West RX-8 Forum Serving CA, NV, AZ, HI
Dyno Day San Francisco/Bay Area
Old May 31, 2007 | 05:31 PM
8rotor8's Avatar
Back in the day...
Hello everybody! I am talking to a shop in Hayward to set up a Dyno Day for any 8's in the Bay Area. It will cost $60 for 3 pulls with A/F. I am just putting this out there to see if there is enough interest to get this set up. It will be on Saturday, June 30th, depending on everyone's schedule and if there are enough people interested. Post here for what day and if you want to attend.
List your mods:
1. 8rotor8 - 30th works for me. RB Street Flash, Revi, RB Exhaust, RB spark plug wires, 18x8 RPM2 w/ RE-01 245/45, Grounding Kit. COMFIRMED
2. RX Guy - 30th works for me also. COMFIRMED
3. Mr. Downs - 30th would work best for me, I'm moving on the 16th.
4. N Rider89 - 30th works, i just need more info. COMFIRMED
5. Ever - 30th, the sooner the better though
6. Chadlington -30th. MS Intake, Greddy Exhaust, RB Spark plug wires. COMFIRMED
7. Gr8handling - 30th - greddy sp2 exhaust, k&n typhoon ver. 2, tein basic coil overs, 18x8 w/ 245/40 and 18x9.5 w/ 275/35. COMFIRMED
8. Endless Rotaries - Pending - NT03+M 17x9.5 +44 245/45/17 Falken ZE512, commuter tires hehe, 2 Piece Rotors Front and Rear, ACT Flywheel, Exedy Organic Clutch, AEM CAI, Espelir Catback exhaust, Koyo Aluminum Radiator
9. SiLVeRE8 - 30th would be best. borla exhaust, racingbeat test pipe, act prolite flywheel, act heavy duty clutch, revi intake and duct, agency power pulley, ground wires, ce28n 18x8.5 with 245/40/18 front and 18x9.5 with 275/35/18 rear.
10. YayAreaBruh21 - 30th would be best for me. HKS High Power Exhaust, RP Supercat, ACT Prolight Flywheel, Exedy Stage 1 Clutch, Revi Intake and Duct, Unorthodox Pullies COMFIRMED
11. trancesimulator - 30th. COMFIRMED
Old May 31, 2007 | 05:56 PM
RX Guy's Avatar
Originally Posted by 8rotor8
Hello everybody! I am talking to a shop in Hayward to set up a Dnyo Day for any 8's in the Bay Area. It will cost $60 for 3 pulls with wideband. I am just putting this out there to see if there is enough interest to get this set up. It will be on a Saturday, either June 16th or 30th, depending on everyone's schedule and if there are enough people interested. Post here for what day and if you want to attend.
1. 8rotor8 - 16th or 30th works for me.
2. RX Guy - 16th or 30th works for me also.
3.
4.
5.
Old May 31, 2007 | 08:13 PM
Throwdown's Avatar
Turb O'd
4.
5.
Old Jun 1, 2007 | 12:15 AM
N rider89's Avatar
^NieL
4. N Rider89- either i just need more info.
5.
Old Jun 1, 2007 | 04:03 AM
Ever Hernandez's Avatar
Rx8_4eVeR
[QUOTE=N rider89;1905144]1. 8rotor8 - 16th or 30th works for me.
5.Ever -16th or 30th, the sooner the better though
Old Jun 1, 2007 | 12:57 PM
Friendlydacat's Avatar
I'm mentally retarded.
[QUOTE=Ever Hernandez;1905307]
Hi, I'm interested, but I may be going on a business trip to Israel, so I'm tentative.
Rob
Old Jun 1, 2007 | 01:10 PM
LionZoo's Avatar
road warrior
Both the 16th and the 30th don't work for me.
Old Jun 1, 2007 | 01:54 PM
8rotor8's Avatar
Back in the day...
Damn, are you serious? Headed to LA both those weekends huh? just give me your keys and I'll dyno it for you.
Old Jun 1, 2007 | 02:10 PM
8rotor8's Avatar
Back in the day...
4. N Rider89 - either i just need more info.
5. Ever -16th or 30th, the sooner the better though
6. Chadlington - either day
Old Jun 2, 2007 | 02:54 AM
gr8thandling's Avatar
7. Gr8handling - any day
Old Jun 2, 2007 | 01:01 PM
map's Avatar
map
my 8 is stock
Old Jun 2, 2007 | 02:58 PM
Endless Rotaries's Avatar
Any of you guys who signed up have Lightweight flywheel, intake, and catback?
