Pettit Racing One of the most respected and accomplished names in Rotaries, Pettit Racing
Pettit's Protek-R Fuel Lubricant
Old Sep 27, 2007 | 11:29 PM
vIce^gRip's Avatar
Honor & Integrity
Cut Friction Gain Power
If we expect good longevity and top performance from our rotary engines, it is clearly evident that extra lubricant must be added to the fuel.
This is why; the oil metering system is responsible for lubricating the delicate apex seals, compression seals and housing surfaces that are common to every rotary engine. Oil is fed from the engine oiling system (oil-pan) to a variable ratio-metering pump, then it’s injected into the engine where it partially blends with the onrushing air-fuel charge, this incomplete blending and fuel-to-oil ratios of 400:1*and higher, are cause for alarm, but now add in unleaded fuels that are designed to clean piston engines, these fuels and the rotary’s high combustion temperature quickly clean away this small amount of oil leaving little or no lubrication. This causes increased friction and wear, resulting in decreased performance and longevity. With over 25 years experience and more than 1000 rotary engines built, we know excessive wear on apex and compression seals as well as critical housing surfaces is caused from inadequate lubrication and using today’s fuels. What’s all this mean? With out proper lubrication friction, heat and today’s fuels will likely cause premature failure of some expensive engine parts, great for Mazda’s profits but not good for you and me.
By reducing friction and wear Protek-R can extend rotary engine life by 30% or more, depending on your driving habits and consistency of use.
Protek-R blends completely with your fuel lubricating all these critical surfaces, this provides reduced friction and wear, adding longevity and keeping the power. Just what the rotary needs to last strong!!
In just one 24 hour race a Pettit Race Engine will get a lifetime of use and punishment, but since we mix Protek-R in the fuel they have little wear when compared to the average street engines we regularly disassemble. This is especially evident on turbocharged and high RPM rotary’s like the Renesis.
Pettit Built engines are the only turbocharged rotary engines in racing history to finish the grueling Rolex24 at Daytona, could Protek be a factor? We think so!
Here at Pettit Racing we know how fun and important it is to have a good running rotary engine and keep it running for many miles and years, that is why Protek-R was developed in the first place, to help keep your engine fresh.
For RX8 owners, some Renesis engines have weak or low compression**, Mazda says “heat generated friction” is the cause, but since factory recalibration for the RX-8 ECU increases injected oil for the high revving Renesis; could they just need some Protek-R to help cut friction and reduce wear? We think so and that’s what Protek-R does best.
By adding just 4 oz of Protek-R fuel lubricant with an average fill up of 10-12 gallons of fuel, the fuel-to-oil ratio is improved by 100%, or 200:1 and better, Cut Friction Gain Power, use Protek-R.
Order now! www.pettitracing.com
Phone: 561-844-2258
Fax: 561-844-2553
*Fuel to oil ratios are calculated by oil consumption / mile.
**Low compression can also result from catastrophic engine failures and overheating.
Copyright 2007 by Excellent Performance Inc. all rights reserved reproduction in part or whole prohibited .TKT, Trak Pro, PROTEK-R, R-Tec and Pettit Racing are Trademarks of Excellent Performance Inc. Palm Beach, FL.
Hunterkelley24
Jun 14, 2022 08:32 AM
RX8mzda
Oct 1, 2015 10:17 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
