Turbo owners, fill this out please.
Old Jul 9, 2007 | 03:20 PM
Trekk's Avatar
Goat rider
Post Turbo owners, fill this out please.
I think this could be a good idea if we, compile info about the RX8 and turbos from around the world. So, I ask you to please fill out/answer as many of the questions as you can. This is more then just a "How much power can it make" thread. Below you'll find what I think to be all of the best questions to ask. (I might have missed some) Cut and paste then edit please.
Make year of car (motor if changed) -
Transmission type -
Average high and low temp in area of operation -
Altitude -
Fuel grade -
Oil type/grade -
Plug type/deg -
Miles on motor before turbo -
Miles with turbo -
Blown motors -
Reason / what broke -
Turbo kit -
PCM/ECU -
Lowest PSI and highest PSI you run -
Your normal operation PSI -
Shop tuned or self tuned -
Dyno'd HP/TQ (if you have) -
Fuel upgrades -
Cooling upgrades -
Exhaust type or diameter -
Cat or catless -
Driving style (DD/heavy foot/so on) -
Average time under boost per day -
Total cost (ball park) for turbo/install/tune -
Personal comments about your setup. (likes/dislikes)
Thanks.
Old Jul 9, 2007 | 05:42 PM
mysql101's Avatar
Sounds like a cool thing to have a summary of everyone's car... here's mine.
Car year: 2004 (built Dec 2003). Bought in April 2004
Transmission type: MT
Average high and low temp in area: 70 - 90F
Altitude: ~60 ft above sea level
Fuel grade: 93
Oil type/grade: 10w40 royal purple
Plug type/deg: NGK-5255
Miles on motor before turbo: 32,000
Miles with turbo: 20,000
Blown motors: 0
Turbo kit: Greddy with mazdamaniac GT3071R turbo upgrade
Fuel management: accessport
Lowest PSI and highest PSI you run: 6 psi, 12 psi
Normal operation PSI: 9 - 10 psi
Shop tuned or self tuned: MazdaManiac
Dyno'd HP/TQ: ~307 whp, 245 tq @ 9 psi
Fuel upgrades is any: OEM baby.
Cooling upgrades if any: mazmart water pump, AEM cai, 100% water in radiator w/ water wetter, greddy oil pan.
Exhaust type or diameter: full 3" ID turboxs
Cat or catless: catless
Driving style: aggressive
Total cost: About 4k installed, but it goes up to ~6-8k with all the other supporting mods (though many are not turbo specific)
see this page for a break down:
http://rotaryinsider.com/rx8-9.html
Old Jul 10, 2007 | 09:02 AM
ToM18nY's Avatar
Make year of car - 2004 Mazda Rx-8 GT, 13B Renesis.
Transmission type - 6 Speed MT.
Fuel grade - Mobil 93 Octane.
Oil type/grade - Mobil 5w30.
Plug type/deg - NGK - 5255 (bur9eqp).
Miles on motor before turbo - 13,000.
Miles with turbo - 8,000
Blown motors - None.
Turbo kit - GReddy (T618z), Fix #2, Upgraded Silicone Couplers / Hoses.
PCM/ECU - GReddy E-Manage Ultimate (Rx-8 Specific).
Electronics - Boost Gauge, Boost Controller, Turbo Timer, Wide Band Air Fuel.
Lowest PSI and highest PSI you run - 5 PSI - 7 PSI.
Your normal operation PSI - 5 PSI.
Shop tuned or self tuned - Shop Tuned, KDR Performance.
Fuel upgrades - None.
Cooling upgrades - GReddy Oil Pan, K&N Air Filter.
Other - GReddy Oil Catch Can, Oil Line Restrictor Funnel Jet .049.
Exhaust type or diameter - Racing Beat REV8 3" Cat Back.
Cat or catless - Racing Beat Dual Resonated Midpipe.
Driving style (DD/heavy foot) - Daily Driver, Calm...
Old Jul 10, 2007 | 09:12 AM
rotorocks's Avatar
RotoRocks Powered
Make year of car (motor if changed) - 2005
Transmission type - MT
Average high and low temp in area of operation - 55F/110F
Altitude - Sea level or so...
