Remote Not Working
Old Jun 10, 2007 | 04:22 PM
Davey's RX-8's Avatar
Red headed stepchild
Remote Not Working
Tried replacing the remote's battery with no luck. Spare works fine. Bad remote?
Old Jun 10, 2007 | 04:32 PM
DarkBrew's Avatar
Extraordinary Engineering
I assume you mean the remote to unlock your doors?
Was it working before? When did it stop working?
Old Jun 10, 2007 | 05:49 PM
TRAVASS's Avatar
real easy to reset if the battery in the remote is fine. make sure you ave all remotes there and do all at the same time. turn the key to acc then to off , 3 times in a row. and then push the button in the drivers side door frame 3 times, then push each remote, until they lock or unlock the doors. should work. somebody correct me if im wrong.
Old Jun 13, 2007 | 08:49 PM
Brought it to the dealer, they confirmed it went bad and replaced it. Odd thing is, they also notices that the power lock actuator on the driver's side went bad, where it never had a problem before bringing it there. They ordered a new one under warranty. Go figure.
bullbuchanan
26
Mar 24, 2016 12:37 PM
TeslaMSI
Dec 10, 2015 01:10 AM
maichristopher
Sep 7, 2015 09:16 AM
ion_four
Jul 30, 2015 09:48 PM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
