Official word from Mazda on dyno'ing RX-8
Old Sep 25, 2003 | 09:44 AM
Gord96BRG's Avatar
Rotary News has posted an official announcement from Mazda Engineering regarding dyno testing the RX-8. It explains the power reduction modes that happen when running an 8 on the dyno.
From the Rotary News article :
Statement:
There is no true way to generate flywheel horsepower from a chassis dynamometer because of frictional losses in the driveline, clutch, transmission, differential and tires. Also, variations in testing procedures will cause highly disparate readings: open/closed hood, high/low humidity, high/low ambient temperature, tire pressure, how tightly the car is tied down, which gear the car is tested in, etc.
In addition, we have determined that, in order to prevent damage to the catalytic converter and the entire driveline, when the PCM determines unusual operating parameters such as excessive slip in the drivetrain from the front to the rear wheels, it causes a rich high-RPM mixture and retardation of the timing. All these items combine to cause apparent considerable horsepower loss.
BACKGROUND:
Horsepower Measurement
There is only one true method for measuring engine horsepower: on an engine dynamometer at constant speed and utilizing variable load.
The engine should use the same intake and exhaust system as in the car. HP results must be corrected to SAE J1349 standards as listed below:
77 degrees Fahrenheit
Sea level
0% humidity
Correction factors must be applied to reference the measurements to SAE J1349 standards. Any correction factor beyond 7% is considered invalid.
Chassis Dynamometers
SAE has produced a technical paper (SAE Technical Paper Series 2002-01-0887) that attempts to address the ongoing debate about inertia dyno horsepower versus OEM net horsepower. You can order a copy by visiting their website at www.sae.org -- we have no intentions of getting mired in the middle of this discussion.
Bottom line: If used properly, chassis dynos are great tools to assist with tuning and modifying vehicles. It is impossible to measure the actual flywheel horsepower because there are simply too many variables.
Other issues that are unique to the RX-8:
The RX-8 uses a very advanced engine management system. Besides precisely controlling the operating parameters of the engine, self-preservation (of both the engine and the catalytic converter) is also considered.
The engine management system continuously monitors all engine functions and adjusts accordingly. For example:
Under heavy load acceleration, the timing is retarded and the fuel mixture richened to reduce the likelihood of pre-ignition or spark knock. If spark knock is encountered, a knock sensor senses the condition and further retards the timing. Gradually timing is advanced and fuel mixture leaned after the load is reduced.
A second reason for fuel enrichment is that when timing is retarded, exhaust temperatures increase; a richer mixture lowers the exhaust temperatures and reduces the chances of damaging the catalytic converter.
In real world driving, this all goes unnoticed to the driver and appears seamless with no disruptions to the performance of the engine. The car encounters a load under acceleration but the load quickly diminishes as the car accelerates in each gear.
Operating on a chassis dynamometer, however, creates a completely different environment. Inertia dynos use a known mass that is accelerated to measure torque at the wheels. This is usually done in one gear under heavy load conditions:
Only the rear wheels are turning while the front tires remain stationary.
On cars equipped with DSC with traction control, the difference in speed between the front and rear wheels is sensed and the power is reduced immediately to compensate for what the car senses as excess wheel spin.
If the DSC is turned off, the traction control is disabled but the brake functions of the DSC are still operational.
If the DSC system is completely disabled, this removes the brake functions from the equation, however it does not fully remove the engine management system functions.
The ABS hydraulic unit/control module (HU/CM), or the DSC HU/CM for cars with DSC, determines vehicle speed by comparing the speed of all four wheels. If two are turning and two are stationary, it will still compute a speed but senses that the car is experiencing excessive wheel spin. To protect against engine or catalyst damage:
The engine management system compares the throttle opening, gear selection (determined by engine speed and road speed) charging efficiency and engine coolant temperature to determine the driving condition.
Since the car is under heavy load, in a tall gear (testing is usually performed in third or fourth gear), with a wide throttle position angle (wide open), spark timing is reduced and the fuel mixture is richened to reduce the occurrence of spark knock and to reduce catalytic converter temperatures.
There you have it, folks - right now, all dyno tests to date on the RX-8 are not showing the true power output of the Renesis.
I hope all the scare mongers who have spend the past 2 months bad-mouthing Mazda and the RX-8 (you know the ones - "Mazda lied to us and cheated us") will now be man enough to admit they were wrong and post apologies!! (Yeah, like that would ever happen) :D
Regards,
Gordon
Old Sep 25, 2003 | 09:52 AM
Wing's Avatar
Well to me the car must have at least 238hp, after test driving the 350z with it's 287hp I expected to be wowed by it's power. It was underwelming and not really much faster.