Fuel grade - 93
Oil type/grade - 10W30 Fully Synthetic Mobil / Premixing with 2 cycle synthetic Mobil
Plug type/deg - Stock NGK
Miles on motor before turbo - 20K
Miles with turbo - Over 20K
Turbo kit - Remote Mounted by me (RotoRocks Induction) :-) Mid mounted T3/T04B (.63AR turbo, .60AR compressor) turbocharger
PCM/ECU - Interceptor-X
Lowest PSI and highest PSI you run - 5-16
Your normal operation PSI - 12PSI
Shop tuned or self tuned - Self
Fuel upgrades - Restaged Stock Injectors
Cooling upgrades - Extended 10' copper turbo feed and 10' drain oil lines. DIY Vented Hood (Weather strip Removed. Hood cover raised )
Stock Muffler. + High Flow Cat on a 3" mid/downpipe
Cat or catless - High flow Cat
Driving style (DD/heavy foot/so on) - DD with 60 miles/day highway 35/street, stomping the pedal every chance I get :-)
Average time under boost per day - Who is counting?
Vehicles Fallen Pray to me: Mercedes SL500, Carrera 911 , latest model 340HP Audi S4 ... The more I tune, the faster she gets
Total cost (ball park) for turbo/install/tune - It depends on specifications.
Blown Motors - 1
Reason, what broke - Apex seal failure on the rear rotor.
Old Jul 12, 2007 | 12:28 PM
RPIRX-8's Avatar
Apexing at Oak Tree
My car is still @ Synaptic3 getting the kit and other goodies installed
Make year of car (motor if changed) - 2004
Transmission type - MT with ACT Prolite Flywheel and Heavy Duty Clutch
Average high and low temp in area of operation - mid 60s to prob 90
Altitude - anywhere between sea level (Boston area) and 2500 ft (New England north country)
Fuel grade - 93 octane Mobil or Shell
Oil type/grade - Castrol GTX 5w20 though may switch
Plug type/deg - stock type for now
Miles on motor before turbo - 74k
Miles with turbo - 0 so far
Blown motors - none
Turbo kit - GReddy
PCM/ECU - eManage Blue with definitive fixes
Lowest PSI and highest PSI you run - 5-10
Your normal operation PSI - 6-7
Shop tuned or self tuned - shop tuned
Dyno'd HP/TQ (if you have) - coming soon
Fuel upgrades - none yet
Cooling upgrades - custom heat shield wrapping around vital lines, Koyo Radiator, Setrab oil coolers (1.5x larger than stock), custom CAI
Exhaust type or diameter - B&B catback
Cat or catless - high flow cat
Driving style (DD/heavy foot/so on) - 10-12 track days a year and weekend driver
Total cost (ball park) for turbo/install/tune - with everything mentioned here, 9k
Old Jul 12, 2007 | 01:00 PM
MazdaManiac's Avatar
Make year of car (motor if changed) - 2004 (2004)
Transmission type - Manual 6 Speed
Average high and low temp in area of operation - 115°/65°
Altitude - 1200 ft
Fuel grade - 91 AKI
Oil type/grade - Castrol GTX 20w-50
Plug type/deg - NGK BUR9EQP (LEADING) NGK RE9BT (TRAILING)
Miles on motor before turbo - 15k
Miles with turbo - 130,000
Blown motors - 2
Reason / what broke - #1 260°coolant temp/120°F ambient/14PSI #2 WG failure
Turbo kit - MazdaManiac/BHR Upgraded GReddy - Garrett GT3076
PCM/ECU - Cobb AccessPORT
Lowest PSI and highest PSI you run - 7 PSI - 14 PSI
Your normal operation PSI -9 PSI summer, 14 all other
Fuel upgrades - 900cc P2/ 780cc sec
Cooling upgrades - BHR radiator, top-mount intercooler
Exhaust type or diameter - BHR Midpipe, Custom CAT-back
Cat or catless - NO CAT
Driving style (DD/heavy foot/so on) - Passive Agressive
Average time under boost per day - whenever I am accelerating
Total cost (ball park) for turbo/install/tune - ??
3 Year Update. lol
Old Jul 12, 2007 | 08:24 PM
Rotorpsycho's Avatar
Seen my car keys?
2003 4 port.
Transmission type -
5MT
unknown
Altitude -
Sea Level
Fuel grade -
95 unleaded
Oil type/grade -
Mobil S
Plug type/deg -
Factory
17,000km
Miles with turbo -
9,000km
Blown motors -
Turbo kit -
custom
PCM/ECU -
Microtech LT10
4psi - 8psi
8psi
shop
250hp
Fuel upgrades -
pump, 440&550cc injectors
Cooling upgrades -
No upgrades, modified fan run.
