ABS light on
Old Oct 3, 2003 | 02:41 AM
mikeb's Avatar
100% Italian
ABS light on
Last night my car was running for like 15 minutes while I was in garage and out of blue the ABS light and the light with skid marks came on at the same time-----------WTF
Old Oct 3, 2003 | 05:24 AM
B-Nez's Avatar
I'd be willing to bet it's because of the self test. Remember how the system does a check when you first put it into gear and move? Perhaps because it idled for 15 minutes, it never did that check and then threw a trouble code. Has the light come on again since then?
Old Oct 3, 2003 | 11:44 AM
mikeb's Avatar
100% Italian
I think your right
I went to bed and started the car this moring and both lights were gone
Old Oct 3, 2003 | 04:13 PM
B-Nez's Avatar
I can see why they would have simply used a timer for the self-check, rather than adding an extra chunk of logic to determine if the car has moved and the self-test not accomplished. Wil have to look that one up when I get my manuals and stuff.
Old Oct 3, 2003 | 08:29 PM
mikeb's Avatar
100% Italian
thanks bnez
Old Oct 24, 2003 | 05:53 PM
Omicron's Avatar
If it happens again, I'd definitely get the car to the dealership to be looked at. The manual specifically states that if you get ANY of those lights on when they should have come on, it means you have a problem in that subsystem. Just my 2 cents.
RX-8 Racing
20
May 14, 2016 06:25 PM
xAgyex
Sep 28, 2015 08:54 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
