2006 RX-8 Turbo Install Hose Routings?
Old Sep 23, 2007 | 03:56 PM
legendkurado's Avatar
img_2966, img_2968 and img_2970 are showing the hose routing from the oil filer neck to 2 nipples on the lower intake manifold on my 2006 RX-8. These 2 nipples on the LIM are capped from the factory on 2005 and lower models that I have noticed.
img_2972 shows 3 hoses that are either tee’d or directly connected to the 2 nipples on the intercooler intake tube. The top hose of the 3 is routed to the back and connected underneath to nipple just after the manifold in img_2974, img_2975 and img_2978. This 3rd hose is also not present on other RX-8s previous to 2006.
Overall, should any of these hoses be routed to tee’d any differently?
Thanks for your time and any help would be appreciated.
-legendkurado
Old Sep 23, 2007 | 10:27 PM
anyone?!?!
Old Sep 24, 2007 | 07:30 AM
rotorocks's Avatar
RotoRocks Powered
That should not be fed back into intake, or if it is, use a catch can to get read of oil.
Old Sep 24, 2007 | 10:21 AM
Speedrx8er's Avatar
I am going to assume you have the greddy turbo.
If you don't have a catch can. then the oil hose goes to one of the nipple on your pipe (see your pic). Remove the air meter (i think) hose and hook that up to where the air filter. The Greddy air filter will have a place where you can hook it up to.
Old Sep 24, 2007 | 03:03 PM
I've looked at the diagrams the greddy instructions show. I've also looked at other owner's install. 06 models seem to have an extra hose behind the alternator. Not to mention the hose are plugged a bit differently. I have an oil catch can, just not sure how it would work with that extra hose.
Old Sep 24, 2007 | 04:23 PM
Spinning Sushi's Avatar
I <3 Sushi
Originally Posted by ahhex8
Just some extra details to clear things up...
This is routed in this configuration from factory for his 2006 model. It goes from the oil filler neck to the 2 nipples on the lower intake manifold. On my 2005, my hose is routed to the rubber piece on the intake right before the manifold. Also, the 2 nipples on the lower intake manifold are capped on mine.
So the question would be, does he really need to install an oil catch can?
-Rob
Well, to be on the safe side, I'd install an oil catch can. FI applications sometimes worry me so I want to take as many precautions as possible.
Old Sep 25, 2007 | 10:48 PM
tell me about it.. i ahve the catch can with me.. i just not too sure which aiv's to use. The aiv's on older models are routed and positioned differently, which makes things a bit confusing.
Old Sep 25, 2007 | 11:43 PM
rotarygod's Avatar
Rather than feed the pipe back into the intake, I'd use the catch can instead and then just block off the manifold side of it. It's really hard to see detail in pictures and I'd have to see it in person. Unfortunately I won't make it out tomorrow night or I'd help you. I will probably be around most of the day on Sunday though so if you don't remedy it by then give me a call.
Old Sep 26, 2007 | 12:35 AM
remember this hose routing was done to help stop the "oil in the intake" issue. some earlier models have been retrofitted to this 2006 configuration
rotorocks
47
May 11, 2016 03:23 PM
uZu
Dec 30, 2015 12:35 PM
dbarber
Jul 25, 2015 01:34 PM
Love_Hounds
Jul 23, 2015 12:44 PM
