RX8 Factory Fitted Alarm Volume
Old May 20, 2007 | 12:48 PM
bigal_miles's Avatar
Hi all,
Does anyone knowA) where the alarm unit is and B) if you can turn the volume up on on it, I have just set mine off to see how loud it was as the horn is quite loud !! to find a little fairy tweeting at me hardly able to hear to the fact that mates took the mickey !!!
Any help would be great !!
Cheers Alun
Old May 20, 2007 | 12:55 PM
The alarm is located at the passenger side.
the alarm vol = your horn's vol.
So no, you cannot change it, unless you change your horn.
Old May 20, 2007 | 01:00 PM
cheers for your reply
Old May 20, 2007 | 01:10 PM
chickenwafer's Avatar
Nope
yeah, the system doens't have a siren, just uses the horn. If you pull your horn fuse while the alarm is going off there will be no siren.
Old May 20, 2007 | 01:48 PM
Unhappy
I dont think its a factory fit then as the alarm is really quite quiet !!! and the horn is quite decent i mean i was stood about 20 feet from the car and could hardly hear it !!! its a 2003 model so were they fitted with factory units then ?
Old Jun 3, 2020 | 03:01 AM
4m4s0's Avatar
Very quiet battery backed alarm
Yeah! I have the same problem as you. Mine is 04 with a battery backed alarm system. I tried setting it off and can barely hear anything from it. The turn signals flashes.
I disassambled the alarm sounder to check if it was anything wrong with the speaker/Siren and connected it to a speaker of my own, but it was nearly whispering too.
Maybe it's a Europe-model alarm for the 04s. Mine's from Austria.
Here is a video of it. Try hearing the alarm if you can:
https://streamable.com/6fm918
MsKingRotary
Apr 23, 2016 05:45 PM
RXeckless
Aug 16, 2015 12:52 PM
akagc
Aug 11, 2015 07:07 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
AussieGray
Jul 16, 2015 03:58 AM
