A/C ECO mode
Old Jul 7, 2007 | 12:43 PM
andreasy's Avatar
A/C ECO mode
I have noticed that nexro to the air-condition light, there's an ECO light. Very rarely I've notice that it was on but I haven't managed to understand the conditions under it's on. Is there a way to manually enable economy mode for a/c?
Old Jul 7, 2007 | 12:47 PM
StealthTL's Avatar
Sorry......
You have a JDM model, we don't get that light in North America, & can't help you.
S
Old Oct 13, 2019 | 10:27 PM
Shepherd's Avatar
While this is an old question but it may assist others in future
the eco mode as mentioned by stealthtl is available on jdm models. But also Australian delivered models. Unknown for uk models but also possibly a possibility.
like some other systems it’s shared with other Mazda models such as the 3 and 6.
it will reduce the aircon engine load during times of higher engine use.
it’s most noticeable during acceleration and will act as if the Ac is turned off or severely reduced, resulting in a noticeably quicker acceleration and throttle response.
to activate this mode the ambient outside temperature will need to be below 24 or 25 degrees Celsius (to be tested at a later date)
to engage eco mode, as displayed between the a/c and auto indicators on the central dash lcd, you will need to change air flow from recirculated to external airflow. (the button below mode on the Ac controls)
eco mode and auto can be used together.
sam heights
26
May 8, 2011 03:14 PM
EinHeisserSchrei
Feb 16, 2010 01:34 PM
delhi
Jun 27, 2007 04:39 PM
ZimSilver05
Mar 7, 2006 04:12 PM
richie
Aug 12, 2004 04:54 PM
