another BIG problem!
Old Aug 11, 2007 | 01:07 AM
c41250n's Avatar
so me and my friends went to the lake today, and on the way there, there are some twisties, so me and my friends are just having fun.....we were going up hill, driving driving.
all of a suddent, A LOT of smoke came out from my car, i wasnt from my exhaust, it was from under the car, so i pulled over and stoped, smoke just starting to come out from my dash, everywhere from the dash. so i turned of the car right away, and waiting for less then 30 seconds, i started my car up again, start driving. nothing is wrong, so i was just waiting for the smoke to clear up.
but after that i notice that my car feels really weird after 6k rpm, i dont know how to explain it, fuel cut, lose boost, or knocking.......i have no idea
even the night before it already felt kinda weird, but the car now drives fine under 6K rpm, its boosting, everything just acting very normal, but after 6K rpm, i just get some kinda fuel cut.
does anybody know whatz wrong?
thanks!
Old Aug 11, 2007 | 01:50 AM
RogueTadhg's Avatar
Living is best Modified.
I've always taken my corolla to the auto repair at any time the car 'feels' different. I just don't know anything about cars to know how to describe any difference in 'feel'.
In terms of the now-larger problem, I've got not clue.
Old Aug 11, 2007 | 02:28 AM
blew turbo seal... or weak seal.. oil got by... if you have a cat the oil clogged it...
one sign of a seal getting ready to go is it smokes on start up.. sound familiar?????
not a whole lot of info you have given..
Old Aug 11, 2007 | 08:37 AM
RogueTadhg's Avatar
I thought a cat back was exhast only? How could oil clog it?
Old Aug 11, 2007 | 01:06 PM
6dmnbg's Avatar
Hey,you,get off my cloud
Here's a couple questions
Do you still have a cat on?
How many mile have you ran the car with the turbo.
Turbo's don't last forever and you most likely blew the seal but you said that there is a loss of power at 6k which sound like a cat problem. Or mabey you just need to change your plugs.
Old Aug 12, 2007 | 02:24 PM
c41250n's Avatar
sorry for the lack of informations, cause i was in a rush to make this tread, i have been really busy lately!
btw...i have a gutted cat right now, and yes it smokes when my car first starts up.
i bought the turbo kit used, i bought it from Scott from mazsport, and he said it has lower then 10K miles, and i added around 2k miles.
i already changed my plugs which Scott recommanded me to used, the all trailing ones.
my car smokes when it starts up ever since i got the turbo kit put on, and i thought itz normal since a stock rx8 does that anyways.
the weirdest thing is, i has no problem with boosting below 6k rpm, and after 6k its just started to fuel cut for like every half a second. so i was thinking it might be my turning problem, but the car ran great for the last half year.
oh btw....we had driven for a while (about 70 miles) before we got onto the twisties, so the engine is probably all heated up already.
hope these informations helps
please ask if you have more questions
thanks a lot!
Old Aug 12, 2007 | 03:29 PM
whoneedspistons's Avatar
what engine managment unit are you using??? if the kit was form scott i assuming it comes with the intercepter.... have you had it tuned? did you check for any oil leaks? around the oil pan if your return line has a bung in the oil pan, check your oil feed line to make sure its tight enough... after 6k what type of symptoms are you experiencing... hesitation, sputtering???
Old Aug 12, 2007 | 09:13 PM
c41250n's Avatar
im currently running the greddy turbo kit which is used from Scott with the interceptor, it has been tuned for CA 91 gas.
what will happen if i do have a oil leak? cause i do have oil leak from the drain plug and the return line that goes to the oil pan which i havnt fixed.
what will the oil leak cause?
after 6k the car feels hesitation.
also, the smoke that comes out doesnt really smell, my friend said it might be the smoke from the coolent, maybe coolent got into the engine????? but if the coolent got into the engine, wouldnt the smoke be coming out from my tailpipe??
Old Aug 12, 2007 | 09:18 PM
unreal89's Avatar
I don't mind pistons
have you been checking your oil level, since you have a leak?
Oil leaks cause a mess...nothing else unless they drip on the manifold...then they are a smelly mess
Tuning could cause the hesitation..
Blue smoke is oil.....black smoke is fuel, and white smoke is coolant.
Usually coolant that is burning will give the exhaust a sweet smell
If you have coolant smoke...you will likely need a new engine ....
Hope this helps
Old Aug 13, 2007 | 12:55 AM
ProCharger GT's Avatar
a/s/l/n00dz?
I concur with what someone said above, sounds like some oil blew by a seal, causing said smoke. Your probably losing some boost, which is why it's not "feeling" right at 6K.
