Transmission Sound...any ideas?
Old Sep 5, 2007 | 10:33 AM
Raptor2k's Avatar
Club Marbles Member
My clutch has been slipping lately which is obviously a sign of wear. The pedal feels very soft (easily depressed) and the slipping occurs especially in 4th/5th/6th gears.
I've ordered a new ACT Clutch and Fidanza flywheel.
My worry, though, is that ever since the clutch slipping there's been an on and off whirring sound in the RPM range of about 2000-4000. It's there on some days, not on others. It sounds where the synchros whistling would normally come from, but instead, it sounds like an RC car....it doesn't sound natural at all. It happens when the RPMs are dropping (whether I'm just slowing down or engine breaking) and sometimes when I'm slowly accelerating.
The dealership told me that would have to take out the transmission to see what's going on, but no way am I paying them $650 for labor.
Any ideas as to what it is? Will the sound go away after I put in the new clutch?
Old Sep 5, 2007 | 05:43 PM
SoFL_RX8's Avatar
Former Owner
Id say wait untill the clutch is install untill you worry too much. If the sound goes away, good, it was the clutch, if not, take it to a tranny shop and see if they can diagnos the problem without dropping the tranny.
Personally I think its probably just the worn clutch, and I hope for your walletts sake it is! Good luck!
Old Sep 6, 2007 | 01:26 AM
Raptor2k's Avatar
Club Marbles Member
I hope so too, thanks.
37 views and 1 reply, great input.
Old Sep 6, 2007 | 01:39 AM
give me two.
miles?
Old Sep 6, 2007 | 01:46 AM
http://www.finishlineperformance.com...4-06-1641a.pdf
http://www.finishlineperformance.com...11-06-1724.pdf
make sure those are covered... but what you are talking about sounds like clutch is gone. mileage? or pp bolts loosening.. old problem, not likely...
Old Sep 6, 2007 | 01:59 AM
Raptor2k's Avatar
Club Marbles Member
40k, been through a lot of abuse, not surprised it's going out.
I got a new pressure plate so hopefully that clears it up.
I don't think it's related to any of those bulletins, thanks though.
I think I'm gonna go read about synchros, because basically, the whirring sound replaces the synchro's normal sound.
Old Sep 6, 2007 | 02:01 AM
i hope you got a new pp, clutch disk, to bearing, and input shaft bearing..
Old Sep 6, 2007 | 12:35 PM
Raptor2k's Avatar
Club Marbles Member
Release bearing and pilot bearigs are in the kit, are they the same ones youre referring to swoope?
Old Sep 7, 2007 | 03:34 AM
yep,
Old Sep 8, 2007 | 10:02 AM
SushiFan's Avatar
Dont know if my problem is a transmission problem. My ride is a 1 year old 4AT. I seem to be expriencing the following problem:
When it changes down from 3rd gear to 2nd, e.g. slowing down on approaching a hump and accelerating after that on 2nd. I tend to get a jolt even if I just gently tap the accelerator when accelerating out on 2nd gear. No problems accelerating on 1st or 3rd gear. Is this a gear box or transmission problem? Anybody can advise?
92trbolzr
May 18, 2025 09:04 AM
airlive
Jun 28, 2020 07:46 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