Factory
Cat or catless -
Catless
very aggressive
US$15,000
Old Jul 13, 2007 | 03:41 PM
LiL BenNy's Avatar
Bubblicious? DEF.
i shall play....
Transmission type - mt 6spd
Average high and low temp in area of operation - idk
Altitude -idk
Fuel grade - 93 shell/ sunoco
Oil type/grade - castrol gtx 5w20
Plug type/deg - forgot.. which ones...
Miles on motor before turbo -idk
Miles with turbo - now... approaching 33k
Blown motors -0
Turbo kit -greddy
PCM/ECU - INTX
Lowest PSI and highest PSI you run -7-9
Your normal operation PSI -7
Shop tuned or self tuned -JPR IMPORTS
Cooling upgrades - greddy oil pan.. oil catch can if that counts?
Exhaust type or diameter - greddy sp2
Cat or catless -rx8store resonated midpipe
Driving style (DD/heavy foot/so on) - 85% dd 15% aggressive ( i like to chase down evo's... lol)
Average time under boost per day - 40%?
Total cost (ball park) for turbo/install/tune - 7k? ish?
my mpg effing blows.. i think im the only one whos FI with 12mpg at 7psi driving conservative?
Old Jul 13, 2007 | 04:14 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Make year of car (motor if changed) - '04
Transmission type - AT
Average high and low temp in area of operation - 115/50
Altitude -1200
Fuel grade -91/premix
Oil type/grade - 10w30 Royal purple w/ TX-7
Plug type/deg - NGK BUR9EQP/ NGK RE9BT
Miles on motor before turbo - 43K
Miles with turbo - 12k
Blown motors - 0
Turbo kit - Greddy
Lowest PSI and highest PSI you run - 4 - 9
Your normal operation PSI - 7
Shop tuned or self tuned - MM and UMS tuning
Dyno'd HP/TQ (if you have) - 185 Hp/242tq @ 5psi
Fuel upgrades - 480cc Secondaries
Cooling upgrades - Manual Fan control/ Purple Ice/ BHR Radiator
Exhaust type or diameter - 3" HKS Hi-Power
Cat or catless - RP hiflo (soon 2b meowless)
Driving style (DD/heavy foot/so on) - Weekend/ LEAD FOOT
Average time under boost per day - not enough
Total cost (ball park) for turbo/install/tune - $2600 Nice to have friends w/ shops
It's got paddles and is 1 of 2 boosted AT's in the States.
And chicks dig it!
Old Jul 16, 2007 | 01:47 PM
unreal89's Avatar
I don't mind pistons
Make year of car (motor if changed) - 2004 Base model
Transmission type - 6MT
Average high and low temp in area of operation - no idea
Altitude - 150 feet above sea level
Fuel grade - 91 octane Shell or Chevron
Oil type/grade - 5w30 Royal Purple
Plug type/deg - NGK BUR9EQP (all 4)
Miles on motor before turbo - 5500
Miles with turbo - 4000
Blown motors - 0
Reason / what broke - N/A
Turbo kit - Greddy Kit w/ Mazsport upgraded compressor
PCM/ECU - Int-X Ver 3.0
Lowest PSI and highest PSI you run - stock (6-7 psi)
Shop tuned or self tuned - Stock int-X map (I think)
Dyno'd HP/TQ (if you have) - N/A
Fuel upgrades - N/A
Cooling upgrades - N/A
Exhaust type or diameter - TurboXS 3" turboback
Cat or catless - Catless (soon to be changed)
Driving style (DD/heavy foot/so on) - DD, not very aggressive
Average time under boost per day - No idea
Total cost (ball park) for turbo/install/tune - $5000 give or take
Old Jul 23, 2007 | 05:42 AM
RXVIII's Avatar
Zoom Zoom Zooooooomm Psst
Make year of car (motor if changed) - Built Nov 2004 (Aust Spec)
Average high and low temp in area of operation - 5-40oC (41-104oF)
Altitude - 434 feet above sea level
Fuel grade - 98 RON
Oil type/grade - Semi-synthetic SAE 10W-50 now Red Line 10W40
Plug type/deg - NGK (not sure model(s))
Miles on motor before turbo - 50,000 km (31,000 miles)
Miles with turbo - 10,000 km (6,000 miles)
Blown motors - none
Turbo kit - PROMAZ
PCM/ECU - Microtech LT10S
Lowest PSI and highest PSI you run - 8 psi
Your normal operation PSI - 8 psi
Shop tuned or self tuned - Shop (PROMAZ)
Dyno'd HP/TQ (if you have) - 205 kw (275 hp) @ wheels
Fuel upgrades - Larger Injectors
Cooling upgrades - 2nd Oil cooler, PWR Radiator (For track reasons!)
