09:51 AM
spdspappy's Avatar
And finally...
Attached Thumbnails How to install rear splash guards...-after-install-rear-splash-guard2.jpg
Old Oct 18, 2003 | 06:15 PM
mikeb's Avatar
100% Italian
sweet pics
I love that blue
Old Oct 18, 2003 | 09:11 PM
spdspappy's Avatar
Thanks. I just hope it helps someone...
The blue seems to catch everyone's eye. Even at the cruisin' nights, people seem to be attracted to the blue over the other colors.
Old Jan 19, 2004 | 01:44 PM
CoastalKT's Avatar
SPDSPAPPY, I can not tell - did you have to take the rear wheels off to put on the splash guard? (in order to get to the screws)
Thanks in advance, Mike
Old Jan 19, 2004 | 04:44 PM
spdspappy's Avatar
Nope, you do not need to remove the rear wheels to install them.
Old Jan 19, 2004 | 06:54 PM
D MENAC 7's Avatar
Moderator with a mycocardium
Thanks for the info, I am getting them for my Velocity Red next pay day.
Planning on getting the front splash guards too. They require cutting as posted? Will my Dremmel be the choice of tools to cut with?
I've gotten pretty good at cutting with it such as mods to PC cases and other custom projects around the house. But on my RX-8, I'd hate to do anyhthing that would jeopardize it's appearance.
Old Jan 19, 2004 | 08:04 PM
spdspappy's Avatar
I think there is another thread on how to do the fronts... I don't have them, but I'm 99% positive you'll need to do some cutting (probably w/ snips & not a Dremmel).
Old Nov 21, 2005 | 08:59 PM
Astral's Avatar
Purveyor of fine bass
bringing back the photos
Old Feb 21, 2006 | 11:57 AM
Luds's Avatar
AW YEA?
thanks spdspappy for the nice illustrations! i have two questions: before installing the splash guards is it necessary to clean the area on the bumper where the splash guard will cover? did you just wipe it down or what? and once it's installed, is it possible for dirt/water to find its way inside that crevice between the splash guard and bumper, or is it a real tight snug fit? i'm probably just being paranoid and over cautious, but just wanted to ask before i install them tonight.
Old Feb 21, 2006 | 06:36 PM
spdspappy's Avatar
I made sure the area was clean, but didn't do anything special (wax remover, etc.) to the area. As far as dirt getting in there now... I haven't noticed any (not to say that there isn't any, but I don't drive my car much - 4.5k in about 27 months). Good luck!!!!
Old Feb 22, 2006 | 07:59 AM
Astral's Avatar
i don't really get any dirt in there. it's a pretty snug fit if you do it right.
i cleaned the area with meg's quick detailer (probably not the best idea, but it seemed to get clean). for the front mudflaps, i clayed the area.
i would suggest claying the area (w/ a claybar).
Old Feb 22, 2006 | 10:26 AM
Luds's Avatar
AW YEA?
just installed them last night. i just ended up wiping the area with isopropyl alcohol as instructed. you're right, they are a snug fit. but i wonder why the rear splash guards don't have adhesives like the front ones do... hmm.
Old Oct 30, 2006 | 04:43 PM
bikes2cars's Avatar
oooh. shiny.
Thanks a lot to everyone on this thread! I've been wanting to get the rear splash guards but did not want to pay Mazda $100 to put on a $50 part. I just finished installing them and they look real good--low profile. Can't hardly notice them. In contrast to the rear Aero Flares which do not align with the curves of the rear quarter panel--the tops of the aero flares should be about 2" higher to blend in with the creases of the rear quarter panel. Anyways, thanks for the info. Without this post, I'd be stuck in my garage for days trying to figure out what a "nipper" even was/is?!
Does anyone know how to install the side aero flares? I think they'd look better with the splash guards, vs. the rear aero flares. Not to mention that the splash guards are about $110 cheaper!
Old Oct 30, 2006 | 05:50 PM
jus7o's Avatar
i guess im the only one who had problems with the rear mud gaurds
story: when i was unbolting the bottom bolt the plastic retainer inside holding the nut came undone so i had cut out the screw and bolt. then j-b weld the nut back in the retainer to install the mud gaurd.
thank you J-B Weld
jay_tibo
22
Sep 13, 2016 08:10 PM
blackbirdrx8
Aug 11, 2015 07:45 PM
akagc
Aug 11, 2015 07:07 PM
AussieGray
Jul 16, 2015 03:58 AM
