Battery terminals oxidation - fixing under warranty?
Old Sep 12, 2007 | 10:13 PM
hioctane's Avatar
Good day,
This is my fist post here
I never seen stuff like that before, terminal almost gone
Battery was installed 8/11/2005 by Mazda (this is "upgraded" 38lbs Interstate MTP 35).
I wonder why this happen and if it can be fixed under warranty.
Thanks,
Alex
Old Sep 12, 2007 | 11:00 PM
Silver_Surfer's Avatar
I4NI
Welcome
No Warranty. Its maintenance.
Good Day!
Old Sep 12, 2007 | 11:13 PM
WoW, where do you live? must be very humid no ?
they give you interstate battery ? I thought Mazda gave everybody a *Mazda rebrand Battery* ? Thats what I got. I dont have a problem with corrosive + Lead
Old Sep 12, 2007 | 11:14 PM
Jon316G's Avatar
Grasshopper
If you overtightened the terminal and placed strain on the post, this could have caused a vapor leak. Overcharging it could also produce that.
I would first give it a good cleaning. Be careful and wear gloves. Best to carefully remove the battery from the car before cleaning.
You could remove the terminals and clean it with sandpaper. Baking soda and water will help neutralize it. Might want to consider buying a new post if its real bad.
Once clean, apply some dielectric grease or vasoline to the terminal posts to keep the vapors away.
OR... do it the easy way and buy a new battery
Old Sep 13, 2007 | 01:22 AM
paulmasoner's Avatar
Asshole for hire
unfortunately i have seen worse a few times.... but how the HECK did you let it get that bad?? surely that cant build up in a months time?? poke around your motor, check up on things, takes 5 mins
Old Sep 13, 2007 | 10:12 AM
hioctane's Avatar
I have this car for about 7 months and have no idea how it was maintained before.
Paper from Mazda dealership says they installed new battery and spark plugs about two years ago.
Btw on my other cars terminals are lubricated with vaseline-like substance but it is clearly not the case with RX8.
It’s pretty dry here and I never ever seen stuff like that before.
Actually I was trying to replace battery with Optima Red Top 35 when discovered that stuff
Any ideas where to get new post?
Old Sep 13, 2007 | 10:18 PM
ken-x8's Avatar
You can't replace the post on a battery. It's built in. It's also lead, so corrosion will usually get the cable clamp, not the post. See how the top of the post looks clean, while the clamp is a mess?
Get a battery terminal cleaning brush. Just a few dollars. Clean post and the cable end, and go from there.
The vaseline-like substance you see on your other cars batteries would be vaseline. When you clean up that battery, coat the posts and clamps with vaseline. You can also buy anti-corrosion felt pads to put under the clamps.
Ken
Old Sep 13, 2007 | 10:46 PM
Jon316G's Avatar
Grasshopper
HAHAHA... I just read my own post. Thanks for catching that Ken-x8.
You are correct that the battery post can not be replaced. I meant to say the terminal might need to be replaced.
My bad
Old Sep 14, 2007 | 12:50 AM
ken-x8's Avatar
Originally Posted by Jon316G
HAHAHA... IMy bad
That's what web forums are for.
Alex - if that clamp does not clean up, replace the whole cable. Get one at a Mazda dealer, or at a good-quality auto parts store. You can buy just a clamp, or a shlocky cable at K-Mart or a low end parts store, but that will wind up being more trouble in the long run.
Ken
Old Sep 14, 2007 | 07:02 AM
Ken
I clean my battery terminals every season to ensure good contact. So I can put Vaseline on my terminals ?
Old Sep 16, 2007 | 11:49 AM
ken-x8's Avatar
Exactly. After you polish or claybar your car, don't you apply a coat of wax?
If you put vaseline on the terminals, you wouldn't have to clean them every season.
There are different opinions as to whether you should smear vaseline over everything after the terminals are on, or whether you should put vaseline on the posts and then put the terminals on. I've done it both ways, never noticed anything dramatic either way.
Ken
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
arexatemate
Oct 4, 2015 12:36 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