Exhaust type or diameter - 3 inch (custom but like magna flow)
Cat or catless - Hi Flow SS Cat
Driving style (DD/heavy foot/so on) - Road std to hard, Track HEAVY!
Average time under boost per day - Don't know
Total cost (ball park) for turbo/install/tune - Kit AUD12,000 (<US10,000)
Love the power & torque. Economy similar to NA (unless you burn rubber all the time)
Only issue appears that it develops a slight hesitation only on very light throttle @ appox 4000rpm. Seems OK on first tune.
Old Jul 24, 2007 | 03:28 AM
zOiS's Avatar
Make year of car (motor if changed) - Make 9/06 Owned since 4/4/07
Average high and low temp in area of operation - L40 H115 AV75
Altitude - 50-100m
Fuel grade - 95
Oil type/grade - Motul 300V 10-40
Miles on motor before turbo - 7500 Km
Miles with turbo - 2000 Km
Blown motors - 0
Turbo kit - Greddy TK w/fix#2 & Turbosmart Supersonic BOV
PCM/ECU - EMU with rewired ignition
Lowest PSI and highest PSI you run - 4-5
Your normal operation PSI - 4-5
Dyno'd HP/TQ (if you have) - ?
Fuel upgrades - ?
Cooling upgrades - planned
Exhaust type or diameter - Stock without front resonator
Cat or catless - 200cpi aftermarket CAT
Driving style (DD/heavy foot/so on) - 40dd 60hf
Average time under boost per day - ?
Hope I had shares of Bridgestone and Shell
Old Jul 24, 2007 | 08:54 AM
RX8FOREAL's Avatar
Captain Spaulding
Make year of car (motor if changed) - 2004 (reman 2004)
Transmission type - 6 MT
Average high and low temp in area of operation - AVG L30/H80F
Altitude - 1100 ft - my home to ~ 200ft above sea level
Fuel grade - 93
Oil type/grade - RP 5-30W
Plug type/deg - NGK-5255
Miles on motor before turbo - ~20k
Miles with turbo - ~50k
Blown motors - 1
Reason / what broke - My tune
Turbo kit - Greddy
PCM/ECU - Int X
Lowest PSI and highest PSI you run - 6/ 10
Shop tuned or self tuned - was shop tuned, now self tuned
Dyno'd HP/TQ (if you have) - 235 RWHP
Cooling upgrades - Mazsport cooling mod
Exhaust type or diameter - SR Motorsports
Cat or catless - SR Motorsports high flow w/resonator
Driving style (DD/heavy foot/so on) - NJ style
Total cost (ball park) for turbo/install/tune - ~ 15k including replacement motor
Old Aug 3, 2007 | 11:04 AM
Kane's Avatar
Make year of car (motor if changed) - 2007 RX8
Altitude - 0 to 1100 Feet
Fuel grade - 93 Premium
Oil type/grade - 5W20 - 5W30
Miles on motor before turbo - 100
Miles with turbo - 1000
Blown motors - 0
Reason / what broke - NA
Turbo kit - Greddy
PCM/ECU - EManage Ultimate
Lowest PSI and highest PSI you run - 0-7 PSI
Your normal operation PSI - Unknown
Shop tuned or self tuned - Stock tune, but soon to be tuned by my software
Dyno'd HP/TQ (if you have) - NA
Fuel upgrades - NA
Cooling upgrades - NA
Exhaust type or diameter - 3" Catback Greddy
Driving style (DD/heavy foot/so on) - Lead Foot when I can, wife... medium lead foot
Average time under boost per day - Less than 1 hour
Personal comments about your setup. (likes/dislikes) - Ron's Perf did a great job of installing, factory looking install. Never drove it NA, but with Turbo it is perfectly fast for me, has a lot of get up and go compared to my old 68 Mustang GT, 98 Cavalier RS with 350 Crate Motor, 87 300ZX Turbo (all stock). I think overall the fastest to drive of the three on the street.
