MW RX-8 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS,
NASA Road America August 4th and 5th
Old Jul 23, 2007 | 10:33 PM
BlueRenesis82's Avatar
Registered Tracker
NASA Midwest is running August 4th and 5th, at Road America.
Shout out if you are coming!
Old Jul 23, 2007 | 11:01 PM
devildog1679's Avatar
I'm still talking to Erin about it. It's our Aniversary so I need to cater to what she wants.
Old Jul 25, 2007 | 10:10 AM
Red Devil's Avatar
Maybe...I'm not 100% whether I'll have my car back by then or not...will make it kind of difficult to get up there unless RSD or Mac are heading that way...I'd like to go, though.
Old Jul 25, 2007 | 11:24 AM
Registered Tracker
any idea when you will have a better idea?
Old Jul 25, 2007 | 01:54 PM
Red Devil's Avatar
I asked for my PCM to be returned right around or before that time...as such I don't think I'll know until the last second.
Old Jul 25, 2007 | 11:10 PM
Lets cross our fingers
Blue, you need to book your room I had a hell of a time getting a room. We decided just to get one ourselves being that it's our aniversary.
Old Jul 26, 2007 | 12:16 AM
Nick R's Avatar
06 Copper Red Shinka
I may end up coming up with some of my friends from Club3G to check it out. Dependant on whether or not I end up going to Iowa that weekend.
Old Jul 30, 2007 | 07:28 PM
Looks like rain this weekend I'll hold off on registration untill Thurs. in order to get a better idea of weather.
Old Jul 31, 2007 | 09:26 AM
Registered Tracker
You should come
Old Jul 31, 2007 | 10:26 AM
More_Revs's Avatar
I'd come watch, but I'm busy Saturday and have autocross Sunday.
Hey devildog, I'm going to the Madison Club autox at Fond Du Lac next Sunday if you want to join me.
Old Jul 31, 2007 | 12:41 PM
I may actually come by then. That's the 12th right? How much to participate?
Old Jul 31, 2007 | 01:36 PM
More_Revs's Avatar
$35 for non-member.
http://www.madisonsportscarclub.com/autocross/schedule/
Old Jul 31, 2007 | 01:40 PM
mac11's Avatar
Rotary , eh?
Wow, missed this thread. I guess we all know whats going on already though.
Old Jul 31, 2007 | 04:18 PM
You going to RA?
Old Jul 31, 2007 | 04:21 PM
mac11's Avatar
Rotary , eh?
I'll be there and I'll be working in some capacity.
Old Aug 1, 2007 | 10:31 AM
RedSheDevil's Avatar
.:. causing mischief
I'm there.
Old Aug 1, 2007 | 12:59 PM
OK great, we'll be there early Friday afternoon, I won't be driving until Sunday. Saturday we are doing some other things in celebration of 1 year of putting up with each other We may stop by at some point during the day on Saturday depending on what is going on.
On a side note, I have a possible stupid question. I noticed know that my steering wheel is no longer centered Meaning, that for the car to track straight the wheel is turned a little to the left? If I try to center it the car turns right? Do I need to get an alignment?
Old Aug 1, 2007 | 01:04 PM
mac11's Avatar
Rotary , eh?
Yes sir - most likely. Its possible a belt slipped in one of your tires or that they have worn unevenly. The uneven wear is HIGHLY unlikely since we just looked at them the other week and they were fine. Belt slipping or breaking is possible but you would probably be noticing a lot of vibration whenever you get over say 50mph(which we know you do...constantly). My guess is you got into a pothole that fubared something. talk to me about it at the track if you can find me.
Old Aug 1, 2007 | 01:11 PM
Ok, Thanks. One other question, I switched back to street pads after autobahn and now my brakes squeal. Not while braking but while wheels are turning with no brake pressure. Do you think the XP8's deposited some material that the stock pads can't scrape off thus causing the squealing. Do you think I can try some aggressive stops to see if that alleviates the issue?
Old Aug 1, 2007 | 01:16 PM
Registered Tracker
You really should have either 1 manuf. of pads, or different rotors. Otherwise the different pads materials will cause issues. I know, I have had that happen to me several times
Old Aug 1, 2007 | 01:24 PM
mac11's Avatar
Rotary , eh?
Either that or the track pads are worn further down that the street pads and the piston did not get pushed quite far enough back into the caliper causing the daily pads to rub on the rotors more than usual.
Old Aug 1, 2007 | 01:25 PM
Yea, I'm thinking next step is to get dedicated front rotors for the track.
Old Aug 1, 2007 | 01:30 PM
mac11's Avatar
Rotary , eh?
Or sandpaper. Sandpaper is much cheaper. .02
Old Aug 1, 2007 | 02:36 PM
Off to Home Depot then.
Old Aug 1, 2007 | 02:56 PM
mac11's Avatar
Rotary , eh?
make sure you don't get woodworking sandpaper. And something like 100-150grit should be sufficient.
