Does your car overflow when you fill up? If so,...
Old Jul 30, 2007 | 09:46 PM
Illmatic's Avatar
See Jello? Say HELLO!
So, I have an '06 with the damn gas overflow problem. To anyone unfamiliar with this, what happens is at the pumps the gas nozzle doesn't cut off the fuel supply at the right time, and gasoline squirts out under pressure from the tank all over the side of the car. If you're **** like me, having your gas tank replaced at the dealer is not an option. Today, I found a solution.
When you are filling up, hold the gas nozzle at the downward-most pointing angle possible. What I mean is, don't rest it in the tank, but pull up on itas far as you can. By doing this today, I managed to hear the click and not have gasoline all over me and my car. I drove around, came back to the gas station and fit in 4L (certain doom) and it worked again.
[Sorry if this is old news.]
Old Jul 30, 2007 | 10:11 PM
ken-x8's Avatar
Sometimes mine overflows, too.
I usually have a good idea of how much gas I'll need. When I'm within a gallon or so of that, I'll put the nozzle down to the lowest setting. Most of the time that prevents overflow.
FWIW, the RX-8 is not the only car with this problem. I learned long ago to never stand in line with the filler neck while fueling. Always stand to the side.
Ken
Old Jul 31, 2007 | 12:06 AM
bruce_van's Avatar
Bruce Van
When I get gas, I make sure to get some paper towel and put it under the nozzle.
My car is so thirsty, it makes a mess when I feed it!
Old Jul 31, 2007 | 12:23 AM
rglbegl's Avatar
Baned
ONLY at Shell stations. Everywhere else is fine.
California has some BS evap. system on the nozzle
Old Jul 31, 2007 | 12:32 AM
refugeefrompistons's Avatar
Never had this problem, usually just buy $40 worth of gas. Only once have I completely filled up and it was at a Exxon (where I always go) and it clicked and I got my change within.
Old Jul 31, 2007 | 03:00 AM
Silver_Surfer's Avatar
I4NI
Only happens when using premium fuel. Try 87 octane fuel.
Old Jul 31, 2007 | 03:02 AM
I4NI
NICE *** I really like to see the rest of her.
SUKIEE
Oct 9, 2017 09:41 PM
D13
Aug 22, 2015 11:42 PM
CMRine04
Jul 29, 2015 02:07 PM
vssystemluba
Jul 19, 2015 04:16 PM