Old Aug 5, 2007 | 02:44 PM
6dmnbg's Avatar
Hey,you,get off my cloud
Make year of car (motor if changed) -2004 gt
Transmission type -6spd manual
Average high and low temp in area of operation -105-60
Altitude -118 above sea level
Fuel grade -mix of 91 and 100
Oil type/grade -Royal purple 10w-30
Plug type/deg -stock
Miles on motor before turbo -on old motor 49000 on new motor 0
Miles with turbo -old motor 1000 new motor 13000
Blown motors -1
Reason / what broke - Bad tunning/apex seals
Turbo kit -greddy
PCM/ECU -Emanage ultimate
Lowest PSI and highest PSI you run -5psi-7psi
Your normal operation PSI -6psi
Shop tuned or self tuned - both
Dyno'd HP/TQ (if you have) -have not
Fuel upgrades -none
Cooling upgrades -none
Exhaust type or diameter -turbo back 3 inch
Cat or catless -catless
Driving style (DD/heavy foot/so on) -daily driver, baby it, weekend racer
Average time under boost per day -almost never unless I'm at the track
Total cost (ball park) for turbo/install/tune - around 13000
I like it
Old Sep 5, 2007 | 07:22 PM
Dalton30's Avatar
Drive the Revolution
Average high and low temp in area of operation - -20/+30 C
Fuel grade - 98 RON
Oil type/grade - Mobil 1 0W50
Miles on motor before turbo - 8000 km
Miles with turbo - 7000 km
Blown motors - 0
Turbo kit - Greddy
PCM/ECU - E-manage Blue (will upgrade to Ultimate soon)
Lowest PSI and highest PSI you run - Default
Shop tuned or self tuned - Local Mazda dealer
Fuel upgrades -
Cooling upgrades - Greddy oilpan
Exhaust type or diameter - stock
Cat or catless - HiFlow Cat
Driving style (DD/heavy foot/so on) - Damn Speed limits
Average time under boost per day - 10
Total cost (ball park) for turbo/install/tune - A lot
Got bunch of upgrades to install - just not enough time.
Old Feb 8, 2008 | 04:09 AM
SWVA_RX-8's Avatar
Purge Addict
----------------------------------------------------2005----------------------------
Transmission type -
---------------------------stock with exedy stage 3 clutch & Pressure plate and Act Prolite flywheel-----------------------------------------------------
Average high and low temp in area of operation -25F to 65F now Summer 60F to 85F
Altitude -2300 ft above sea level
Fuel grade -93
Oil type/grade - Pennezoil Pure Platatimum 5W-20
Plug type/deg -NGK 5255 all 4
Miles on motor before turbo -21,000
Miles with turbo -8-9K
Blown motors -0
Turbo kit -Greddy
PCM/ECU -Int-X
Lowest PSI and highest PSI you run -6psi to 13 psi
Your normal operation PSI -8psi to 11psi
Shop tuned or self tuned -Mazsport
Dyno'd HP/TQ (if you have) -302HP 292 TQ with a GTech SS
Fuel upgrades -Mazsport's Fuel pump and Mazsport's Big Injectors
Cooling upgrades -koyo full aluminum Radiator with wetter water and Mazsport cooling fan mod
Exhaust type or diameter - 3inch Greddy Sp2 Modified,RX& catless mid-pipe
Cat or catless -Catless
Driving style (DD/heavy foot/so on) -9K every gear all the time til at crising speed very aggreissive
Average time under boost per day - 80% of the time
Total cost (ball park) for turbo/install/tune -around 12,000 with all other turbo accesories and parts
Mazsport's support, products and staff are superb!!! The Int-X is the best to ever happen to my 8!!!!!!! Also, if your not turbo'ed you don't know how much fun you are missing!!!!LOL!!!!!!
Old Feb 27, 2008 | 10:18 PM
steven000e's Avatar
I will forever miss my 8!
2004
Transmission type -
6 spd
10° to 100° Fahrenheit
Altitude -
Not sure
Fuel grade -
93 octanes
Oil type/grade -
Royal purple 5w30
Plug type/deg -
NGK-5255
38k
Miles with turbo -
41k
Blown motors -
0 and I pray every night to keep it that way!
