Strange thing happened this morning
Old Jun 25, 2007 | 10:25 AM
Gambit's Avatar
Screw gas mileage
As i was driving in to work this morning, going around an onramp from one highway to another (somewhat fast, maybe 50) my ABS, Ebrake, and traction control lights all popped on. The car drove fine, i checked the emergency brake to ensure that it was off, so I decided to pull over. I shut off the car and gave a quick look, turned it back on and everything was fine.
Anyone see this or have an idea what may have happened?? hopefully there will be no nasty surprises in my future
Old Jun 25, 2007 | 08:36 PM
RxJaye's Avatar
U had a Intermitten fault. Your probably did something to activate the ABS system and it failed. The abs system goes through certain checks everytime the car is started, so when you turned it off and restarted it, it did a self check and everything appears good at that time. Good news is that a fault code (DTC) will be stored in the ABS module. It could happen again the next time you have an ABS event.
If it was a bad ground the light would stay on.
Old Jun 30, 2007 | 09:56 PM
CnnmnSchnpps's Avatar
No means yes
Your problems are all related to that X-men wing :-D
.... j/k
Probably an intermittent fault, but I would suggest giving your ABS system a "test" to be sure (i.e., wait for rain, find an empty parking lot, and have at it :-D )
TeslaMSI
Dec 10, 2015 01:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
mattymack
Sep 6, 2015 10:33 PM
rxwilly8
Sep 2, 2015 02:42 PM