That's basically what i have except i have ligher 2 piece rotors as well.
Word of advice, if your wheels are bigger than stock TAKE THEM OFF. The dyno will be pointless and you will be saddened. i.e. EVER, remove the 19's and put the stockers on.
I would do the same. Take off the 19's and put my 17x9.5 +44 NT03+M's on there.
Now question, do we just disable the ABS and Traction control to get good dyno figures? I remember that whole issue with the 8 not getting good dyno readings. I really wanna see what that RB flash did so i'm hoping there are relative comparisons. If he can pull the power i have then shiet, i need the flash. i'm leaving for LA from the dyno directly. hahahahahaha.
thanks, Rishie
Old Jun 3, 2007 | 11:09 AM
8rotor8's Avatar
Back in the day...
Here is more information, this is from the email sent to me:
"David, most of our dyno days we can fit 8 people in a day. We can do more if you like, but that will really depend on. This is how our normal prices break down.
3 pulls 50 dollars
A/F – Tailpipe air fuel ratio curving – 10 extra dollars
Wideband – 25 extra dollars, this is of course assuming people have a secondary 02 bung in their exhaust pipe.
We tune AEM EMS, Haltech, SAFC, for the RX8’s"
Rishie, I hope my bigger tires won't mess with the numbers too much, i'm running 245/45 on 18x8, if you have a set of stockers around that I can use on the dyno maybe that will show true power that the RB flash gave me. Prior to the dyno, I'll wash out the filter, change the oil, and run 87 octane. I do think we need to atleast turn off the DSC, but i'll try on run with the DSC off, then the next two runs with everything off.
Old Jun 3, 2007 | 11:17 AM
8rotor8's Avatar
Back in the day...
List your mods:
1. 8rotor8 - 16th or 30th works for me. RB Street Flash, Revi, RB Exhaust, RB spark plug wires.
6. Chadlington - either day. MS Intake, Greddy Exhaust, RB Spark plug wires.
Old Jun 3, 2007 | 02:43 PM
Old Jun 3, 2007 | 04:32 PM
I don't think you'll be affected too much 8rotor8 because you do have a lighter wheel and the mass should be about the same. If you increase wheel diameter, that's where you can lose power even if the combinations weigh the same as stock.
I've run into situations like this before with my FC where I had some 18x9.5's in the back with 255's and a basically stock FC pulled more power. I was very disappointed. So always remember to find that balance between power and weight in all aspects. Rotational mass, Sprung and unsprung masses, etc....
If i were to sign up, date pending: I'll list all mods, some might not apply to power output.
1. NT03+M 17x9.5 +44 245/45/17 Falken ZE512, commuter tires hehe.
2. 2 Piece Rotors Front and Rear
3. ACT Flywheel, Exedy Organic Clutch
4. AEM CAI
5. Espelir Catback exhaust
6. Koyo Aluminum Radiator
Rishie
Old Jun 3, 2007 | 07:30 PM
N rider89's Avatar
^NieL
i have an a/t, im already going to be dissapointed
Old Jun 4, 2007 | 01:34 AM
Rx8_4eVeR
Awww, crap! I don't have the stockers anymore. Should I just do it for the hell of it. I"m just wondering how much off the numbers would be...
Old Jun 4, 2007 | 10:36 AM
8rotor8's Avatar
Back in the day...
You can always swap tires with another member before you dyno.
Old Jun 4, 2007 | 05:22 PM
NOpes, SWAP TIRES/WHEELS ever.
Rishie
Old Jun 4, 2007 | 09:04 PM
scremn8's Avatar
the more things change
we did the same thing down here in the south. we had about 17 cars everyone left there cars as they were just to see what they were pulling with what they had on. but one thing we found that did help was running the car hard just before we dyno'd... #'s were better for the cars that did...
Old Jun 5, 2007 | 05:58 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
1. 8rotor8 - 16th or 30th works for me. RB Street Flash, Revi, RB Exhaust, RB spark plug wires, 18x8 RPM2 w/ RE-01 245/45, Grounding Kit.
7. Gr8handling - any day - greddy sp2 exhaust, k&n typhoon ver. 2, tein basic coil overs, 18x8 w/ 245/40 and 18x9.5 w/ 275/35.
Old Jun 5, 2007 | 10:27 AM
YayAreaBruh21's Avatar
Old Jun 5, 2007 | 03:28 PM
c41250n's Avatar
can it be anytime after july 16?
Old Jun 5, 2007 | 04:09 PM
8rotor8's Avatar
Back in the day...
I can set up another one anytime, but for the first one, I don't want to drag it out for too long.