N/A
Turbo kit -
Greddy with few custom tubing parts
PCM/ECU -
EMU for 5 months however I replaced it with the Interceptor X
8 psi and 12 psi
10 psi
RX7 store
Fuel upgrades -
None yet but planning on new larger Injectors
Cooling upgrades -
None
Stock Cat back
Cat or catless -
High flow Cat
DD when weather allows
Few times when I need to
Greddy RX-8 Turbo Kit, Greddy Profec B (boost controller), reducers/couplers/hoses, Turbo XS blow off valve, Gauges: Air Fuel Ratio (AEM Uego Kit), Boost Gauge, Greddy 52mm Electric Boost, EGT gauge, oil pressure, NGK-5255 Sparks plugs, Installation, Tuning, GReddy oil pan upgrade, Interceptor X EMS, Custom parts , etc, etc , etc….
Around 7 to 8 k
I like it
but I live terrified that something will brake and I will lose everything…..
I don’t have any place that works on rotaries around so if something does happen…. I will be done!
Old Mar 21, 2008 | 08:17 PM
kiet1's Avatar
Make year of car (motor if changed) - 2005 Limited Edition
Transmission type - Standard 6 Speed Still Using Standard Cluth Today
Average high and low temp in area of operation - Oil Temp daily driving 70 Track 110. Water Temp Daily Driving 90 Track 120
Altitude -
Fuel grade - 98 - 100 octane
Oil type/grade - Full Synthetic Royal Purple can't remember but i think it's 5-40w
running rotary mineral oil daily driving temp is always 95-100
Plug type/deg - standard plugs but changed for the 3rd time now i'm at 40,000kms
Miles on motor before turbo - 20,000kms
Miles with turbo - 20,000kms
Blown motors - front seal where engine connects to the omp broke so i put my spare engine in
Turbo kit - Trust Turbo Kit
PCM/ECU - Xede ECU
Lowest PSI and highest PSI you run - low PSI 7 high PSI 14
Your normal operation PSI -normally run 12psi
Shop tuned or self tuned - self tuned at a friends shop.
Dyno'd HP/TQ (if you have) - 220kw on 14psi no idea on torque
Fuel upgrades - bigger fuel pump, reg, return line, fuel filter, a pair of injectors changed for the auto injectors
Cooling upgrades - Bigger Custom Radiator, Bigger Front Mount, HKS oil cooler, Trust Oil Pan, Billion Fan controller, Custom Fully enclosed intake box, Trust Breater Bottle, Intercooler & Oil Cooler water sprays
Exhaust type or diameter - HKS Legamax Catback with Custom 3inch Piping to Turbo
Driving style (DD/heavy foot/so on) - dont get to drive my car much it's always in the damn shop. alot of the KM's on the car are from the Dyno and road tunes.
Average time under boost per day - no idea very random.
Total cost (ball park) for turbo/install/tune - Trust Kit was 5500AU install for that was i think 1500 or 2000 can't really remember so long ago.
HKS blow off 400AU Blitz SBC ID3 was 650 which is now replaced with the IColor which is 850, Bigger Intercooler piping and custome 3" exhaust piping with removal of cat 1500, Xede ECU with Patch Harness and tune 2000,
Trying to get more power out of it but dont know what to do now.
I have a spare engine which i'm goign to rebuild stronger and probalby stick a HKS TO4Z on it my friend and i are debating about whether or not we should get rid of the intake manifold with the flaps or keep it i want to keep it cause i think that is what gives the car no lag when you hit the pedal. need to get a stand alone ecu in but waiting to we build the engine first.
the wastegate spring on the Trust turbo is crap so we put a stronger spring to help it hold boost better.
even with a bigger radiator car has a slight water cooling issue.
can only do a few laps at a time before water temp is too high.
once the turbo was put on had to change my brake setup right away.
car was not stopping well.
Old Mar 27, 2008 | 08:36 PM
bboieddie's Avatar
Make year of car (motor if changed) 04'
Average high and low temp in area of operation - 46/31
Altitude - 170 feet above sea level
Fuel grade - 93
Oil type/grade - 5W30 Mobile1
Plug type/deg - NKG BUR9EQP8 (All Trailing)
Miles on motor before turbo - aprox. 26000
Miles with turbo - 200+
Blown motors - None (Thank God)
Turbo kit - Greddy Turbo
PCM/ECU - EMU
Lowest PSI and highest PSI you run - Low 4/High 6
Shop tuned or self tuned - Shop tuned (Ptuning)
Dyno'd HP/TQ (if you have) - TBA
Cooling upgrades - None
Exhaust type or diameter - Greddy SP2
Cat or catless - stock cat
Driving style (DD/heavy foot/so on) - Grandma lol
Average time under boost per day - Not very much
Total cost (ball park) for turbo/install/tune - 3300 for the kit + 1200 for install and tuning
I love it!!!