Old Sep 25, 2003 | 09:58 AM
Spin9k's Avatar
Momentum Keeps Me Going
Is there such a thing as a dyno that has the all wheels spinning via pully from the driven wheels?
maybe if so that could put this Mazda statement to the test and settle the debate and quiet the naysayers once and for all. Just one dyno graph of a 4 wheel dyno would solve the puzzle!
Then we could all just go out and drive our cars rather than debating our cars half the time.
Old Sep 25, 2003 | 10:10 AM
compaddict's Avatar
I really don't want to start anything more than I have already have but the article is from RotoryNews not Mazda right?
Vince
Old Sep 25, 2003 | 10:23 AM
RX8-TX's Avatar
Senior Geek
Apologies?? for what??
1. They did downgrade stated HP for A reason.
Admitedly the car is no slouch, but c'mon. I was pissed with the HP thing in the very beginning...not much in comparisson to some others. However, I still won't forget a missrepresentation like this one.
Do you think they would have downgraded HP if there was no reason for it? get a load of negative attention + 'Fxxx UP their Sports Sedan (or Sports Car....doesn't matter too much to me) product competitivity in the market? IMHO: NO, they wouldn't even have paid attention if the car was doing things right.
Is the car performing poorly: ITS PERFECT FOR ME. I don't drag race, I don't street race, I need a fun car to take my wife & me from home down the office, and back.
Do I regret it? Absolutely NO; we'll talk again in 100K miles and some oil & filter changes, and maintenance on the record.
Do some people should regret it? Maybe: depending on what they were expecting; but c'mon, if you test drove the car, you knew what you were getting. I did, and I loved it the moment I laid hands on it.
Mazda should regret it? They better do; they better sell shxx loads of it, get more funding from Ford and develop the 7 (or any 2 seater alternative for that reason Rotary powered.)
Why?? Because I don't know if I could be able to drive a piston engine again (as I said before, we'll talk again in 100K miles.)
Cheers!
Old Sep 25, 2003 | 10:33 AM
poison123's Avatar
"we have determined that" gee sounds like to me they should have known this was a issue from the beginning.
Old Sep 25, 2003 | 10:34 AM
rotarynews.com's Avatar
Vince
Read RotaryNews... " Mazda has backed [our] hypothesis up with a release of information."
IE, from Mazda...
If you don't beleive so then see the attached screen shot from my inbox.
So, our standing is backed up by actual automotive engineers from Japan. Thereby proving that we know what we are talking about.
Old Sep 25, 2003 | 10:36 AM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
Vince
I believe that Rotary News -- as a media source -- was reporting a story from Mazda Engineering (as evidenced by the title of the article). This is significantly different than Dan or Bern posting a personal opinion on this board.
Old Sep 25, 2003 | 10:38 AM
Kev's Avatar
Kev
[rapidus octus]
Walks like a duck......
I believe them!
Old Sep 25, 2003 | 10:50 AM
ChrisW's Avatar
Re: Official word from Mazda on dyno'ing RX-8
I don't understand their use of the word "load" here. Surely, the load on the engine is the resistance it encounters as it attempts to turn the driveshaft. This would be a function of the weight of the car and the gearing (and at high speed the aerodynamic drag). So in the real world (as the weight is constant) high load simply means being in a high gear.
Are they saying that it will only produce maximum power in low gears?
And what about "the load quickly diminishes as the car accelerates in each gear". I don't understand that statement at all.
Old Sep 25, 2003 | 11:14 AM
compaddict's Avatar
I would like to see a TSB or a statement from Mazda on Mazda letterhead that's all.
It's really not all that much to ask is it?
Vince
Old Sep 25, 2003 | 01:40 PM
mikeb's Avatar
100% Italian
he is giving all the info he knows
relax
Old Sep 25, 2003 | 01:41 PM
T-von's Avatar
The game changer!
How would you expect them to know something like this? Name one manufacturer that has ever released a vehicle and only advertised rwhp from a dyno. Also this is the first rotary powered vehicle to have these additional safety features.
Old Sep 25, 2003 | 02:40 PM
poison123's Avatar
T-Von the guys who created the system should have known this would fudge results from it. After all aren't they marketing this car as a sports car? I mean they designed the system to retard the car if something abnormal was happening with the wheels, How smart do you have to be to figure out "Hmm all these guys dyno's suck, maybe its because of the safety systems we installed to retard performance if the wheels aren't going like they should" Just a thought
Old Sep 25, 2003 | 03:04 PM
Peter Sawko's Avatar
Talking Unbelievable
Seems to me that Mazda has started to answer some of the questions being raised.
Engineers are typically myopic and focused on whatever details they have in front of them so it doesn't surprise me that the response took a while.
I do find the endless questioning unbelievable and unjustified. I also credit the engineers who spent the last 4 years developing the car and engine with a better understanding of the dynamics involved than most of the commentarians on this and other threads.
