Defog Question...
Old Jun 24, 2007 | 09:26 PM
delhi's Avatar
Grand Chancellor
Defog Question...
I'm wondering if the 8 like most cars automatically turns on the A/C when you activate the defog function. If so, how come the A/C light doesn't light up? Or should it (warranty!). Or do I need to manually turn the A/C on as well?
Old Jun 25, 2007 | 07:13 PM
puch96's Avatar
the A/C comes on when the defog is turned on (if the outside temperature is above 32 F) or close.
It's normal behavior. Some cars have a way to turn the "auto A/C" feature off
Old Jun 26, 2007 | 11:47 AM
delhi's Avatar
Grand Chancellor
But the A/C light doesn't come on. Is my light broken? But it comes on when I manually switch on the A/C
Old Jun 26, 2007 | 11:50 AM
DarkBrew's Avatar
Extraordinary Engineering
The AC light only seems to indicate that the driver asked for AC. The other functions are 'hidden'...
Old Jun 26, 2007 | 12:07 PM
StealthTL's Avatar
Cool It is written......
The computer turns it on when you sellect certain windshield/feet flows - it's even in the manual. Says the light won't show.
If you don't like it, pull the fuse marked A/C Clutch - the computer thinks it is still working, but it ain't.
S
Old Jun 26, 2007 | 03:10 PM
delhi's Avatar
Grand Chancellor
OK i read the manual thrice.... i must've somehow dozed off in that section.
Old Jun 27, 2007 | 04:39 PM
Nubo's Avatar
Lubricious
The AC won't come on if you put the selector into "full face" mode. That's what I normally use on those "bizzarre" occasions when want the heat on but not the air conditioning. :shrug:
NotAPreppie
12
Sep 24, 2015 03:22 PM
MolecularConcept
Aug 5, 2015 04:43 PM
papipito
28
Dec 6, 2006 12:29 AM
Xtasy94
19
Dec 14, 2003 06:17 PM
dankgummy
17
Sep 5, 2002 05:04 PM
