strange power steering feel
Old May 7, 2007 | 08:26 PM
Vrimmick's Avatar
It seems I have a problem with power steering. It just feels weird. When I turn it a little everything is fine and it is working normally but when I turn more - about a quarter of the wheel turn then it feels as if the power steering stopped working and it is heavier. Then when still steering it is back on. The light did not come up and everything besides that is fine. Is it possible that suddenly my allignment is totally out of whack and that is causing it? Or is it steering motor? Any thoughts?
Old May 7, 2007 | 08:52 PM
Get the steering checked.....it sometimes fails so that one direction is working and the other not.
A lot of the faults have been the sub-wiring harness between the motor and the main harness. If you remove and clean/re-install these connectors odds are that the problem will go away
Old May 8, 2007 | 08:51 AM
donack456's Avatar
Are you sure the PS reserver is full or not low?
Are you sure the PS reserver is full or not low? That happens on some of my cars you fill the PSR and eventually it goes away. Don't know why it doesn't work well half filled? Fluid level check.
Old May 8, 2007 | 09:18 AM
Vrimmick's Avatar
It's electric not hydraulic - no fluids. I think I diagnosed the problem. I must have lost a tooth on a gearing (either on a rack or steering column). Do you think it is possible?
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
04rx8rotary
Sep 3, 2015 04:36 PM