Old Sep 25, 2003 | 04:00 PM
GoBerserk's Avatar
real power losses
We should all thank Gord for clearing this issue up. I would hope that no one would expect 238 at the wheels; that's just not possible if the engine makes 238 at the flywheel. As the article states, it is impossible to get flywheel hp without actually putting the renesis on a real engine dyno. I'd like to hear from someone who's actually done that.
As for a real power loss. I'd be more upset about the A/C compressor losses when the A/C turns on when you don't request it. When I get my 8 the first thing I'll do is to run the wire for the compressor clutch in series with the A/C switch so the switch actually controls whether the compressor is on or not.
Now lets stop complaining about phantom power losses and talk about real issues.
Old Sep 25, 2003 | 04:41 PM
medcina's Avatar
Re: real power losses
I'd make sure to include the temp switch. If you don't and have the dash switch be the only thing that determines if the compressor is on or off, your system will be frozen in no time.
Old Sep 25, 2003 | 06:29 PM
KyngNothing's Avatar
Re: Unbelievable
No, i think most of the people on this forum know more about the RX8 ecu than the people who designed and built it, don't you?
Old Sep 25, 2003 | 07:59 PM
mikeb's Avatar
100% Italian
we certainly care to find out more than them
Old Sep 25, 2003 | 08:38 PM
mullogutherum's Avatar
Note that:
(1) Mazda USA apparently arrived at their revised 238 HP figure after chassis dyno testing of 11 production cars. The results were then passed through a roomful of lawyers. In light of their latest statement, just how accurate could the revised figure be?
(2) If you read the statement carefully, the circumstances which can generate "considerable horsepower loss" are by no means limited to chassis-dyno-like conditions. Indeed, fuel enrichment and timing retardation appear to occur under any "heavy load acceleration". The latter term isn't defined, but nothing in the statement specifically precludes the power loss from arising in normal operation of the vehicle.
Old Sep 25, 2003 | 08:44 PM
StretchSJE's Avatar
So, the engine makes less power under a load or if the front wheels aren't spinning. The first part puzzles me- is the engine ever not under a load when at WOT? Could the engine ever even reach a torque/horsepower peak if not at WOT? The engine makes less power in higher gears due to increased load?
Odd then that the highest dynos were in 5th gear (a tall gear, even if 1:1) and with regular fuel (high octane would prevent pings or knocks). I guess Mazda thinks it'd be better to dyno in 1st gear with premium?
Old Sep 25, 2003 | 10:37 PM
RXhusker's Avatar
Interesting that the Jeremy Barnes shown in the Rotary News email is also listed on THIS ARTICLE in CNNMONEY as being a "spokesman for Mazda North American Operations".
Gee -- maybe thats as good as being on "Mazda Letterhead"
Old Sep 25, 2003 | 11:17 PM
RotaryRocketMan's Avatar
Dyno testing question
I am not real familiar with the dyno-testing process or car engines in general. I somehow seem to have a knack for fixing them though. Anyway... does it not matter that the car is just sitting still when being dyno'ed? If I recall correctly, from a Mazda mechanics video on the 8, at high load/HP/RPM conditions, an additional engine air intake port opens up. The air is fed from the front-end scoops. Seems that speed would effect the amount of airflow being forced into the engine. No airflow, no power. What is wrong with this assessment? Is the airflow change due to speed negligible? Do other engines have additional ports that open up like the RENESIS?
Thanks for any responses.
Zoom-zoom.
Old Sep 26, 2003 | 01:00 AM
bureau13's Avatar
The only thing that still nags at me is the question of in-car dyno type devices e.g. G-Tech. They appear to indicate a similar torque curve as the chassis dynos. If the ECU issues with wheelspin, etc were totally to blame for lower-than-expected chassis dyno numbers then you would expect in-car dyno numbers to look better.
jds
Old Sep 26, 2003 | 01:03 AM
silver8's Avatar
Originally posted by mullogutherum
Note that:
Agreed.
Who watched "Ed" (american sitcom) last night about the guy selling puppies as pure breds? Of course they were mutts, he offered to return people's money after a week. Well, guess what? Of course, no one took him up on it. It's the old puppy dog close (the first sales technique taught...). Mazda has mastered it.
The similarities between the Miata and the 8 goes beyond their having the same maunfacturer and producing less-than-advertised horsepower. Sorry to say it but the 8 is a Miata: handles great, but underpowered. Why do you think there are 20 rx's at just one of the local dealerships? There are people that LOVE their Miatas..many have dropped $K's on mods though.
The "explanation" of dyno'ed HP seems far too simplistic. What 16-year old wrote it? Why did it take Mazda a year or more to figure out/admit that the US-spec car was making less than announced?
Hmmmm.
