i know you're suppose to drive the rotaries a certain way..
Old Sep 25, 2003 | 03:34 AM
energie's Avatar
does anyone know what that is?
I remember talking to someone with an RX7 and he told me that you are suppose to take care of rotary engines differently and drive it differently. Does anyone know if that is true?
Old Sep 25, 2003 | 06:40 AM
Elara's Avatar
yeah- hard
Old Sep 25, 2003 | 08:07 AM
RotorGeek's Avatar
Still spining
REV IT like crazy. Don't shift till you hear the buzzer
Old Sep 25, 2003 | 08:39 AM
Slickvic's Avatar
Thumbs up
I drove my '82 RX-7 for ten years. And I Always drove it like I stole it. Keep up with the oil change maintenance and never let the engine overheat. That's about it. The rotary engine begs for the redline. And after driving an RX-8, so will you.
Old Sep 25, 2003 | 09:49 AM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
Posted this on another thread, but here you go:
Here's what the RotorHeads recommend everyone to do: you can shift around any RPM range, yes even at low RPMs AS LONG AS YOU ARE NOT LUGGING the engine along. Also, everytime you drive the car, after the engine has reached normal operating temperature, it is recommended you to rev it all the way to the Red line at least once. This is to ensure that you will not have hydrocarbon build up and clog up the ports.
Just keep up with the Oil change, check your oil once in a while. Make sure you warm it up before shutting off the engine and should have an engine that is good for 200,000+ miles.
Old Sep 25, 2003 | 12:31 PM
R8N8SIS's Avatar
I Rev it up to redline 40% of the time on the road, and i normally shift between 5k to 6k on normal driving.
Old Sep 25, 2003 | 12:39 PM
brothervoodoo's Avatar
RainMan is Back
Also try to keep in on the road apparently and admittedly so, that is too hard for me to do..
Old Sep 25, 2003 | 04:05 PM
rotary-tt's Avatar
Don't stop and start it repeatedly and let it warm up before running the hell out of it. Put over 100k miles on several 7's this way
Old Sep 25, 2003 | 06:36 PM
mikeb's Avatar
100% Italian
what elara said
Audio Concepts ATL
Sep 26, 2021 01:59 PM
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Ccrosskno21
Jan 9, 2016 05:43 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
AussieGray
Jul 16, 2015 03:58 AM