Old Aug 13, 2007 | 02:11 AM
if your stock rx8 smoked when you started it that is the root of the problem..
do you have the oil restrictor in the turbo line????
you might read this thread.. lots of good info.
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/definitive-greddy-turbo-fixes-here-they-81825/
Old Aug 13, 2007 | 02:36 AM
c41250n's Avatar
yes...i check almost every 2 days
Old Aug 13, 2007 | 02:46 AM
c41250n's Avatar
here is the thing, im still looking for someone or some shop who can help me put the oil restrictor on, i know itz seems easy to you guys....but i really have no clue how to install it.
my rx8 has some white smoke when it starts up cold when itz stock, just like all the other car does, my friend's stock rx8 does that too. after putting on the turbo, it has minor blue/white smoke coming out form my tailpipe when it starts up cold. my car is running with a gutted stock cat, so i can smell any sweet but some awful smell.
the day that my car was smoking, it wasnt from the tailpipe, my friend said it was from underneath my car, near the right side, so i think it is from the turbo.
so now i think i need to either get my turbo rebuild or upgrade to another turbo, but before i do that, i have to make sure it is the turbo that went bad. and also, i need to find a good place that can turn my car before i do anything about it. i might want to bring my car to LA to have it tune.
but i still want to make sure what cause my car to smoke, and nothing afterwards. i know i was kinda pushing my car on the twisties, but im planning to track my car, so i wont be good for a long run.
any info would help
thanks!
Old Aug 13, 2007 | 02:53 AM
sounds like you have an oil leak... you need to find someone that knows something about turbos / rotarys..
this is stuff you cant fix with typing...
good luck.
Old Aug 13, 2007 | 03:31 AM
Kane's Avatar
I agree with swoope, one thing you can do, tie the wastegate open on the turbo, that will lower your boost a bunch (since the wastegate will always be open). If the smoking stops or decreases it is a good bet the turbo needs to be rebuilt/fixed, whatever you want to call it. If it still smokes and from the same area, the oil feed or return LINE is likely leaking.
Cheap and easy test...might be worth it.
Old Aug 13, 2007 | 06:00 AM
so am i reading the post right that you have not had your car tuned other then the tuning that the int-x came with??? well that could be your problem... you could be getting hesitation from either not enough timing or to much fuel blowing out spark... the reason why you are most likely getting some smoke at 6k (now that there is more info out there) is your feeding the turbo with way to much oil (no restrictor) and its pooring out of the leak that you have... that does not mean you arent getting blow by because you most likely are... its an issue that should be addressed quickly so that you dont ruin your turbo and you are discusted at the whole fi thing....
the oil restrictor addition is a tough one due to the location of the turbo... so i cant really blame you for being hesitant... from my understanding you have to drop just about everything to get to the turbo
Old Aug 13, 2007 | 07:54 AM
a/s/l/n00dz?
If you haven't gotten a custom tune from a shop (i.e. mail-order tune, a chip that came w/ the turbo package) you may want to do that as well; let the shop know what is happening to your car, and I'm sure (if they are reputable) they have heard of it before. They would be able to dial in your car on a dyno much more efficiently than some standard computer map that the company designed.
Old Aug 13, 2007 | 09:01 AM
Kane's Avatar
Make sure your hardware is good first. If all is well, then work on the tuning side. You don't want to try and tune around a mechanical problem.
Old Aug 13, 2007 | 01:43 PM
olddragger's Avatar
while you are at it also check your coil packs--power lost at 6k is a classic sign for bad coils---they dont cause smoke however!
olddragger
Old Aug 13, 2007 | 03:36 PM
c41250n's Avatar
i have had mine tuned by a local store with CA 91 octane
i guess its the oil restrictor that i havnt put on!
so most likely i have to get my turbo rebuild?
Old Aug 13, 2007 | 03:37 PM
c41250n's Avatar
so anybody knows a good machenic shop in Nor Cal?
also, how do i know if the coils are bad? where do they locate?
Old Aug 13, 2007 | 05:51 PM
hmmm where in nc??? i know of a few places in that area and i can find someone if you would like... the turbo is probably still good in my opinion... i would listen to dragger though... deff check the coil packs... it could be a combination of problems... if the coil packs have a melting spot on the bottom... they are done and you need to replace them... i would post in the southern forum to see if anyone local to you knows of a specific rotar y shop
Old Aug 13, 2007 | 06:01 PM
mysql101's Avatar
You can install it in the line near the dip stick.
Old Aug 13, 2007 | 06:19 PM
c41250n's Avatar
i live in Daly City. let me know if you know any places that can help to fix my car.
btw..i've tried full function, i dont really like them!
good to know...i'll go check it out when i get home!
