NW RX-8 Forum Serving WA, OR, ID, AK
Center Dash Console Squeak
Old Aug 14, 2007 | 10:01 PM
pfbaseball's Avatar
Wondering if any of you have had a fix to this. I started having a chirpiing or "cricket" noise coming from the center console on the dash.
I've had it in the dealership probably 7 times at least for this... They fixed it once, then needed to replace the heater control unit, and it returned... It's been in twice since then. Last time, in for 4 days, (over the weekend) NEW heater control unit and the squeak is back.
They've been great at the dealership, putting new padding in the upper part, working on it, but have yet to fix the problem.
Ideas?
Thanks,
Paul
Old Aug 14, 2007 | 11:43 PM
kristopher_d's Avatar
Drive Master
We found it in Jisoo27's car. If you press on the piano black on the left edge, just below the CD slot, it goes away in his car. If you can make it squeak on demand, have a passenger start pressing around the edges until they find a spot that makes the squeak go away. You have to press pretty hard, but hopefully that will help you find it. It's probably lower on yours, 'cause it came after they replaced the climate controls.
Old Aug 20, 2007 | 06:39 PM
jisoo26's Avatar
RX-8 dreamer
It's jisoo26....26!!! rofl
Yeah it's in the upper left corner of the center console just below the left AC vent...if I press down on the plastic part of the dash right next to the piano black plastic, the cricket chirping goes away. Hopefully Lee Johnson can put in a lil' padding to make it go away.
Old Aug 21, 2007 | 10:18 AM
Drive Master
Woops. Sorry. Maybe you should come out for a drive and I might remember your handle. :p
Old Dec 10, 2007 | 05:16 PM
Detrich's Avatar
幹他媽!
crap... me too. when the car is cold it does that. after i drive around a bit and the cabin warms up the chirping goes away.
anyone know what's wrong or is it just cheap *** fabric/ materials/ plastic?
Old Dec 10, 2007 | 07:34 PM
pfbaseball's Avatar
chirp
I found out it was the cd player, just needed to be tightened in... It does it sometimes now, much less, and is no big deal.
Old Dec 10, 2007 | 07:40 PM
Detrich's Avatar
幹他媽!
how do u tighten the CD player? did the dealer do it or did u take it apart yourself? thanks for the help.
Old Dec 10, 2007 | 09:43 PM
jisoo26's Avatar
RX-8 dreamer
I took it to the dealership. They put in some extra padding but the chirp came back...it's especially apparent when it's cold. It looks like it comes from somewhere other than around the center console...I can't find it though. I wonder if it's actually *inside* the dash?
pfbaseball if you're around Seattle maybe we should get together and try to track this friggin' thing down...it driving me nuts
Old Jan 8, 2008 | 05:44 PM
jisoo26's Avatar
RX-8 dreamer
Dunno if anyone's still interested in this...
Sound seems to travel funny inside the RX8 cabin. I drove around for half an hour with my brother to try and track down this damn chirping noise. He swears that it's eminating from up on top of the center console (where the NAV would be) back towards the windshield. We both believe it's somewhere inside the dash...away from any exterior parts where one can press by hand to make it go away.
I have a better description for this "chirp" sound....it's rather a high pitched jingle...like a small washer rattling loose because the screw hasn't been tightened down all the way.
Mine's at Lee Johnson right now staying over night. They have an older tech there (Gary) who's fixed squeaks and rattles in all sorts of Mazdas, so I'm crossing my fingers that he can track it down and finally end the insanity.
Old Jan 8, 2008 | 11:17 PM
Luftwaffle's Avatar
I've had a chirping noise coming from the gauge cluster. I think it's a TSB now.
http://www.finishlineperformance.com...23-06-1596.pdf
Old Jan 9, 2008 | 05:36 PM
jisoo26's Avatar
RX-8 dreamer
Interesting, I don't know about the VIN but my car's a 2005 and obviously produced before 2/2/2006. I'll have to give the dealership a ring and see if they've seen this. Nice catch!
Old Jan 10, 2008 | 08:53 PM
jisoo26's Avatar
RX-8 dreamer
IT'S FIXED! It's the audio unit. The tech tightened every single screw on that audio unit cage. So glad the annoying squeak is gone!
ShellDude
Oct 1, 2015 09:55 PM
archon
Oct 1, 2015 06:08 AM
XianUnix
Sep 29, 2015 03:48 PM
FubarI33t
Sep 28, 2015 08:45 PM