It's just enough power for me.
Oh and many thanks to Ptuning. Great job
Old Mar 29, 2008 | 12:31 AM
rx-81688's Avatar
Make year of car (motor if changed) - Mazda rebuiled motor
Average high and low temp in area of operation - 50 - 90
Altitude -?
Fuel grade - 91
Oil type/grade - N/S 5w30
Plug type/deg - stock NGK (5255)
Miles on motor before turbo - 0
Miles with turbo - 15k
Blown motors - 1
Reason / what broke - my own map
Turbo kit - greddy
PCM/ECU - HKS V-PRO
Shop tuned or self tuned - Shop. (SGP Racing)
Cooling upgrades - none
Cat or catless - RP super cat
Driving style (DD/heavy foot/so on) - easy after new engine
Average time under boost per day - from time to time
Total cost (ball park) for turbo/install/tune - includ motor, it's about 13k
Old Mar 29, 2008 | 12:40 AM
$13k for 4 PSI and you popped a motor?!?
Old Mar 29, 2008 | 02:37 AM
rx-81688's Avatar
yeah! when i first got the turbo, i tho that i know everything, and drive the car like a stupid ***! and when the engine blown on the side of the road, i did't even think it's engine problem, so i was try to run spark and fuel test myself. think about it now i feel very stupid! LOL
Old Jun 7, 2008 | 05:05 PM
ChattyRX8's Avatar
Now turbo!
I am the newest member to the FI club! Here's what I have....
Make year of car (motor if changed) -2005 w/ original motor
Transmission type - manual
Average high and low temp in area of operation - 85*F hi 40*F lo
Altitude - ~300 ft. above sea level
Oil type/grade - Castrol GTX 20w50 dino oil
Plug type/deg - Rx7 plugs with shims
Miles on motor before turbo - 56k and some change
Miles with turbo - ~700
Blown motors - zero so far
Turbo kit - GReddy
Lowest PSI and highest PSI you run - 4 psi lo and 9 psi hi
Your normal operation PSI - 5 or 6 psi
Shop tuned or self tuned - Scott at Mazsport
Dyno'd HP/TQ (if you have) - 250 whp and 216 tq
Cooling upgrades - Mazsport cooling fan mod
Cat or catless - see above
Driving style (DD/heavy foot/so on) - average with occasional lead foot
Average time under boost per day - less than 50%
Total cost (ball park) for turbo/install/tune - $7000, including a new clutch
I'm liking it so far! Tons of fun! Scott claims I can instantly get another 20whp by going with an aftermarket exhaust, so that will probably be my next purchase.
Old Oct 25, 2008 | 04:03 AM
GaMEChld's Avatar
Registered Noob
Transmission type - Stock 6 Speed Manual
Average high and low temp in area of operation - 80-90ish summer 20-40ish winter
Altitude - sea level
Fuel grade - 93 Octane
Oil type/grade - Royal Purple 10W-40
Plug type/deg -
Miles on motor before turbo - 45K
Miles with turbo - 10K
Blown motors - 0
Reason / what broke - n/a
Turbo kit - Esmeril Racing
Lowest PSI and highest PSI you run - (13.5-14) approx
Your normal operation PSI - (13.5-14) approx
Shop tuned or self tuned - Esmeril Base Map
Dyno'd HP/TQ (if you have) - n/a (tuning soon)
Fuel upgrades - Esmeril Stage 1 (Kit Supplied) [Fuel Pump + 2x1000cc secondary injectors]
Cooling upgrades - Removed Grill + Bumper Support
Exhaust type or diameter - TurboXS Full Headerback 3" ID
Driving style (DD/heavy foot/so on) - Daily Driven, Very Spirited
Average time under boost per day - Probably 2-3 minutes or so total per day, not sure
Total cost (ball park) for turbo/install/tune - $7000 (Kit+EMS+Ignition Upgrade) [self-installed + not yet tuned]
Wastegate location on Esmeril Racing Kit is a bit low to the ground, lowered cars might run into problems. TurboXS Catback hangs pretty low to ground near the differential fins as well. Other than that, so far so good. Will update once tuned.
Update: 4/1/09 - Been about 10K miles now, still running.
